TDIDog
Everything posted by TDIDog
  1. Anyone have part #s for the drivers door latch & micro switches? Your help is appreciated. jack Just do a search...link 1 and link2 and link 3...took 3 seconds...you get the point.
  2. Thanks, I'm getting it. Just do a search...link 1 and link2 and link 3...took 3 seconds...you get the point.
  3. I meant send some pics, thanks again. jack
  4. Hi Loren, any chance you could see some pics of how to? Sure would be appreciated. Thanks in advance. jack
  5. What will I see once I take the door panel off? Will it be obvious? Everything is fine when driving. The window stays up, & works fine. Just when I get out the window will some time(not always) go down part way. Like I say, if I put the key in the door to lock & hold for window to go up, it stays up fine. A real mystery. Any pics out there of whats going on in the door? Thanks again for all help. Cheers jack Well you've got two choices...either take it to a stealer or remove the door panel and have a look. It is most likely either the motor or microswitch...
  6. What could be wrong with the motor unit? Sometimes it acts up when I turn off the ignition & take out the key. But when I put the key in the door lock & turn it to lock the door & raise the window, it stays up fine. Any ideas would be appriciated. Thanks jack
  7. Do you have any suggestions how to repair? Any help would be apprieciated. Thanks jack
  8. I was concerned it might afect the CATs, but probably should be ok. Thanks for the reply. Cheers jack
  9. Does any one us fuel stabilizer in their cars? I will be parking mine for the winter & am thinking of putting stabilizer in, but want to know if it is a bad idea. Thanks in advance.
  10. Has any one had this problem? Sometimes if I lift the outer door handle a couple of times the window will just go down by it's self. Also some times when I open the door to get out of the car, the window will open part way by it's self. I will use the key in the door lock to raise & lock the door. Could it be a relay? Thanks for any help
