garyc
Everything posted by garyc
  1. thanks, i just kept pressing the electric switch to move the seat and it seemed to click back in ! works fine again.
  2. after fixing my ignition problem ,thanx to this forum, i had to take drivers seat out, but when i put it back the back part of the seat is "floppy" the electric motor still seems to work but it aint moving the seat with it? any help would be appreciated.
  3. 1, when i put the key in it springs to the right as if to start by itself. 2,i cannot lock the car with the remote because it thinks the key is still in it. 3, the key is really tight now to put in. any help out there?
  4. its quite difficult to get one, could you tell me where the obd connector is on the boxster? just so i dont start puliing things to bits, cheers.
  5. thanx for your help, i have obdI and II.
  6. sorry, i have the obdII software and a laptop, i thought it was then just a case of getting a cable from car to laptop?
  7. where can i get one? thanks.
  8. The handle on the outside of the car is connected to the door lock mechanism via a short rod which is anchored to the lock by a sliding ring, this may have broken or come loose. Get the door panel off and have a feel above the lock, put the rod back into the sleeve and slide the ring up over it. Sounds tricky, but it is simply and can be done just by feel Glyn thanks glyn.
  9. the problem is when i lift the door handle to open the door the window goes down (like it should) but the door won't open, there is no click, i then have to open my paasenger door and i can then open it from the inside! weird. Anybody out there with an idea to solve my problem?
  10. mine have went grey in colour so i want to get them off to clean, thanx.
  11. right at the front of the dash, below the bottom of the windscreen, anybody know how to rempve the trim at that bit?
  12. lights, alarms, cig lighters, codes you name it!
  13. 1. i have 2 spare yellow wires, where do they go to? 2. the instructions talk about illumination wires, the only wires i can see are the traction control switck wires? 3. i ain't got a clue!!
  14. tried, but still not working, anybody out there who i can contact with a few questions?
  15. my cig lighter works, but the light that surrounds it doesn't, i changed the bulb and checked the fuses, still nothing, the new bulb i bought is a12v 1.5 amp is that the right one? the old one never had writing on it to see. cheers
  16. wait till summer, cheers.
  17. is it easy to check microswitch, cant really see anything there?
  18. C16 uk lux spec 030 sport type running gear 013 sport technick pack could anybody tell me what they actually mean? i need to find out what is factory and whats not.thanx in advance.
  19. light not working, bulb and wiring ok, how does it actually work? its really pissing me off, thanx in advance.
  20. my light doesn't work in the front luggage compartment, bulb ok, power ok, can anybody supply me with the electrical schematic drawings, i think it might be a relay but i haven't got a clue really.
  21. does it work? and how does it work? mine is at +7 whatever that means and still no difference.
