box986
Everything posted by box986
  1. if u can't get it let me know .
  2. anyone got any suggestion at all?
  3. not sure what cause this loose sound at the front by the fuel tank ,under the batteries tray,which is hard to reach and find out ,this is what i do ,jack the car up ,and strongly hold the wheel and shack it ,you will hear the dry noise rolling clunk ,clunk ,almost sound like a bolt is rolling back and forth,i don't think it's inside the fuel tank ,other wise you can't hear it in side the fuel tank ,i have remove the underneath cover can't see much ,no sure is anyone got the diagram to looked at ?very appreciate if someone can help .thank's
  4. found the problem ,it was the water drip pant got a small holes .
  5. just to remind those who have passenger back sit wet ,after washing the car ,guess what i found out the water drip pant (980.561.80603) black covering under the top got a few hole which u can't really see it until u remove the convertible top ,replace cost $65.00 1/2 hrs job ,my problem slove :D
  6. looking for how to remove water drip pant (980.561.80603)
  7. tool pant's i in a process of removing the floor carpet being the reason of the both wet floor ,i can't removed the floor carpet because of the hand break cable is blocking the way,any suggestion
  8. can any guru point out what cause the front passenger carpet wet ?i can't figure out why.i appreciate if someone can help .thank's :huh:
  9. this serve me very will ,old time flavour ,get a hot water and rinse the boxster logo for a few time and just will gently remove it ,that all need no tool for it .
  10. my batteries are not the original sizes it's smaller than the batteries box it wasn't start strong strong ,but it start nor ,but after install the ignition switch i got a feeling that it start differently ,like more power on the batteries ,instant quick start ,i can be wrong ,but it feel that way to me .exactly my mechanic told me usually 97 box have that problem ,because as soon as i ask him ,he point out that right away ,and told me how to change it ,for 7 year's old box that igination was last quiet good ,but i figure even that wasn't the problem is still wroth it ,again it's quiet easy to install it ,fun job .let me know how it goes on your's
  11. hi 98 boxster thank's for the part's no that u gave me for the ignation switch they were quiet suprised when i gave them the part's no ,otherwise they were trying to sell me the whole unit ,they still got them if u need them or who ever need them let me know ,apperiantly they were audi logo same as the original aswell suprised ,it take me longer than 5 minutes ,my time 10 minutes .
  12. tool pants thank's for the tip's ,didn't realize there is much more info that i thought after searching the DIY and search engine
  13. I need to change my fuel filter any suggestion how to?thank's
  14. put on the euro bulb ,man they sure looked good for a very little price to pay .
  15. thank's for the quick reply ,i will give it a try
  16. can any boxster owner recommender the front head light ,which type is good ,i just got the euro H-7 replacement bulb ,haven't put it in yet ,any suggestion
  17. what is the OBDLL codes mean?
  18. 98 boxster thank's for the quick reply ,do u have the ignition switch part no for it ?how hard was it to fix it yourself ?
  19. have anyone got the same problem like i have ,97 boxster i just got a few time that i can't start my car , that was a while back ,today it happen again it when complete no dash light. for a few time i start ,than the interior light came on and start again ,but this time the k/m turn to miles and the clock when off need to ajust again,and the wrost thing is one side of the light blow off just the running light is on ,and idea what is the problem ,when i got the car the batteries wasn't the original type ,was quiet a bit smaller compare to the original batt ,no sure that was the case ,also before i start the car i got the radio going for a may be an hour cause i was polish my car .thank's if someone can advise me . :(
  20. thank's for the tips tool pants i prefer to do it myself .is there any instruction that i can get it from ?thank's
  21. have anyone try the rear spoiler modified switch ,so that i got the control to get the real spoiler going up and down whenever i like ?or any suggestion ?i see a site saying that they can get the spoiler retract up and down at the speed of 25mph .
  22. will the H&R 7mm in the front and the 17mm in the back will work okay ?what about the bolt ?
  23. thank's for the info ptec ,i will give it a try
  24. hello! anyone help me .thank's
  25. what should i do ,i am only trying to remove the driver sit just for cleaning,and i am afraid to remove it ,because there is a connector under the sit ,should i be disconnect the batteries first?before i remove anything at all ?
