gregthiara
Everything posted by gregthiara
  1. Hi Richard, Hope you are well, have checked unit by moving seat up and back all seems to be dry however since moving seat car is now staying locked and windows closed, key remote is now also working first time. I need to go and buy a socket to remove seat so I can check all wires. Thanks.
  2. Hi Loren, The battery is about a year and a half old and the voltmeter is showing between the 12 and 14 seems to be where it has always been and hardly moves when you switch headlights on. I will try checking alarm as Richard said maybe this has somehow got wet.
  3. Hi Loren, I can not find any damaged or bad ground wires. I disconnected the window motor wires and found them to be a bit damp cleaned and put back together but still have the problem, still had the problem even with all wires disconnected. What is happening exactly is I can hear what sound like a relay clicking in each door then the car is unlocking itself then the windows come down even when the car has opened the windows and unlocked itself you can still here relay clicking in each door. The car is not unlocking itself or locking straight away with the key, the sensor in the car in the middle of the front window flashes when you try to lock/unlock but it doesn’t re-spend and sometimes works but most times not. It seems to be acting like when you hold the button on the key remote and it unlocks and opens the windows I have had to remove the fuse for the electric windows and take out the door lights but this is not good as windows need to be forced in to close doors. (can not remove the interior light fuse as alarm is connect to it) Need help as the weather is very cold -6 unbelievable for UK, I really do not want to take the car to Porsche as I know im going to get stung. Thanks.
  4. Hi Loren, Is there something I should check or should I just remove the door card check the wires that attach to it and put it back on. When I removed the door card im sure I didn’t do anything to damage the wires, however this issue is down to me removing the door card as now only passenger door window is opening by itself and it all started after my removal and reinstall. Thanks.
  5. Ah yes I had the passenger door card of a couple of days ago to change some of the plastic door panel clips could be something I done then. My aunt owns some Arbys not rb's, Thanks again loren.
  6. Thanks Loren, What do you suggest I do? By the way my aunt lives near you in Rocklin they own a few RB'S around your area let me see if I can sort you out a few free meals. Regards, Greg.
  7. Hi I own a 996TT 2001 with 80K on the clock. When I’m driving along both the windows start going down and the interior lights come on, I put them back up but they go straight back down. This has been going on now for two days, and today the passenger side was going down and interior lights on when I was driving along at 80. Does anybody now the cause of this?
  8. I had to ring porsche to get my key deactivated, then I purchased another from them I think it was about £150 may have been £180 can not remember for sure and I did have to take the vehicle to them with the remaning key I had. But I was able to drive there. ring your porsche service department and tell them what is going on with the key. they did say to me if somebody has the key that was deactivated then it would still allow them into the car but would not let them start it. Hope this helps a little. Regards, Greg.
  9. sound like you are trying a deactivated key. A deactivated key will unlock all doors and do all as you say but will not start car. if spare doesnt work you need to contact porsche dealer. I lost my key and had it deactivated from porsche, few weeks later found the key and it did the same as yours. if the key has been deactivated then you can not use it again. regards, Greg.
  10. My lights where also damaged in the same place after I had a little bump nothing major just lifted the bumper a little, done the repairs myself and also repaired the lights. Im not saying your car had a bump this could also have been done with force as you say. I used fibre glass repair and then sanded and painted over with black paint, be careful you don’t put any inside the light, it was very simple and now you can not see the damage I think fibre glass repair kit would last the lifetime of your lights mine cost £11 in the uk and was done over 3 years ago still unable to tell where damage was. Hope this helps.
  11. You need to have a good talk with the dealer, was it bought from porsche? if so then the 30k service should have done before the vehicle was purchased by anybody as the vehicle was so close to its service time. if the vehicle was not bought from a porsche main dealer then its up to the garage. Regards, Greg.
  12. Hi, Mine has stopped turning down altogether when selecting reverse although memory seat and mirrors still work, and reverse lights. I would also like to know what the possible cause is and how to fix. Thanks
  13. Hi, Does anybody know where to get a 2010 sat nav cd, my car is a 2001 so I think its the pcm1 sat nav. The disk is made by NAVTEQ, only I do not wish to pay the dealer price £500-£800, can anybody copy and send me I will pay or suggest a download. Thanks. forgot to say UK version
  14. Hi Guys, My 996TT 2001 with 80k on the clock and no mods was recently only boosting to 0.5, so I suspected the hoses and as it was going to have brakes changed at a Porsche specialist anyway so I had them check the boost and there was a gasket blowing on one of the turbo's. Replaced and now the car is boosting to a constant 0.7 and I have been told the hoses do not need changing as they are fine. But after reading on the forum that you guys are all boosting to 0.9 is there still something wrong with my car? I have had the car for four years and it only had 25k on the clock with Porsche warranty being brought from a Porsche dealer and I can not remember if the car ever boosted to 0.9 I think it always hit 0.7, Sorry for the long explanation but please advise, Thanks all.
  15. does the cover just pull off
  16. Hi Guys, Could anybody tell me where the radio signal booster is located on a 996 turbo 2001, when I have the windsreen wipers on the radio has poor reception and is fuzzy when the wipers move. THANX..
  17. Hi guys, has anybody had a ecu remap on a 996tt? thinking of having it done from revo in the uk, is it worth it and can you feel the the results?
  18. Hi Guys, maybee im missing the page but I can not find the instructions on how to change the rotors on a 996TT, been informed its the same as 996c, I would like to know the tools needed and correct torque
  19. thanks wasnt sure if it was diffrent
  20. Does anybody have any instruction on how to change the brake disks (rotors) on a 996TT with pictures.
