saxman61
Contact Methods
  • Website URL
    http://
  • ICQ
  • Interests
    Jazz, Blues, any type of music associated with a sax
    Victoria BC, Canada
    2001 Porsche Boxster
saxman61's Achievements
  1. Check out the Bentley Boxster Service Manual from the Renntech Amazon store Here is a site to find the area your looking for.. http://www.cannell.co.uk/Manuals.htm B)
  2. It looks pretty good..(You might have to check to see if the frame is bent.. it could be a write-off.). If it is secure it really doesnt look that bad.. do not purchase parts from the dealer unless you have to.. It will be costly because the part might have to be brought in from the germany plant.. junk yards on occasion do get porsches.. you will have to get a repair manual.. It's a car and DIY should be no probs, for alignment of headlights follow the manual and alignment of the front wheels should get done by a professional.
  3. No it was actually quite simple, I am an Aviation Technician, but that doesn't matter, as long as you follow directions and read the documents more than once to make sure no mistakes are made. 1st evening top removal, clean parts. install new top. not glued yet. 2nd evening glue top front and sides and let sit overnight ..done! The following link is to remove the top, then proceed to top replacement with the link provided in the directions. http://sites.google.com/site/mikefocke2/replacingthetop-adiy I am also a member of 986 Forum.com for additional tech advice!! http://www.boxsterforum.com/forums/index.php Good Luck!!
  4. "To Jazz or not to Jazz, there is no question"
  5. I am not sure that is entirely true. Which rear speaker unit are you referring to? Bose or standard 2 speaker kit? Do you have the rear compartment? or are you looking to replace the soft leather sport case?
  6. I installed a GHAA Top with rear glass window on my 2001 Boxster. It took 2 evenings by myself but saved alot of cash. I installed everything and there are no problems because the window is actually smaller to fit in place behind the speaker unit. That is why your rear view is smaller that the OEM plastic rear window. I would suggest installing it, and make slow movements while stopping to check to make sure everything fits.. Good luck!
  7. YES Coolant Fans operate correctly.
  8. Living the Dream!
  9. I have a 2001 Boxster.Ive read some of the issues regarding coolant leakage but not sure if thats my problem.. I had a oil seperator change reciently and not sure if there is an air blockage or if its a thermostat change required. I have a problem of coolant escaping through the discharge line when driving during hot days or long periods of driving. I was on vacation and it happened again, I noticed if the air conditioning was on there is no coolant leakage. What is my problem?
