havf8h
Everything posted by havf8h
  1. Have you had the dyno completed? Also, what is the speed from 0-60 and 0-100?? Thanks!
  2. Ok... I think I read on here that if you just remove the relay than everything will work fine. Do you have to cut the diode and so on and put the relay back? If I keep the relay out does that do anything bad to anything else on the car? I have an 04' C4S with the PSE. Thank you.
  3. Ok... so I am clear. If you remove the relay "Abgasklappen" then it won't affect anything else other than cut the switch to silence the sports exhaust? Is this true? I pulled this relay and I can't even open this thing. Any suggestions? FYI - I have an 04 C4S with the sports exhaust. Thanks in advance.
  4. Does anyone know if the PSE provides any additional HP? I have an '04 C4S. I want it to have a bit more horses under the hood. BTW, I cannot wait to try and get rid of that annoyance of the change between 25-45mph. Thank you.
