ahn
Everything posted by ahn
  1. Factory specs are 29(psi) front, 36(psi) rear...
  2. there is no gaps. It is very synchronized with car.
  3. It is very easy to fit. Just remove four 8 mm nuts and the light is out. in my case, the backup light is not bright than oem. the other are very satisfied.
  4. I did LED tail light. look at my picture, personally I like it. more aggressive look.
  5. thanks your answer. then, the solution is to purchase aftermarket tunning kit.
  6. I have 2003 boxsterS and live in Korea. no data about tunning was here. I knew 987 has 280HP because of large air intake, ecu, manifold and exhaust. 986 and 987 are same engines. is it possible to retrofit 987's maniford,cats, and exhaust on 986? 986 and 987 are not same frame ,therefore I am half in doubt.
  7. thanks a lot good source was here! I download now and read all carefully.
  8. because I am newbie and not good English, I didn't write the details. once I write and read, it takes about 1 hour and more. I hope your comprehension, thanks.
  9. thanks Mr. turro To Mr. LVDell, Mr. Tool Pants I have manual but it was written in Deuch language. In my country english manual and Korean manual only give who buy Korean dealer shop. I buy my car grey importer, then he gave me Deuch manual. I am not good English. and don't know Deuch language. therefore HERE is my olny help place. If you don't want answer my question. then ignore my question and don't mention my question. thanks.
  10. hello^^ this forum give me a lot of help, thanks. my question is how operate headlight washer? Is it same method operate front glass washer? thanks
  11. thanks your help^^
  12. :eek: Hello everybody ! This is my first post here, I have been told it is a good place for technical advice. my car is boxsterS 2003 year. I purchased new LED rear lamp set in ebay. and I want to change new one myself. Is it possible to install myself? and not difficult? :drive: Thanks for any help^^
  13. mine is 2003S it works great very comfortable and easy to install.
