Duster
About Duster
    San Jose, CA
    2000 Boxster
    1998 4Runner (TRD Supercharger & Catback Exhaust)
    1966 Mustang
1,418 profile views
Duster's Achievements
  1. I have a write up on how to install a backup camera on a 986 too.
  2. Wiring diagram from Crutchfield for the Boxster.
  3. Did you use a wiring harness such as this one? CRUTCHFIELD REVEIVER WIRING ADAPTER.PDF
  4. What year is your Boxster and what stock Porsche radio model number was in your car? Trying to determine if you had a Bose (fiber optic) or non-Bose audio system
  5. There is no ps fluid filter in a 986. I have not heard anyone installing a filter either. I’ve done a PS fluid flush by disconnecting the return line underneath the driver side of the car and there is a wire cage.
  6. Try an old farmers trick by soaking cotton balls with peppermint oil. I do this all the time with my Porsche when I store it away for the winter. I’ve never had a mice or rat problem with my car.
  7. Thanks Topless. I currently have the Base M030 rear sway bar and stock base front sway bar now. I like having my Boxster more neutral to oversteer for Autocrossing. I'm planning to sell the M030 front swaybars and that's why I needed the information.
  8. Yes. Scroll down your CB Racing link. All the dimensions are there:) http://www.cb-racing...oxster_030.html Yes, I did look there already. However these part numbers are not listed: 996-343-701-21 996-343-701-23 The part numbers above may supercide the older listed number on CB's website. Please advise....
  9. Does anyone know the differences between these M030 Front Sway bar part numbers, in terms of diameter and thickness size, along with stiffness: 996-343-701-21 996-343-701-23 http://www.cb-racing...oxster_030.html http://www.pelicanparts.com/catalog/shopcart/986M/POR_986M_SUSshk_pg3.htm#item23 I've used the above websites and could not find the part numbers with corresponding diameter, thickness and stiffness. Any help would be appreciated!
  10. Does anyone know the differences between these M030 Front Sway bar part numbers, in terms of diameter and thickness size, along with stiffness: 996-343-701-21 996-343-701-23 http://www.cb-racing.com/boxster_030.html I was using the above website and could not find these part numbers with corresponding diameter, thickness and stiffness.
  11. It does vary somewhat from car to car but -1.5 deg. front, and - 2.0 deg rear are pretty typical. Bent cars are anybody's guess. Thanks for the information. I'm currently using front camber plates with -1.5 deg and -2.0 deg rear. This set-up has been great with Dunlap Star Spec tires for Autocrossing, where I'm getting good tire wear. The problem is the noise upfront with the top of shock hitting inside the top of shock well on rough roads. The Boxster was set-up with me inside the car and I weight about 140 lbs with 1/4 tank of gas and stock battery. I'm just wondering, if I would be able to get 1.5 deg with the ROW M030 with me inside and fuel load?
  12. Does anyone know how much negative camber you can get on the front and rear using the ROW M030?
  13. Check out this website: http://shop.wheelsrims.net/porsche-boxster-inventory.html This where I bought my Porsche OEM Carrera Light 5 spoke wheel for the Boxster at a very low price of $265.00. The catch is they are refurbished, but have a lifetime warranty (Whatever that might mean). The Porsche wheel I bought was the real thing, because it did have have Porsche part number stamped on the back of the wheel. I would give them a call and ask them if they have the Porsche wheel in stock and if they will ship out to China.
  14. When I replaced my Catalytic converters with bypass pipes on my 2000 Boxster 2.7, the bolts are wedged into 3-bolt triangular connection. I sprayed PB Blaster pentrating oil on both sides of the bolts and let it soak for a couple hours to loosen the bolts. Then I used a mini-sledge hammer to pound out the bolts. However on the stubborn bolts, I heated the bolts with a propane torch and used the mini-slege hammer to pound out the bolts from the 3-bolt triangular connection. I tried a regular hammer first, but it didn't have the weight behind it to pound out the bolts. Unfortunately I had to make a couple trips to Home Depot to buy the mini-sledge hammer and then the propane torch. 1. I would recommend soaking the bolts with either WD40 or PB Blaster pentrating oil for a couple hours. 2. Heat the bolts with the propane torch 3. Use a mini-sledge hammer to pound the bolts out. *** Wear mechanic gloves to protect yourself from the heated bolts (propane torch) and scrapes from the exhaust system.
