lswjth2
    2000 boxster 2
    2001 grand cherokee
    1990 f 250 diesel
    1971 ford bronco
lswjth2's Achievements
  1. Thank you all for your help. I will let you know how it goes.....Thxs
  2. Thank you all for helping out a newbie.......I will let you know how it turns out...
  3. Hi all, newbie here. We have an 00 Boxster S, we rarely drive the car, it's garage kept with 55k miles on it, second owner. The other day i went to start the car and it had a bad odor inside, turned the ac on and pieces of black/grayish foam starting coming out of all the ac ducts and the ac does not cool. Any ideas where this maybe from? I would think it's some kind of a gasket but from where??? Is this a common problem?? Any help is greatly appreciated...Thank you
  4. Hello. I did this myself. NO big deal. Just make sure you scribe the bolts on the bottom of the door that hold the glass. Here's the link I used....Good Luck http://www.bombaydigital.com/boxster/projects/window/
  5. Thxs for the info...
  6. Hello. Is :drive: there an RPM limiter on the 2000 S? If so at what RPM is it supposed to kick in? I found myself the other day @ 7500 RPM. I thought it was only supposed to go to 6800?? Is this Normal? This is my first porsche...Thank you all for your help
