Dr. T
About Dr. T
Contact Methods
  • Website URL
    http://
  • ICQ
    Bothell, WA
    2003 Porsche 996TT
    2002 Honda S2000
    2001 Honda Odyssey
    1996 Suburban
Dr. T's Achievements
  1. A number of us have had this problem. Here's a link to an old thread on 6speed that addressed it. Sticking in gear Turned out the input shaft needed grease.
  2. I posted this up a while ago. Here's a link to the thread; Click here
  3. Replacing the motor mounts with the ones in the x-73 kit is very easy.....no need to drop the engine....takes less than 30min.
  4. Maybe the sensor in the reservoir got stuck for a time when the level was just below minimum during the bleed.
  5. Stephen at ImagineAuto posted instructions on his site. ImagineAuto Click on the "how to's/tips" and then on "BOV install" It's a tight job but not too difficult. Good luck :D AWE Tuning also has a pdf on the bailey's DV install AWE Tuning Click on "Bailey DV30 install" then choose the bottom "instructions" link -Glen
  6. High silicone is probably from the gasket sealer used at assembly.
  7. Don, Did the test tell you which metals were high? My guess is it was Molybdenum which is used as an assembly lube on all of the bearing surfaces thus leading to a rather high content of moly in the oil. Some manufacturers (such as Honda in the S2000) claim to use a special breakin oil that they recommend leaving in for the full breakin period (it is supposedly high in moly). I have never heard of Porsche doing this.
  8. Nice mod to open your garage door by flashing your high beams. I posted the pics and directions in a pcars album. Flash to pass garage door opener mod.
  9. Did they powdercoat the inside of the pipe that needs to slide over the tailpipe? It's a snug fit to begin with so that may be enough to cause your problem. Maybe take a dremel and grind out the coating in this area back down to the stainless. Good luck, what a pita!
  10. Do it! You won't regret it. -Glen
  11. These are the best jack stands I've found AC JAckstands -Glen
  12. Wardhog, Have you noticed the howling go away when you depress the clutch? If so it could be from the hydraulic system. Here's a recent post from 6speedonline Hydraulic noise Good luck, -Glen
  13. Driver's side is red, passenger side is blue. -Glen
  14. If you haven't changed the pollen filter since new you'll be amazed at how filthy it is. This is probably all it needs. -Glen
