Okbye2
Everything posted by Okbye2
  1. What do you guys think. Thinking of selling my 2002 boxter for a cayenne turbo. Should I do it? Is this a good car? Anything I should watch out for? Any year that wasnt a good one? Thanks in advance... Ps. Whats a good website for upgrades for this car?
  2. Nah, Not really a waste of money. Atleast it improved my lighting and visability. Plus im not blinding other drivers as I live in Miami and get a :censored: load of traffic daily. Im sure im bound to run into someone who will flash at me to turn off my lights but, not one yet. I've also driven with other people who have been in front of me and everything is ok. No blinding. Conclusion.....dont believe everything you read unless you have tried it yourself. I dont mean to be rude either.
  3. I bought it off ebay. JDM 8000k kit for about $280. Beats the heak out of those yellow bulbs it had! Took me about one hour to install taking my time to make sure i did everything right. Thanks Hey there, How's the brightness on these? I am considering getting these for my Boxster. I currently use the fake bulbs off of ebay, not too bright :/ Thanks, mike Brightness is alot better than stock and 10 times better than the fake bulbs. I once tried those bulbs and you cant even compare to these hid conversion kit. Im sure that the litronics original kits are better but these aren't too far behind.
  4. Ive noticed that when I start it in the morning It runs a little less then it should. Give it 30 seconds for it to warm up a bit at it runs awesome in the cold. Maybe some type of saftey mechanism so you dont rev it up when the engine is cold and oil has not circulated. My acura had that mechanism which it shut down the Vtech until it warmed up. Not that it has anything to do with this but its just a thought.
  5. I would like to add to this post that after making it a routine on only putting 93 Octane ive been having less smoke at start ups. Meaning, before it used to smoke only at start up atleast 2 times a week. now its been only about 1 time for every 2-3 weeks. :clapping: Just thought i should share with you guys.
  6. I also did an hid conversion. No lens burn out yet. Ive had them on for about 5 months or more. good luck
  7. Will these work? fgr6kqc
  8. Hi guys. Im sure you've seen this many times. Ive done my search but found many different answers. :help: Basically which spark plugs should we use. Ive got a 2002 Boxster 2.7 Which Bosch and which Beru model numbers are they? If anyone has a site where I can get them cheap I would appreciate it too. ;) Thanks
  9. I had a similar problem with the ignition switch. The lights would not work or the a/c because the switch wouldnt come back to the normal position after crancking the engine. Dealer changed it now everything works. thanks warranty! :beer: <{POST_SNAPBACK}>
  10. Thanks Loren
  11. Slight problem with my ignition. I turn the key to start the engine. for some reson the key does not click back all they to the normal (after start) position. so the engine is running but the lights on the dash stay on and the a/c wont turn on. When I manually turn it just a bit (5mm)conter clockwise, the lights turn off and the a/c turns on (how its supposed to be). You guys think a little wd-40 will do the job? Any thoughts? :help: Thx
  12. It looks fine. If some sees it and they dont like it f*ck it, who cares. You will not see them again anyway! or are going to start putting stuff that other people like on your car? <_<
  13. Yeap, I had mine change recently by the dealer. cost me $0.00 gotta love the warranty. mines a 2002
  14. Ive seen them for sale on ebay
  15. Is this vibration you are talking about at 3500 rpm?
  16. Im not a expert on this but, on past experience on another car, my sycro's went bad, in this case your 1st - 2nd syncro might be bad. That cause my gears to pop out of gear when accelerating....
  17. Honestly... it must have been minimal to even notice. The mechanic at the dealer noticed it while he had it on the lift (im guessing) i was lucky that they told me that it was leaking and they changed it. if you dont have any stains on your drive way then i wouldnt worry.... do you still have warranty? if so then you should take advantage and take it in. I was really surprised on how honest they were. They changed also both of my window motors even though I had a problem with only one of them. Since they changed the rear main seal I also got a free oil change out of this one. :beer: <{POST_SNAPBACK}> <{POST_SNAPBACK}> I took it to "The Collection" here in Miami. Good service but they took a long time...about 1 week
  18. Would you guys have the diagram or instructions on how to do this little project? (Taking the top down while driving slowly of course) Thanks
  19. Honestly... it must have been minimal to even notice. The mechanic at the dealer noticed it while he had it on the lift (im guessing) i was lucky that they told me that it was leaking and they changed it. if you dont have any stains on your drive way then i wouldnt worry.... do you still have warranty? if so then you should take advantage and take it in. I was really surprised on how honest they were. They changed also both of my window motors even though I had a problem with only one of them. Since they changed the rear main seal I also got a free oil change out of this one. :beer:
  20. Im thinking you should. They told me they saw it was leaking. its got to drip somewhere...
  21. I called the dealer today and they replaced the rear main seal anyway. dont ask me why along with an exhaust manifold(had a leak). Along with that they are changing the oil seperator. Thank god this is all under warranty! :clapping:
  22. Anyone know if you can bring down the windows using the remote. I saw someone mention this before but it didnt show how. :huh: Thanks
  23. 2002 Boxster 2.7 What are some things I should have changed or looked at before my warranty is expired. "Common defects" I think is what Im trying to say. I just don't want it to expire and then something finally breaks when I could of looked at it first and applied it to the warranty! Today I dropped it off anyway and they are changing the oil seal separator, window regulator, and something in the exhaust that is making a noise. Any suggestions on things I should look at that always break on these cars? Thanks
