mphart
Everything posted by mphart
  1. Got it working. I tapped into wrong black/white wire. As mentioned there is another wire that looks black/white in addition to the larger black/white. That was my problem. Works great and very cool. Thanks for write up and help!
  2. I tried this tonight and got the left side done but it's not working as expected. When I have the headlights on I get no side marker on the left side, the right (unchanged) is still working. Likewise the turn signal does not flash the left side. I did note that when I engage the left side parking lamps it does illuminate so it seems to be working but not combined with the right side. Is it possible that the modification needs to be completed on both sides for the modification to work? I followed the directions and tapped into the smaller white/black wire. Any help would be appreciated. Thanks, Mike 2001 911
  3. It can happen..I am on number 4. I have only replaced the switch in lieu of the entire mechanism that is supposedly the fix. I will do it the proper way next time Interesting, I think only one part of the switch on mine was replaced (two times now). The dealer implied it might be driver error suggesting the clutch might not have been fully depressed. That isn't the case and in looking at the assembly it appears to me the switch is under the dash and contact is lost with the pedal being depresses only an inch or so. The dealer said the switch is on the firewall and the pedal would have to go all the way. That doesn't seem to be the case per my visual inspection. Can anyone confirm for me?
  4. I have the same problem. Took it to the dealer in February and they replaced the ignition switch but it still has same intermittent problem. Took back to the dealer today and they again replaced the ignition switch. I'm skeptical that I've had two bad ignition switches but I guess I'll see it the problem persists.
