Cayenne17
Everything posted by Cayenne17
  1. depending on your location check with your dealer i know they make them i have seen them
  2. I reciently installed a HID kit that Vertex sells for the Boxster. I ordered the 6000K super white kit. The install was pretty easy and the results are FANTASTIC! The lights look like the high end euro's and the performance is as good as ANY lights out there. Also, the lights look like they belong on the car. Originaly I did this install on the Boxster and I was very happy but when I did it on my wifes Cayenne I must say I was jelous. The kits run for about $250 on Ebay and come with a 1 year warrenty. Just do a serch for Boxster HID. Hope this helps. Regards, Scott my headlights and fogs are HIDs 8000k :D look for JDM HID porsche 165 :) AWSOME PRODUCT
  3. haha mudman how did you break that seal what tool did you use im afraid to dent the rear end :censored: haha :D
  4. pimpin it may be the DVD hardware itself issue not compatible
  5. try to pull forward both front seats and re-lower rear seats lift up larger driver side section of rear seat....then raise passenger side the middle belt harness should re-raise..its on a spring hinge. if not it may require a "stealers" touch
  6. i believe it is the same exact wheel :)
  7. good luck trying to remove the tailights :D i havnet had any success dealer always does my bulbs :P
  8. I did the full conversion to mine for about 2000 dollars front bumper 4 grills mounting supports hood paint etc cool could you tell me where i can buy the turbo hood from? thx Give a call into Sunset Motorsports in oregon at 800-346-0182 if there pricey try DSP Motorsports ask for Dayton 877-550-8555 shipping might be $$$ depending on your location. i also messaged you back **Marco**
  9. had mine replaced its a airbag with the controls must remove airbag and deactive battery
  10. I used etrailer.com and ordered part number 11775 and it fit the Cayenne. It is a Pollak 7-way rv oem style socket. If you type that part number in their search box you should see it on their site. If the trailer you will be using has a 'flat 4' or other type of connector you may also have to buy a 7 pin to 'whatever you have' adaptor. I have a flat-4 on my utility trailer and had to buy that adaptor. All works great with this setup. Good luck. You need a general plug adapter plate i have it for my 05 cayenne and tow my boat with it :)
  11. I did the full conversion to mine for about 2000 dollars front bumper 4 grills mounting supports hood paint etc
  12. very simple just take into the driver side fuse box or use the homelink power in the center console
  13. Yes, they said this is the first they've heard of it but they'll mention it to the regional rep. I was hoping someone elsewhere in the world (i.e. this group) would know more. Also, if Porsche doesn't know about the problem... how do we get this information to the right people? I just purchased an 06 left over and I have the exact same issue with MP3 CDs. Random turns itself off, and when I put Random back on, I get the same songs over and over again. Did you ever find a solution? maybe its a software issue? update?
  14. you should have one by default in the rear center console
  15. Yep, I have an 2003 Cayenne, apparently its always been an option since then. anyone have any pics of this setup??????????? i have the full sport kit the front spoiler is silver and body paiint not real aluminum pics to follow TODAY!
  16. Hi All anyone do any rear camera installs? Looking for the nav mod and the rear camera...i would like the oem camera but i am unaware of cost. Any ideas are much appreciated. Thanks Marco
  17. Anyone buy a Silver Crest for the front bumper? I have and it doesnt fit the gasket from the OEM crest...as well as the wholes are slightly off.
  18. Any thoughts or objections to adding aftermarket mirror http://cgi.ebay.com/ebaymotors/ws/eBayISAP...hlink:middle:us Would that work..I was thinking about removing the post of the mirror and install new one to the ball socket. Marco
  19. You probably have to buy nwe mirrors....Just swap the mirrors on the loaner :) Seriously what you probably need is Rear / Lower bracket with cut out of 06 Mirror Wiring Harness Light Assembly
  20. I just got a pair of sports exhaust tips myself, and I was wondering whether you had to remove the rear bumper to install the ring clamp? Only remove clamp no bumper...REQUIRED TURBO VALENCE PIECE OF CAKE TO INSTALL
