manxman
    Other
    1958 356A Super Coupe (Euro spec)
    1976 912E Sunroof Coupe
    1997 Boxster
    too many to state 25 Porsches.....
manxman's Achievements
  1. Sorry guys it was P 0160! My currently running codes are as follows: P1121~heating of pre cat cyl 4~6, P0160~ post cat 02 sensor cyl 4~6, P1115~pre cat 02 sensor heating cyl 1~3, P1119~pre cat 02 sensor cyl 4~6, P1117~pre cat 02 sensor cyl 1~3 This AFTER changing out ALL four 02 sensors! Yikes!
  2. Thanks for the input! I did NOT spray anything on the electrical connector ends, just snapped them in place (boy is that a chore on the rear two, any easy way to get to them?) But when you say reconnecting them do you do it with the key on or off? I'm assuming you mean off? Just disconnect the snap part an reconnect it? The codes I got AFTER I put them in were: P1121~heating of pre cat cyl 4~6, P0160~ post cat 02 sensor cyl 4~6, P1115~pre cat 02 sensor heating cyl 1~3, P1119~pre cat 02 sensor cyl 4~6, P1117~pre cat 02 sensor cyl 1~3
  3. Recently I got this code (P060) and can't find it in the Workshop Manual? Anyone get this code or know what it is?
  4. Recently I bought a 97 Boxster with 98,000 on the Odo. The car ran fine but I had a engine check light on. I bought a meter to check and erase the codes and it read 02 sensors with 3 variations of potential problems. I opted to change out ALL 4 02 sensors and bought the kind with the correct ends and replaced the units. I'm STILL getting an engine check light and 02 codes after clearing the codes! Any suggestions?
