almeida944s2
About almeida944s2
  • Birthday 08/21/1974
    Naugatuck, Connecticut, USA
    1999 Carrera
    1990 944 S2
733 profile views
almeida944s2's Achievements
  1. Hi, does anyone have a DIY, hopefully with some pictures, on the proper placement of the brake pads anti vibration shims? I cannot find any information for the 2009’s online. I have the brake system where the calipers have to be unbolted, not the rod and cotter pin system. Any information would be app.
  2. Has anyone ever had an issue where the tiptronic whines when its put into reverse? It does not show fault code when I scan the computer, nor does it drive strange. I don't know if servicing the tip will help. I checked with my local dealer and they have never heard of such an issue. the car has 45,000 miles. Any help I would appreciate.
  3. I have bluetooth in my cab. I don't bother using it with the top down because no can hear what I am saying, too much wind noise on their end.
  4. Hi Loren, I was just reading this and I have a question, is the wire I need to tape off in the radio harness or is it on the side of the radio cage, or do you know the color of the wire by any chance?
  5. I have searched over and over and can't find a write up on how to clean the MAF sensor. Is it as simple as removing and spraying with electronic cleaner?
  6. Thanks Loren for the quick reply.
  7. Hello, I have a 1999 C2 Cabrio tiptronic. I was wondering if there is any way to check the Trans fluid.
  8. I have a question if anyone can help. When I put the car into reverse, I hear a whining noise, When I put it into drive, it goes away. Is this normal? Could it be that I may be low on tranny fluid? My car is a 1999
  9. That is a good DIY, the question I have is the lever replaced with a new one or was it repainted? If it was repainted, was the picture of the hood just covered and the rest repainted? Mine are worn almost the same way and I would like to do the same. Thanks.
  10. Hello, I have a question for anyone who knows. I have a 99 C2 cabrio that did not come with a owners manual, and I have tried searching but can not find the answer to my question. Normally when I turn the key to start the car, the countdown starts from 5 seconds to zero, but sometimes when I am out and have to make a stop somewhere, I get back into the car , turn the key, and it starts from anywhere from 7 minutes to 15 minutes. Am I suppost to wait no matter how long it takes or is it ok if I wait a little while, just not the several minutes? Like I said I tried to search this here but can't find any answers as to how I should handle it. Thanks
  11. Thank you Loren, This looks like it will be a big help.
  12. Can someone please help me find a DIY (perhaps with pictures) for changing the drivers side window regulator on my 1999 carrera? I have tried searching myself and cant find just a DIY. I know there are alot of posts about this, just cant find what I am looking for. Thanks
  13. Does anyone know if there is a way to tighten the cabriolet top down when it is closed. Mine makes alot of noise while driving and I didn't know if this is possible. Tried doing searches and could not find anything on this. 1999 996 Cabriolet. Thanks
