mangaluzC4S
    Dallas, Tx
    2006 911C4S - Guards Red
    2002 Z06, Audi A4 S-Line Quattro, BMW 528i
750 profile views
mangaluzC4S's Achievements
  1. removed switch, reinstalled and disconnected battery and wallaaa? It started working again.... I guess i got lucky... Thanks...
  2. would this possibly cause none of the brake lights to work (replacing tail to non-moving tail; cutting wires?) Thanks, Mau
  3. 2003 996 C4S manual tranny... Driving down road and PSM/ABS failure comes on. I checked the brake light fuse and it was blown, (changed fuse 15A and nothing, tested voltage at fuse got nothing when brake pedal pressed), switched the brake pedal switch (still nothing), checked bulbs (all good)... Any other suggestions on what to test next. All other lights work, parking, hazard, etc... Thanks for the help....
  4. Funny, Key FOB works fine now and i can now turn the door lock with the key but it does not lock or unlock the car; only the lock button on FOB locks the car.... ? I am soooo confused....
  5. Since my key does not manually open the door (fits it but doesnt turn), i finally had to jack the car up, remove the wheel well housing and look for the trunk release cable. Once i opened the trunkthe alarm went off and i removed the battery for about 10 seconds. I then put the battery back and walah!?, the key fob works again...Can't explain it but now it works just fine... I read somewhere that Porsche goes into saftey mode after 3 days of non use, is this true? I have been trying to use it more often (usually only once a week).
  6. Shall try with 4.5 ft pipe from Home Depot, thanks for the help....
  7. 2003 C4S: Trying to remove front axle nut to install H&R but cannot loosen it. The car is on the ground, going counter clockwise with 3/4 socket set and 2 ft. cheater bar and nothing; It turned the wheel and it was even in gear. Am i doing something wrong? Am i missing a step? Even tried pentrating fluid... Please, any help would be appreciated.... Mau
  8. How do I tell if it is the Valet Key? It has a yellow tip on the FOB 2 buttons...
  9. The key fob battery is good, tested on voltmeter. I unfortunately don't have a spare... Came with only 1 key... Pulled the shroud off of passenger wheel well and looked for cable to get into trunk, opened trunk and disconnected battery and put back on and wallah!!! key fob now works? I don't know why but i guess i "woke" the car up? I need to get a spare key, but still wondering why this key does not open door manually or glove box. Could the previous owner change the ignition and key?
  10. I have a 2003 996 C4S. I'm new to porsche's and need some help. My key FOB was working fine and both lights blink for trunk and doors when i press them but nothing happens. The key does not open the door manually but it does start the vehicle and run it. The car is now locked and I cant get into it. How do i get into my car? How do i get a key that manually opens the doors. The key i have does start the car and open glove compartment but will NOT open doors or center console... Please help....
  11. Ok, i have done searches and tryed to sift throught the information about porsche springs and the different setups available. I am thoroughly confused, lol!!! I have a 03 996 C4S with front springs with orange white/blue markings and rear with orange green/pink coloring on it. I want to lower the vehicle and dont mind the rough ride, but mostly want to just drop the gap in the wheel well. I really just want to do springs since i dont race and drive only about 3 times a week. Which would be the best solution for me, row m030? H&R springs? Thanks for any help.....
  12. So i took off the wheels this weekend and looked for any markings on them. They have no numbers, no stickers, or any branding of any sort. They are super light and are true 3 piece wheels. How do i find the offset and the brand or model of these wheels? i took detailed pictures of them, any help would be appreciated... i have pics at : http://www.mangaluz.com/wheels.htm
  13. It came with wheels so i will remove them this weekend to see the offset and specific size. Thanks for all the useful information guys....
  14. I am a newbie to Porsche's; I have a 2003 C4S with 19 front and rear wheels. Can I lower the vehicle without issues and how complicated is it? Do i need to realign after lowering and what other issues might i encounter? Any help would be appreciated.. It seems my porsche sits higher at front than rear and its kind of feels "floaty" on highway at front end...
  15. I'm a newbie to Porsche's. Does the decklid from the 996 Turbo models fit the 996 C4S. I have a 2003 C4S and would like to put a small wing in rear...
