97 Boxster
    97 Boxster 5sp Guards Red/Beige
    06 Hummer Victory Red
    08 Yamaha Wr 250x BLACK
97 Boxster's Achievements
  1. I left a message for him. Thanks
  2. Roger, I am in Texas as well. I live in Houston. Where are you at? I would be happy to go with a local parts supplier if I can "purchase local" I will but this part seems to be eluding me.
  3. Thanks to all. I will look into ordering the correct part. Any suggestions on suppliers for these?
  4. LEFT = Drivers Side DOOR Correct?? Those part numbers are for LHD cars - so yes left side door. Also, these numbers are for MY1997 w/o M535 So if I need the Drivers side lock mechanism I need part # 3B1 837 015 E
  5. LEFT = Drivers Side DOOR Correct??
  6. I have a 97 Boxster W/O Airbags and I need the door lock mechanism. There seems to be 2 part #'s for this so I want to know if somebody can confirm the 2 part #'s for me so I can be sure to order the right one. I have seen 2 separate sites say "just order it and we will send you the right one" and I am not comfortable with that. PLEASE HELP.
  7. Try 9682 or 9680 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Neither code worked. When my "CODE" shows up on the display I just need to input the #'s correctly then it should start working or do I have to press a button after the 4 digit code to "enter" it?? Did you read the FAQ? I tried 9682 and it worked. Had to enter code then press "up" on the tuner button. Thanks for your help.
  8. Try 9682 or 9680 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Neither code worked. When my "CODE" shows up on the display I just need to input the #'s correctly then it should start working or do I have to press a button after the 4 digit code to "enter" it??
  9. Here we go 97 Boxster 5 spd V5009402 R2896 CDR-210 Thanks in advance.
