jyeates
Everything posted by jyeates
  1. Anyone install Innovative MD seat heaters? I need the wiring instructions.
  2. That is the latest tank so unless it damaged during the install it would be unusual for it to leak again. I would double check where the leak is coming from. Thanks Loren, I will check further and pressure test the tank again.
  3. The tank part number is 996 106 147 56.
  4. I replaced a leaking coolant reservoir tank 18 month ago with an OEM tank and it is leaking again. Is there anything that could be causing that? Also, can the crack be fixed with epoxy?
  5. I have MY99 996 cab. without heated seats and I want to add seat heaters. Can anyone tell me if my99 996's are factory pre wired for seat heaters? Thanks!
  6. Can you tell me what the pin assignments are and what you used as a guide to make the removal key. Thanks
  7. Can anyone give me the height dimension of the cup holder under the center air vents? Thanks!
  8. Do you know if a PCM2 can be installed in my99 996? Thanks.
  9. I'd be interested in a red set, powder coated. Joe from San Diego - 99 cab
