ubu
Everything posted by ubu
  1. ubu
    Recall MY 14 GT3
    last news from Porsche AG important failure in engine bolt, 9A110311502, at connecting rods, destroying the oïl span. All the 900 and more delivered engines to be removed and changed by new !! Take time to have your own...
  2. ubu
    Recall MY 14 GT3
    http://topgear-magazine.com/post/77727250088/ready-to-drive-your-new-gt3-richard-most this is the solution
  3. Any idea to find the plastic circle around airbag on sport steering wheel ? seems not detailed by porsche dealer. :(
  4. Right Richard After erasing faults and recheking all potentail air leaks in MAF, Throttle and IPD mounts, it became perfect Thanks for the help
  5. thanks Richard I will recheck but - at durametric I have an error code on PAS 8004 Supply voltage clamp 50 sc + and 8005 supply voltage clamp) 5 cs+. This is the reason of my suspiscion - and the engine runned 3/4s not only once but at each starter demand; If the pump failed, I think I could not have these repeated engine starts.
  6. Hello After having disconnected battery for a night to change the Air Filter and the MAF for new; it was impossible to have engine restarted but a quick engine-running during 3/4 seconds and looking as lack of gas. I suspect having PAS disconnected as if the car would have been stolen; Impossible to restart correctly Any idea to recover the situation or have I to go Porsche dealer ? Thanks for help
  7. Thanks Loren I had a mail back from Greg at IPD Hard reboot is the solution and now idle is back to 650 r/mn - shut out battery at negative for 30 mn - engage key just before start for 1 mn - push the accelerator pedal once -close key out - put key -start - push PSM button thats ' it
  8. Hi all, Just mount new plenum ipd 74 mm and K&N air filter on 3,4l boxster S MY 2007 but idle jumped at 1400 r/mn instead of 700 r/mn before, even after 50 miles test Any idea or solution ? thanks per advance
  9. Looking in the front electric harnesses inside front luggage room any direct potential link with "in run or start only" electric location or other solution to step from gen 1 to gen 2 day leds. Any idea?
  10. You are replacing horns? Are you needing to remove the bumper cover or the spoiler? There are several articles here and on rennlist and 6speed that cover bumper cover removal. Not sure of any that just have the spoiler removal? Good luck. DC Yes apparenltly I need to. If you know another method I will appreciate Not seen any good detailed DIY with photos on renntech
  11. Hi Any of you have a good detailed explaination step by step with photos for 987S 2007 front spoiler removal ? I need to replace the failed horns. Thanks
  12. Hi New on forum Has any experienced moving Boxster horizontal side grilles to Cayman vertical grilles at air intake side level ? :huh:
  13. 1/ Opening the plastic arch at front inside one of the front wheels location ( right or left depending model year ), you will find a secret manual cable in order to open the trunk :P or 2/ Inside the fuse box at left of driver legs, you will find a dedicated button to pull and to use as + of any charger ( - on car itself) :) or 3/ As said having a porsche charger to fit with the cigare lighter in the middle box ;)
  14. Nice and you what he did?
  15. look at this : http://www.renntech.org/forums/index.php?s...hl=horn+failure ;)
  16. :angry: 1 one of the 2 traffic horns failed. :huh: Any solution before putting out the front bumper ? thanks
