fast eddie
Everything posted by fast eddie
  1. Good evening, 997 C2S My two forward air intakes for the oil cooler radiators are full of s---t!*%#$@. These receses have managed to entrain all sorts of refuse, ie, leaves, trash, cig butts, bugs, etc., etc.,...... It is a pia to get the junk out of there. I used a car wash vacuum and couldn't get it all after two dollars. Some of the detritus entered through the central (license plate area) void. There must be some after market screen that will permit air entry while blocking the trash. I've seen other model years with screens where our louvers are located. Anybody know of a product to eliminate the accumulation of crap there? Thanks, Ed
  2. Not a single response. I guess nobody drives fast. Ed
  3. Good Morning, How fast have you driven your C2S?? I've gone up to 145mph. Also, my pax seat release or maybe the seat belt rattles and shakes at speed. Have you experienced this? Ed
  4. Also, don't open the oil fill cap while the engine is running or you'll trigger the engine alert light on the dash. I am told it will require the Diagnostics module to reset it. Ed
  5. Sorry if it's a bit late but it is my understanding that as oposed to the factory installed universal audio interface, the add on after factory interface will not let you operate your MP 3 via the in-dash radio controls. i.e. you have to use the mp3 controls on your i-pod to select playlists, etc. Ed
  6. Do not worry, I had to add oil at the rate of about 1qt. every 2000 mi or so for the first 8,000 mi. It has since settled down to about 1 qt. every 3,000 mi. With 0 w 40, which is about as thin as water, I'm not surprised or upset. Also with colder temps in winter it's logical consumption would be down. The only concern I have is what the valves look like, i.e. exhaust valves, in the 997-2 direct fuel injection manifolds. We will see. Ed
  7. My first oil change performed by a dealer resulted in an overfill. I took it to a factory authorized private service shop and had some oil drained. I don't recall a check oil level warning but it sounds reasonable that you would get such a warning with a low or high oil level. If the car has over 10K miles and they did not reset the diagnostics, that could also trigger the fault indication. Good luck, Ed
  8. 2009 997 C2S. Flat right rear tire. Bought the tire ins when I got the car. Sooooo,,,,,,,I took it in when I noticed the drop in press. Went to work with 20 psi, worked all day and pumped it up with the included pump. The pump worked well. Got it up to 36 psi in about 7-8 min. Took it into the dealer and got a new $500 tire at no expense to me. Left happily after about 45 min incl a car wash. Then,,,,,,, I stopped to check things out after a couple of blocks.....you know, anal. Lo and Behold.........some SOB had jacked my original tire stem caps!! WTF???!!! Drove back to the dealer and asked for my caps. "Duhhh,,,,what caps??" "We don't know where they are." Well, they tried to make nice and offered me other caps. I told them I just wanted my original caps. Nobody knew "nothing", so I left. Couldn't prove anything. The acutal caps weren't the issue. Before leaving I looked the service mgr in the eye and told him they had a problem. How assinine and unprofessional, over a stupid set of valve stem caps. What has happened to America? :angry:
  9. ...People are going to do what they want to do regardless, but there is no good reason not to follow the manufacturer's recommendations when it comes to engine and transmission oil levels. Couldn't agree more. Is it possible that nothing bad comes of it? Sure. Likely, even? Maybe. This makes it the subject of easy internet speculation. But is there anything bad that comes from NOT overfilling it? Nope. Err on the side of caution when you're talking maintenance. Sure you can save a few minutes and maybe a few bucks not having someone drain a little oil out. Hey, it's your Porsche... The level best advice I've seen is. "tell them to put only 7 qts in, I'll check it and fire for effect". :rolleyes: Interesting viewpoints. Ed
  10. Howdy, Would you plug a flat tire? (on your 997 C2S) Plugging flats generates a lot of traffic on the motorcycle forums. You can imagine. Having said that, I've plugged lots of tires, including my motorcycle tires. :o Never had one fail yet. Sooooooo....... (BTW, after plugging a tire, I would not drive too fast) Any opinions out there? Thanks,
  11. Hello Wvicary, The play is minimal. However, compared to a manual shift where the gearbox is located directly below the lever, the feel is positively loose. As an example, (dare I say it?), the BMW 3 and 5 series shift is as precise as it gets. And these are not gated like the Ferrari. I'm not crying in my beer, it's Porsche and it's different...... I'm just wondering if installing the solid rod shift linkages I've seen will void the warranty. If these parts are not OEM then the question is probably answered. Don't get me wrong, I'm getting better and better with the manual transmission with time.
  12. Hello! Does anyone know if it is possible to retrofit a purely solid rod based transmission linkage without violating the warranty? Object would be to eliminate the cable linkage and some of the slop. I've seen a solid tube-rod shift mechanism on some of the racing 911's. Thanks!
  13. Do not worry about it, one of the moderators, (Loren?) will put it where it belongs. Impressive video. With all respect Loren. Ed
  14. Thanks again Loren, You answered my question. Most of the info in the technical manual seems to address the PDK equipment and I have a manual transmission. It seems that many of the sports chrono effects apply to the PDK and that makes sense. And I understand why Porsche would not want to reveal detais of it's ECU programming. I just wondered if it was only throttle control. I will say that in Sports Chrono Plus my 997cS2 is another animal. That in addition to PASM really is another automobile altogether. This machine is phenomenal. BTW, is DME interchangeable with ECU? Regards,
  15. Hello Loren, Thanks for your reply. I've read the service technik pub and really see no info re mapping other than throttle. I'm specifically looking to find if there is any change in either the ignition or valve/cam timing. I did read somewhere else that "mapping", which to me means more than just throttle opening, was implied to mean changes thrughout the power curve. And that would imply fuel, fire or valves to me. Am I wrong? Regards,
  16. Hello, Does sport chrono plus selected on the center console change ECU mapping. The literature I've seen so far states that the throttle opening directions are stepped up in relation to throttle foot pedal input...... but I was wondering if there is any change in the ignition or valve/cam timing? If there are any links or articles anyone is aware of that explains this feature in detail, I'd love to see it. Many Thanks! (GO HURRICANES!!)
  17. Hello, Does anyone know of a good link to see all the diferences between 997-1 and 997-2? Thanks!
  18. Yeah....... And all this because they just HAD to get rid of the oil dipstick! Why couldn't they just engineer a dipstick??? I could have sucked out oil from the sump through a dipstick pipe... The freaking oil sensor will last 4 years and one hour exactly..... Then, it will require dropping the engine to install a new sensor...... I want a dipstick!!!!... How can you race a car engine without a dipstick? Can we reverse engineer an oil dipstick?? Somebody needs to design a retrofit kit to install a dipstick!! :huh: Very cutting edge concept. Dipstick.
  19. [bOK[/b], Where do I post this topic? Which is the best radar detector out there. Not jammer, to get a good jammer it has to be self contained and not a feature of the detector. So...just the detector. Is it the Valentine One or the Escort 9500ix? Or something else? (I couldn't find a good heading under which to ask this question.) Thanks!!
  20. Thanks to all for your replies. Took the car to an independent shop in Pompano Beach, FL. FOREIGN AFFAIRS, the owner's name is Bob Varela. They removed 1L of oil to bring the level to the correct quantity. They had the car on the lift twice since the only way to remove oil is via the drain plug. It is a trial and error procedure. They did not charge me for the service. The oil removal had to be done and Varela and his shop were a class act. Keep you 911's out of the trees!!
  21. Hello! Got the oil and filter change at the dealership last week. 997 SC2. The indicator reads overfill. Ran it for +/- 100 Mi thinking,,,,,,,"they couldn't overfill it that much, after all, it's the dealership, right???!!!" Welllll,,,,,,The indicator still reads overfill!*#%@!!! Soooooo,,,,,,,I got this syphon pump, see, and tried to run it down the oil fill tube......No joy....... It didn't reach the sump. Therefore, I still have overfill and don't know how much overfill. The manual clearly says, "Do NOT overfill". I've probably got huge bubbles of oil in the direcrt injection chambers, right? My valves are all going to get impregnated with burnt grunge, right? My spakplugs are probably fouled, right? If you can't trust the dealership, who can you trust? Would you find someone to drain some oil? Would you take it back to that dealership? If it were your $90K baby? Am I worrying too much over bull****? The exhaust doesn't look too bad..... I cant sleep!!!!!! Somebody reply,,,,,,,please,,,,,,,,OK?
  22. Howdy antinul, Call Champion Porsche in Pompano Beach, FL, 954-946-4020. My total layout was about $850.00. They ordered the stuff for me and had it in 48 hrs. I posted the breakdown earlier in this thread. Good Luck!
  23. Sorry, no "non smokers" kit for the 997 to my knowledge. I think the only thing that woud fit there is a hockey puck. But it is an interesting idea.
  24. Howdy!! 997-2 CS Does anyone with a manual transmission have trouble engaging 1st gear from a stop?? Sometimes it is dificult to get into first, even shifting to second or third before trying first again. Sometimes it delays getting off the line at a red light with the inevitable honker assclowns behind me. Sometimes I'll cycle the clutch several times and try again...and...no joy! I don't want to "force" it, I am told one should not "force" german things. When german things don't work as they are designed, suposedly there is something wrong....right?? Plus, the linkage shift feels sloppy anywaaaayyyyy...I can live with that. But, dudes, that delay at the red light is frustrating sometimes, embarrasing, WWWTTTFFF!!!!!!!!! When some hottie sees you sitting there with your finger in your ear its not cool. ( I'm not really that upset, I will probably keep the car anyway.) (The italics and other gilding was for emphasis only, a form of entertainment and nothing more.) :rolleyes: Gotta be careful here, some of you I know are sensitive. Don't want to get anyone excercised, OK? I do love my car,,,,,,,and this web site.
  25. If your Porsche dealer tells you that you have to drop the engine to change the oil and filter, I think you've been sold a bill of goods my friend. See this post: http://www.renntech.org/forums/index.php?showtopic=7055. The procedure for a 996 is pretty much the same as a 997. I'm just as leery of doing my own maintenance as you, so I had my independent mech, who used to work on my old M-B W123, do my last oil and filter change for $20! I supplied the 9 qts of 0W-40 Mobil 1 and the rest of the bits, including the filter and crush ring from Sunset Porsche. The whole thing set me back a grand total of $110. And seeing how easy oil and filter changes are, I might attempt the next one myself. Cheers! 355, I actually find it easier to have my mechanic do my oil changes as well. I have a similar relationship (with my mechanic) as you do. Changing the oil is easy...It's disposing of the used oil that I find a bit of a problem. No 355, nobody said dropping the engine was required for an oil change.
