skymast
Everything posted by skymast
  1. make sure you by one specific to the C4!!!!!!!!!!!!
  2. Easy task + tight space + 90 degrees = PITA BTW, I tried not to lose the screws, but of course, managed to do so. Thx all.
  3. Hi - I am replacing the interior rear door panels on my 1999 996. Can someone send me the removal instructions? Much Appreciated!
  4. I can confirm that the Pilot Sports are loud!
  5. What is the correct way and appropriate tool to use to measure remaining brake pad and rotor thickness? TIA, Mark
  6. I just did it a few weeks ago. Very simple to do and Scouser has some great photos of the process.
  7. I saw these wheels a few years ago. Likely not true but the dealer in Houston said that they were porsche 'carrera cup' wheels and I did not pursue the point any further. If you get the part number from the inside of the wheel, you can do a google search and likely track down the manufacturer. Also, if you want to replace them, check ebay or www.wheelenhancement.com. M
  8. I looked around and ended up staying with the Mich PS. I think they are good tires. If you have specific driving requirements or if you are a tire person, then maybe the incremental difference from one tire to another will make a noticable difference. Otherwise the standard summer sports from the major manufactures will probably all be about the same.
  9. I am almost problem free at 50K miles. By the time the C4's came out many of the early build issues were resolved. Enjoy the ride! M
  10. Search this site. About a month ago a guy had all of these hosted and downloadable for free. Alternatatively, you can by the set on ebay in PDF format for about $40.
  11. thats a bad way to find out about the problem!
  12. Does anyone know if the MY 04 Carrera 5 spokes will fit on a MY 99 Carrera 4? TIA, Mark
  13. The OBC is an option and whether it was ordered or not, the computer was buit into the cluster. Its about $180 in parts. Well documented install instructions but it takes a few hours.
  14. Same on my 99 C4.
  15. There is a guy on this board that is hosting the 02 + tech manuals. I am not sure if that will help but there is one for electrical. That and some trial and error should od the trick! I would love to see some of the WIP pics....
  16. I dont have PCM. Can anyone else provide info? THx
  17. Hi - have a 99 C4, with the 490 Hi Fi Sound package. I was thinking about buying a (used) DSP system (option P49). A few questions: 1) is the in console DSP module the only part that this different or is there a seperate amp for the DSP? 2) Will this plug directly into my existing sound wiring? 3) If not, what is required? 3) Any other considerations? Thanks, Mark
  18. Quite a few people have done the side skirt only approach so I am surprised no one posted a picture. I dont have a picture but I have seen a few with only the side skirts. I think it looks OK It definitelly accentuates the 'middle' of the car and makes it look more substantial. If you like the side skirt look, then I think you will be happy with it w/ or w/o the aero front bumper.
  19. I go forward in life more educated. Thanks!
  20. So I dont go through life not knowing, what is the significance of the offset? TIA
  21. Holy Self Promotion -- I have the B&M for sale in the classifieds... new in box for $199, shipping included!
  22. I had the same problem jared mentioned. I took a short cut and taped the jumper down to the wiring harness and that solved the problem (I should have done that to begin with!)
