scalendine
About scalendine
    Escalade Black 2003
    Cayenne 2004 Silver/Gray
855 profile views
scalendine's Achievements
  1. Summer tires: I just put on Toyo Proxes S/T(20")...SWEET! The ride is way better than the Diamaris I replaced(not as harsh...same handling). Got 'em at onlinetires.com $690.00 delivered and had them balanced and mounted $125.00= $815.00 compared to Diamaris at $1525.00. I'll spend the $710.00 difference on something fun! The tires aren't N rated but they're extra duty and W speed rated. I don't drive faster than 159 mph :rolleyes: . Sweet looking, too.
  2. Buy an instrument cluster for Cayenne S on EBay...the rings are actually one piece that screws on...you can remove the black ring-piece from the V6 cluster and directly screw on the aluminum look ring-piece taken off the S instument cluster.
  3. Believe me...there is NO noticable performance improvement and, at least on the V-6, the pipe gives a tin-can rattley sound at high rev's that's somewhat embarrassing. Sounds like my '75 Vega when it rusted a hole in front of the muffler...not impressive at all! :(
  4. Yea... Don't hold your breath...I don't think that VF is really going to produce one. I tried to contact Nik again, too but to no avail. Too bad...huh? :(
  5. I had the same problem with their inferior product :censored: ...I used hanger strap to anchor the pipe away from the diff, since there are no mounts on their pipe, but the rattle remained. It's more of a resonance/leak problem that Joe and Fabspeed definately know about (I've spoken to him personally on several occasions) but lend a DEAF ear to. I would not recommend Fabspeed for anything...go with another good company for your bypass/exhaust needs.
  6. Oh...this must've been a brand new cluster, huh?
  7. Awesome!!! You still had to have the cluster programmed by PS2T once you had it installed didn't you? I'm glad it worked :D
  8. Well...not really! I just replaced my steering wheel with the wood and everything was just fine when I reconnected the battery. Some settings may revert back to factory pre-set(audio bass, treble, etc.) but nothing that a dealer has to recode! The hard part is getting the air bag off if you've never done it before. In the back of the existing steering wheel there are access ports or holes near the base of each horizontal spoke. You can feel it on the back of the wheel hub if you turn the steering wheel 90 degrees so the spoke points up. To get the air bag off, leave your key in the ignition after turning the car off. Access the battery under the driver seat and un-seat the ground cable(instructions in the manual). Wait at least a minute after power's off, according to the tech. manual, to be safe to unhook the air bag. :eek: Don't worry...it won't blow on you!! Insert a short thin flat screwdriver into the port on the back almost at a 45 degree angle down. Engage wire clip and lever it down very firmly to disengage; took me several tries and some cussin' :cursing: ; rotate wheel and repeat behind other spoke. you'll feel the air bag(top) release when you catch the clip right. Tug gently but firmly on the top edge of the AB unit until it rotates part way out. Disconnect wire harness and it's off. You need a "XZN" or "triple square" socket wrench to remove the wheel bolt. These look like the Torx wrench but with more tines(12). Remove center bolt, take off old wheel, put on new & replace bolt. The airbag then is replugged to the wire harness, lined up and reattached at the bottom first then rotated toward the top. It takes some effort to re-engage the clips at the top of the airbag...you intermittently push on the airbag with the left then right hand and test for attachment by tugging on the top edge. Power up and you're done!!
  9. Porsche calls for use of a "plastic spatula" for prying off and removal of interior plastic trim pieces. I always wondered what the heck they were talking about and just tried not to mar stuff up when using a screw driver. Bojoinc.com offers some real nice sets of plastic non-marring pry tools designed for just this...and at less than $20 you can get a set of four tools that have proven invaluable to me during PSM install, pulling panels/clips to run wires, etc.. Check 'em out. Just wanted to tell you all :D
  10. The procedure is NOT the same... Here's correct procedure for the Cayenne Automatic Shift Knob... 1. Apply park brake 2. Shift selector to drive(car must be running) 3. Firmly pull shift knob off of shaft(do not press selector button on shift knob while doing this) 4. To re-attach knob...place a short flat head screw driver under button on shift knob to wedge it forward gently while push the knob/shaft back onto the selector rod. Push until it snaps to place. 5. test for proper function and shift back to park before releasing park brake. :clapping:
  11. Hey Everyone!! Just got off the phone with Nick who's the head of R&D at VF Engineering. Theyv'e finished work on developement of a supercharger for the V8 Cayenne and are offering it as a bolt on kit. Also...for the V6 Cayenne...they're looking for an owner of a V6 near the Anaheim area or anywhere in CA for that matter who's willing to let them use your Cayenne for a month to tweak the supercharger for it before releasing it as a kit. Nick said you'd get an awesome deal for the supercharger in your Cayenne and if you can stomach renting a car for a few weeks or if you have other wheels to drive they'd definately make it worth your while. For the V6, the supercharger is 6psi, est HP gain approx 80-90 HP bringing the total to around 330 hp or so for the V6. Also good torque increase. Est. cost is $5000 for the V6. Go to VF-engineering.com and check on the kit for the Touareg V6 for more specs...they're both very similar. If interested e-mail Nick at Nik@vf-engineering.com. E-Mail Copy Steve, Thankyou for your email contact and phone call this morning. As discussed, we are looking for a Cayenne V6 to be left with us for a month to allow us to adjust our duct work for the throttle body which is located differently to the Treg. You may be aware that the Cayenne V6 has the Treg engine but just a different manifold. We would also retune software on our 4wd dyno and offer the test car customer a 50% discount on the kit and there would be no labor charge. We are currently finishing up on our V8 kit and are keen to complete the V6 kit, but need a test car. Thanks Nik Saran Head of R&D, CEO
