jstarr
About jstarr
    2002 boxter s
jstarr's Achievements
  1. Is the remote reciever under the drivers seat ?
  2. Good point so a code 54 could cause a code 60 in the system can the reciever be re programed?
  3. forgot how do i get to the door microswitch?
  4. Thankyou i will ck the fuse the radio works great and it appears to be factory everything else is good i have a durametic but it it has limits in this situation.My key is old but its all i have.This form has helped me with everything else thanks for all the info.
  5. Code 60 central locking and a 54 code for radio are they related?
  6. Help here remote not working to lock or unlock car durametic said it was a fault code 60 but where do i start to find the problem how do you trouble shoot this thanks for any help i can still use my key
  7. My remote key is flashing but my car is not locking or unlocking also my trunks wont open with my remote what is going on?
  8. Recommend proper way to tow behind A motorhome any ideas or option i have a dolly
  9. Thanks
  10. Ok final question a local part store guy thinks i can reset the airbag light by disconnecting the battery if it wasnt on before i removed the seat im hoping someone can shed some light on this cause i cant find anyone around here who has a scanner for this
  11. In Oklahoma thanks anywaY
  12. Yes cel and a air bag
  13. you are right connector not snapped it was hard to tell at first thanks for the help this a great wed site
  14. Will a actron obd ii auto scanner work on the 986 to read and clear codes?
  15. You probably tripped the system pulling the seat. Did you leave the key in or listen to the radio while working on the car? Either can trip the airbag MIL. Unfortunately, unless you own the Durametric software, you will have to take it to a dealer to get the MIL cleared.................. i open the roof to remove the seat darn it
