ttreat
    NEPA
    2009 997.2 C2S Carrara White
    91 Toyota MR2 Turbo
ttreat's Achievements
  1. I finally got my LCD repaired and it works great thanks to Andy at VDOrepair. Here are some tips and lessons. I bought a bad instrument cluster with a good tach LCD screen from a dismantler thinking I could switch it myself if it were a pin connection. I took apart the bad cluster and saw that there was a ribbon connecting the LCD to the circuit board directly. I pulled on it gently and it came off easily. BIG MISTAKE! I later found that these are thermally bonded and if they are not pulled off with heat applied, there will be damage to the contacts on the ribbon. For anybody thinking of doing this, I was told that it just takes a heat gun or hair dryer and it will come off easily with no damage. Once I had the LCD panel off I shipped it off with my car's cluster. They were able to replace the old ribbon with a new one and it works great so far with no crazing. This was much less expensive than replacing the cluster with another used one and I was able to keep the original cluster in the car.
  2. I have started that as well. I will make some calls on Monday to dismantlers.
  3. Loren, do you know if the '01 Boxster LCD panel will work?
  4. vpcar, my LCD screen is a little different so unfortunately I don't think it will work. Thanks for the offer though.
  5. Does anybody know if there are differences in the instrument cluster tach LCD panels? What years would be compatable with an '01 cluster. I know there are differences in the clusters from a tip, manual, C2 or C4 but are the LCD panels really different? The LCD panel just displays the digital speed and computer information (avg mpg, temperature, etc.) My LCD panel has some crazing and I was told that nobody makes these panels but you could replace the panel from another instrument cluster. I would like to find a donor panel from a bad cluster and try to replace just the LCD panel. If anyone has a bad cluster I may be interested in buying it.
