martadon
Everything posted by martadon
  1. I had to do this to both sides of my 2004 Cayenne Turbo. Before, it would throw errors and have intermittent failing lights, mostly turn signals. Afterward, not a single problem. It should not be a tight fit, however. The short harness allows a fair amount of room to fully seat those connectors before sliding the assembly back in the rails and locking them down. I agree that the design is lacking!
  2. I believe that is your evaporative canister that captures fuel fumes.
  3. Oh how I hate TPMS. More trouble than benefit, IMO. Who didn't check their tires monthly anyway?
  4. 2004 CTT w/smoked rear LED lights and 22's. My beater to accompany the 2007 Carrera S Cabrio.
  5. Here's one solution: http://www.atbs.com.tw/product_TPMS_Module_E.htm no matter what system you get you have to have transmitters and the receiver. The iPhone App is free.
  6. Hello. Had moisture issues (cracked lens) and intermittent failures from it. Got the smoked LED assemblies for the rear. Perfect. Direct replacement and a joy. Under $500 from a Left Coast seller. Do it. 2004 Cayenne Turbo.
  7. My owner's manual says a D1 "low temperature" start-off relates to engine temperature rather than ambient temperature. Mine is always that way as well.
  8. I have a 2004 Cayenne Turbo. The VIN should look like -- WP1AC29P04LA9xxxx.
  9. If you really like them, get 4 rears and 2 fronts. That way you'll be covered for a while when they go away. I personally couldn't stand them on my car. Functionally fine but the noisiest high performance tire ever, in my experience. Couldn't wear 'em out fast enough to get rid of them. Michelin or Bridgestone much nicer for me.
  10. And you know this because of your current or former employment with Porsche or a tire manufacturer supplying N rated tires? Just curious. This is from a very credible source: "...This N-rating isn’t free. It comes at a price. All of that development and testing costs the tire manufacturers and Porsche a penny or two. For instance, one of the most popular tires for a newer Porsche is the new Michelin Pilot Super Sport (Max Performance Summer) 265/35/ZR19 N0. It can be purchased from TireRack.com for $419.00 each. The same tire, without the N0-rating but with the exact same specs is offered by TireRack.com for $297.00 each...." http://www.pedrosgarage.com/Site_5/For_the_Nth_time.html You want only N-rated, fine. You don't feel you need to pay the premium for N-rated, fine. And as was previously noted, if your re-shoeing a Cayenne, don't think you're dealing with a GT3.
  11. I've got WINRUN 285/35x22s KF997 106W on my 2004 CTT. Wear rating is 400. Relatively new but quiet and smooth. $498.00
  12. Had to re-glue mine, too. Used Gorilla Glue and a brace to press it tight as the glue set. Just find something that will fit very snugly from the passenger rear seat to the back of the passenger front seat, without damaging the passenger seat, of course! Worked fine and is holding well now after 6 months.
  13. Good luck. The link I posted describes the issue with the LCD display. Whether it's lines dropping or a dimming issue doesn't matter. Check further. It's the connection. Oh, i have an instrument cluster from a 2004 model. LCD has no issues. PM me if you want to talk about it. I've changed my cluster out with zero issues.
  14. Google is your friend http://www.audi-sport.net/xf/threads/east-fix-for-fading-lcd-on-instrument-panel.44714/ Explains why this happens. Fix it? How bold are you!
  15. You're not wearing polarized sunglasses, are you??? Because that's exactly what happens if you do.
  16. Yes. i was looking at the instrument cluster in the original photo in this thread which shows a Turbo cluster. Thought that was yours. I have a Turbo which has the HID headlamps as shown in the diagram I posted. If you have the standard headlamp system I'm not sure what your cornering lamps are. HID units have 5 bulbs and standard units have only 4 bulbs.
  17. You have a Turbo so you have HID lights. The diagram above is incorrect for your car. Here's the correct diagram--http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=9PA-03-06&section=905-01 Item 5 is the cornering light. just a basic H3 halogen.
  18. http://www.tpmsbuyer.com/Porsche_TPMS_Sensors_s/1701.htm
  19. My 2004 CTT had the same leak. Thought it was the hose. Nope, dealer washed it down, drove around and discovered that it was valve cover gasket and the leaking oil just happened to collect there. replaced gasket -- no more leaks.
  20. Just did this with my 2004 Turbo. Just want to say that you don't need to hammer in the center locking posts. They'll push in with moderate pressure. Just use anything that's bigger than they are. They're about 1/8 inch diameter. I used the tip of a pair of small pliers. Works fine!
  21. Absolutely. Since the metal valve stems w/metal caps are the transmission antennae of the TPMS sensors, I suspect that removing the metal caps from the aftermarket sensors changed the radio frequency (RF) characteristics of the stems (antennae) so that the aftermarket sensors became more compatible with the receiving end of the business. Just my theory--as an old, 30-year retired USAF radio and radar guy. ;)
  22. My mechanic @ the dealer said he couldn't code it to my car and then put the old "S" cluster back in. I asked my Service Mgr "Well, did anything work on it?" He didn't know so he had the mechanic put the Turbo cluster BACK into my car and fired it up. It worked perfectly with full functionality! Go figure. Also, if you read a few posts earlier here, you'll see the issue of "RB4" and "RB8" incompatibility. The "S" cluster I took out was "RB4" and the Turbo cluster that went in is "RB8" I have no idea--it just works fine. As for mileage, I sent the Turbo cluster to ODO-PRO.COM in Colorado and they programmed the cluster to reflect my mileage. Thet say they can hit it +/- 300 miles. They did. Eighty bucks, one day turn around. Do remember, though, that my car IS a Turbo. I got the car with the "S" cluster installed. I have no idea why or when that occurred. Good Luck!
  23. Well, this applies to all Porsches w/TPMS, I suppose. I had to replace all four TPMS sensors last year (dead battery on 2 of them) and got some aftermarket sensors at less than half OEM cost. Subsequently, my TPMS system would intermittently loose the sensor signal and go into Learning mode on its own. Worked well--didn't work well, randomly. My Porsche mechanic said he never had good experiences with aftermarket TPMS sensors so there was nothing he could do as my TPMS system wasn't at fault. After living with this for months and months I had an idea. I removed the aluminum (I think) stem caps and put cheap, green plastic ones on (N2 filled tires) and tested the TPMS for the past 2 months. Long story short, everything is fine! No intermittent re-learning and the system picks up all four signals even when the car is at rest. So, if anyone has experienced similar anomalies I suggest similar action and see if it works for you. 2007 Carrera S Cabrio
