Italianbeauty
Everything posted by Italianbeauty
  1. Thank you sir!
  2. Not the correct website. It's "sports" news website.
  3. Hey guys! Just replaced my deck lid with Misha GT2 lid. Does anybody know where I can get a euro third brake light (clear) for this GT2 lid? Thanks all!
  4. Where can I get a decent price on an aftermarket GT2 deck lid? Any leads would be appreciated. Thanks.
  5. Thank you for the link. I've finished installing the bearing on one side of the car with the red/orange seal towards the outside of the car. I wonder if this will present any future problems? I'd have to do more research before I continue.......Thanks again!
  6. Removing stock springs and installing H&R lowering springs. Do I need to re-valve the front struts before installing the front lowering springs? Thanks.
  7. Thank you for the reply. You've been a great help.
  8. Thanks for the info. My car is a 2001 TT. This is the type of ABS Sensor I have in my car.
  9. Hey all! Need your assistance on bearing installation. I removed the carriage following the DIY posted by DASBoost, however, looking at the photos, not sure which way bearing should be installed. The photo from DASBoost shows the black side of the bearing facing the inward, but my carriage shows the "orange/rubber" part of the bearing facing inward. Which part of the bearing should face inward? Or does it matter? I took it to a couple of Porsche independent shops and had 2 different answers.
  10. After moving the steering wheel back & forth a few times, I was able to get the ignition switch to work. Thank you all for the help!
  11. Hey guys. I need your help with my ignition switch. I have a 2001 996TT, searched this forum regarding ignition switch replacement. I was able to acquire the same exact switch and replaced it myself. After installing the new switch and connecting the battery cables, I insert the key and will not turn. Seems like it's stuck in "0" position and will not turn at all. Any help is much appreciated. Thank you.
