c337cc
About c337cc
  • Birthday December 9
  • Interests
    Porsche,BMW,Airplanes & firm women
    Mississippi
    1980 911 SC,85 Carrera,03 X/5 3.0,03 745I,89 944,74 914
  • Future cars
    GT3
    to many to list
c337cc's Achievements
  1. That's it. Thanks Loren !
  2. CR220 serial number15008629 Lost radio code
  3. Thank you Sir !!
  4. CDR 220 serial number 15040022. Need radio code please.
  5. CDR 220 serial # X5029097. Need a radio code please . Thank You, Howard
  6. Thank You Loren !!
  7. radio code needed CDR220 serial number Y5050613 Howard
  8. Remove the fuel tank sending unit ,use a bore scope or a inspection mirrior & flash light to check the upper half of the tank for rust. This is the biggest problem I see bringing the hanger queens back to live. The tank has to come out most of the time & be cleaned & sealed & many cases opened up,blasted & welded back together. There are reproduction fuel tanks available now for a reasonable price now,so if they are badly rusted,just replace it. Howard
  9. Talk to Vinnie @ Gulf Performance. Pompano Beach, FL. Howard
  10. Agree, Stuck float. Pull the fuel level sender & have a look in the tank for rust. Use a mirror & flashlight & look @ the upper surfaces. Carbs need to be gone thru too. Stuck float will not be the only problem. Solex or Weber carbs??? H.
  11. David Brown is the one person who will do your top correctly. Ask me how I know.
  12. Which cayenne & engine?? Need more info to look up part #'s in PET. Howard
  13. You need to perform a pressure check on the system.Look closely at the control pressure cold. I think the graph is posted on this forum,if not let me know. You should also check for unmetered air leaks. Howard
  14. All 2.4's including the T had counterweighted cranks. Only nthe 2.0 & 2.2 T's had the non conterweighted crank. So the bottom end of a 2.4 T uses the same crank as the S ,as well as the 2.7's. Same crank. Howard
  15. Does the car still have the original non barrier hoses??? If so ,it will leak using r134 in the system. I replace all rubber hoses & seal rings,new drier & exp valve & cure the problems. The cooling fans in the 996 cars are there for a different reason,not for the condensor. Cond is mounted up front on 996,rear in a 88. If you want to make that 88 A/C cold,talk to Charlie @ Griffiths techinal. Howard
