NISTISHIN
Everything posted by NISTISHIN
  1. search sonnen porsche in california.... they have best prices on OEM...or try EBay. Good luck!
  2. Hi 2000 Boxster top is suddenly stuck in down position. I see I can manually get the top back up from the owners manual. What occured was the "red" light would not go off when the top was completely in stored/down position for a couple days. Then it happened...top went down & would not go back up. When it trys to go up only some movement from driver side occurs. The passenger dosen't move & then the motor cuts out. Does this seem like the passenger side cable or transmission issue? Or do you think the micro switch is the problem (since the light on dash would not go out when completely stored)? Your thoughts are appreciated. When i get in there to look at the mechanics of the top what should i be checking for?
  3. im not sure where Placerville is....is it california?
  4. search where...can you point or link me to it? thanks
  5. Can some one upload an owners manual for 2000 Boxster in English....one posted is in french...its great but i dont speak/read french....thanks for any assistance...
  6. I would like to add to this stall topic & wondering if any one has this problem. When the gas tank get filled at the gas pump....the car will not start afterward. I do get it started but I have to fully press down the gas pedal and hold it.....crank the engine & then it catches and starts... runs rough but runs fine after a few minutes...(like 5 to 10 minutes). I assume its a vapor lock....but how can I permanently fix this from happening? Happens on every fill up
  7. the first code 5257 worked for my radio...thanks
  8. 2000 Boxster Radio code needed: CR-220 Becker 1 Serial# X5018785 Type 4362 47/98 Can you assist with code?
  9. Ok I cleared the "WAIT" per your instructions. Thanks Radio is CR-220 Type 4362 Serial # X5018785 2000 Bosxster 2.7 I haven't retried to input any codes yet. Do you have potential codes to try?
  10. ok thanks I will try the igition on for (1 hour) tonight...& attempt some codes. do I go with 9398, 9396 or 1011, 1013...
  11. I purchased a 2000 Boxster a month ago. The battery ended dying since sitting in the gargage. I charged the battery & everything is fine. Now the radio needed a radio code. My 6 yr old daugther though she could randomly put in numbers & guess the code. Wrong. Now the radio says "WAIT". What do I have to do to clear the "WAIT"? Once it clears, what is the radio code? I picked up from bloggers a radio code of 9398 or 9396. Can anyone confirm that? But I can't enter them since I can't get rid of the "WAIT". Can anyone post a 2000 boxster owners manual, last I checked there was a 2003 boxster manual...which im sure many things are the same.
