aviator at elstree
Everything posted by aviator at elstree
  1. Hi I have exactly the same problem I get no more then 20 mpg driving carefully This has been going on over 5 months I had rough running, changed the MAF sensor which cured the rough running, then someone sugested it may be faulty so I changed it again Then it failed an emmisions test so I changed the Lambda Sensors. It passed. I have had it read by a Porsche agent and there are no codes I am at a loss as to what to do next Dave
  2. Fantastic thanks I never knew that, I thought that only did the trip milage - Doooooh ! All sorted now, thanks again
  3. Hi N41EF just mentioned the Dimmer ? My panellights are too dimm Can this be adjusted ?
  4. Not being rude I was never talking about the box under the seat, you did not read my post properly I clearly said the alarm in the front, under the hood, the red one with the siren I will get a second hand one and plug it in Thanks
  5. Well I am not, please read my post correctly The Siren -the red one -under the front hood - sealed and certainly very dry it goes off on its own and does not stop even with the fob pressed, I have to take it off and wrap it in a blanket until it stops Is it plug and play to replace it
  6. QUOTE It is the alarm in the front with the siren not the box under the seat Can I fit a replacement by just pluging it in or do I need diagnostic equipment WHICH I DO NOT HAVE ------------------------------------------------------------------------------------------------------------------------------------------- So now please :- The question is as above If I get a second hand one is it plug and play
  7. Thanks You are talking about the red Siren in the front hood compartment aren't you ? No I have not opened it yet but I will If I get a second hand one does it need to be programed to the car or just fit it and work Thanks
  8. It is the alarm in the front with the siren not the box under the seat, that is ok I have dried it out but it still goes off Search for what ?? My question was will it re set or is it faulty Can I fit a replacement by just pluging it in or do I need diagnostic equipment WHICH I DO NOT HAVE
  9. 1997 Boxster 2.5 Auto - right hand drive I recently had a water leak inside the car which I have fixed Trying to find it I played a hose onto the windscreen The alarm got very wet I locked the car and at 2 in the morning it kept going off I removed it and put it in the garage I have dried it out at home but when I fitted it today it just keeps going off Will this re set or is it faulty If I get another one is it 'plug and play' or do I need diagnostec equipment to re set it Thanks Dave
  10. Hi Mate Please e mail me instructions for Dash Removal Thanks davecockburn2@gmail.com
  11. W T F is a contributing member I have contributed in the past by replying on the forums about Zenon conversion kits Why is this site so difficult to use, you search for one thing and get pages about all sorts of other things Dave
  12. This interests me too I entered ' Approved Sumer wheels and tires' in search and came up zero Any help please Dave
  13. Thank you Richard I won't bother, I have lived without Cruise Control all my life so why start now Many thanks for your reply Dave
  14. Hi Very interesting I have the OBC but no Cruise Control My turn indicator is broken so I need to get a new one Can I buy the 4 stalk switch and add the Cruise Controll to my 1998 Boxster How do I do it please Dave
  15. Hi I have a 1998 Boxster and I need to change the indicator switch. I guess I have to remove the steering wheel. How do I do this and is the airbag a problem Also is the indicator and wiper switch one unit I also have the computer switch, is this seperate or part of the indicator / washer switch I am in the UK and the car is RHD Thanks Dave
  16. Not sure what you mean by relay kit comes suplied - all the kits are the same. a bulb and ballast and some wires. I did try an extra device called a Canbus but that did not work either In the end , after trying 3 kits, I found one that worked It seems it is all in the ballast
  17. OK finally sorted Got another kit on UK E Bay item no 270490919248 - VISIONDP - £72 inc uk postage - guarenteed to work - all works fine E Bay shop - VD lighting and performance - visiondp@live.com 6000k bulbs Sent all the other kits and bits back for refund Dave
  18. I have genuine Litronic headlights which of course are on the dip beam I fitted these myself so they dont rise up on main beam I have fitted HID kits to the main beam But it took 3 sets of kits to get a kit which did not screw up the milometer and clock UK e bay VISIONDP item 270490919248 E bay shop VD lighting and performance Good luck Dave PS Mine are 6000k - best light and white
  19. Hi I fitted an HID kit and had all sorts of problems. The mileage went to zero and the clock went to 12 o clock every time I used the lights First I tried a Canbus killer, that did not work Then I got new Ballasts from another supplier, that did not work I got refunds on all the bad bits Finaly I got another kit which was guaranteed to work for the Boxster - and it did I am in the UK so UK E Bay - Seller VISIONDP - item no 270490919248 - cost £72 with posage E Bay Shop is VD lighting and performance Good luck Dave
  20. Well the new ballasts arived and fitted Same problem I give up Dave
  21. UPDATE A company is selling me 2 new Ballasts for £50 from a complete kit designed for the Boxster 96 - 04 Apparently they have a chip inside which fools the computer into 'seeing' Hallogen bulbs Lets see if this works I will keep you posted Dave
  22. Hi I spoke to them on the phone and gave them the year of the car and they say it will work I will let you know if it works when I fit them Dave No they did not work When I fitted the Kanbuss Killer the headlights stopped working completely Removed and all working but still have the fault The guy is going to try to help me after Christmas
  23. Hi I spoke to them on the phone and gave them the year of the car and they say it will work I will let you know if it works when I fit them Dave
  24. Hi I have been investigating this and apparently it is common Depends on something in the ballast There is a 'warning eliminator' on the market for about £12 I will try Thanks Dave
