993GT2
Everything posted by 993GT2
  1. Battery is OK, ground points are fine. Any other hint?
  2. Loren, There are several fault codes as per below: U0155 lost communication with instriment cluster control module P1613 lost communication with gateway "a" P0503 vehicle speed sensor "A" intermittent/erratic/high P1610 air conditioning control module, no communication P 1614 steering angle sensor control module, no communication U0114 lost conmmunication with 4 wheel drive clutch control module P0000 unkown fault code U0129 lost communication with brake system control module P1606 communication ASR control module U0103 lost communication with gearshift module Thanks in advance, Sergio
  3. On a 2008 Cayenne I have an 'Ignition Fault Lock', the key turns, all the lghts are on but no start. As per the PIWIS it relates several faults, but one caught my attention: Tiptronic module fault. On the PIWIS I cannot access the Tiprtonic module, any hints?? Thanks in advance, Sergio
  4. On a '96 993TT, I am having no boost reading in the dash, although the car has full boost pressure. I have changed the pressure transmitter with no luck. The car has a flashed DME by Fabspeed. Any thoughts would be appreciated. Thanks in advance. Regards, Sergio
  5. On a 2006 997.1 C4S, the passenger door doesn't work, the window switchs are not working, the door cannot be open from the inside nor the outside, even the outside mirror doesn't work. The car was not involved in any accident. Where is the DOOR CONTROL MODULE located for the passenger door? Is there a way to manually open the door? Thanks in advance, Sergio
  6. In a 2011 Cayenne V6 the engine is overheating whenever the AC is OFF, once the AC is turned on the fan starts and the temperature drops. Is there a 2 speed fan for this car? if so, where is the temperature bulb located? Thanks in advance and happy new year! Sergio
  7. On a 2006 997 4S, i'm having the following codes: 8034 8035 8036 Can somebody help? Thanks,
  8. On a 2006 Cayenne S, the engine starts fine, but I cannot get it out of Park, the gear knob doesn't move, I don't even hear the relay working. The car is in a undergound garage, is there a way to put it in neutral? Thanks in advance, Sergio
  9. Loren, I'm sure, I have got this codes as per Autologic and VDO diagnosis
  10. I'm having the following code on a 2009 997.2 Carrera Targa 4S PDK: P1026 Thanks in advance Sergio
  11. Thanks Loren !!! The air bag wire was interupted. Regards,
  12. In a 2007 997.1 GT3 I'am having the following code as per Durametric: 800B Driver's head airbag above upper limit Can someone give me a hint? Thanks in advance
  13. I am having the following errors as per Durametric: 8009 Driver's belt tensioner above upper limit 803A Passenger's belt tensioner below lower limit Does it sound like I have to change the seat belts? Thanks,
  14. Thanks Loren, you are always very helpful. Here is what I found: I have measured the fuel pressure and this is what I got, at start up 4 Bar, then at idle it goes down to 2 Bar, at about 4000 rpm it goes back to 4 bar. Do you think that my primary pump might be faulty? I have changed the pump relay and it did not changed anything. Once again, thanks,
  15. I have a 2004 Cayenne S that have the following codes per Durametric: P 2177 System off idle bank 1 P 2179 System off idle bank 2 Any hint of what it should be? Thanks in advance.
  16. 2004 Cayenne S, US Model
  17. Loren, Is this the one located at the back of the camshaft? (behind the engine) Thanks,
  18. I'm having this CEL code: P0349 - Camshaft Position Sensor A Circuit Bank 2 Does anyone have a clue of what it should be? Thanks in advance
  19. Actualy it was a very small front hit, but the roll over bars were deployed. Thanks Loren for the fast reply Best,
  20. Tha manual says to take the car to a Porsche workshop.
  21. I just bought a 2008 Carrera 4S Cabrio that was involved in a accident, unfortunately both front airbags were deployed and the roll over bars are extended, my questions are: What do I need to change in the SRS system to make it operational again besides the two airbags? How do I retract the roll over bars? Thanks in advance, Sergio
  22. I'm having the following codes on a 2004 Cayenne S: P0102 P0112 P2177 P2179 Can someone help with this? Thanks in advance.
