fab
Everything posted by fab
  1. This might sound like a stupid ? to some of you but.....how to reset the DME
  2. looks like oil filler tube could be replaced? Anyone know the part number? Any DIY or pics on how to replace?
  3. Dunca! Loren
  4. I'm having a hard time removing the wire connector clip from the MAF sensor. Is there a clip release? Do I use a screw driver. I tried pulling it off but that didn't work. How did you guys do it?
  5. do we have an update?
  6. Hi I own a 00 boxster what is my MAF part #? Thanks Fan
  7. I'm not sure where the oil filler tube is? But it's it where the spark plug is I just had my plugs replaced. No signs of oil. And the car runs fine, no idle surge. I'm gonna reset CEL and see if this happens again. This is my second CEL on 1130 and it has hapen only when I'm in stop/go traffic. I suspect it will come back....fyi i did clean the MAF.
  8. Hi I own a 00 boxster w/approx. 38k mikes. My CEL light came on with code 1130. CEL 1130 point towards intake air leak or vacum air leak. How does someone check for these leaks?
  9. Please do update as I am chasing a CEL 1130 and it could possibly be my MAF on my 00 boxster (tip). with just over 38k miles on it.
  10. Thanks Loren...I'm a victim. Was given the wrong part. I needed the right side and was given the left side. BIG.....difference. Now I need a drink.
  11. My Passenger side connector broke. Does anyone have any pics on how this fits? Does the part differ depending upon which side? I have this as a PN# 996.631.245.00. TIA
  12. I've finished painting my center console and was wondering if there any tips out there on how to put it back in without causing scratches?
  13. I'll post some pics later @ work right now.
  14. bump anyone know?
  15. once you remove your cd disc and storge bin, inside the upper console there are these 4 orange looking plastic things 2 on each side. One snapped off, is it important that I need to replace? Does anyone know how to replace?
  16. I'm stuck. I took off the cd disc caddy and the storage. How do you remove the upper console frame? I can't seem to find any screws to remove. Also, there are these 4 orange looking plastic things inside the upper console frame. One snapped off, is it important that I need to replace that one? Someone must of haven taken off their upper console at one point in time? Any feedback?
  17. I followed these instructions.
  18. I'm stuck. I took off the cd disc caddy and the storage. How do you remove the upper console frame? I can't seem to find any screws to remove. Also, there are these 4 orange looking plastic things inside the upper console frame. One snapped off, is it important that I need to replace that one?
  19. Loren- You have been so helpful and knowledgeable I have to make a donation. Thanks again....
  20. Loren- I found the seller from this website. If you perform a search for 996 headlights his ad displays- Front Headlights 996/boxter - pair, 996 front headlights - clear Do you think these will fit my 2000 boxster?
  21. I've found a pair of 996 clear headlights for sale. Part # 996 631 064 20 and 996 631 063 20. Will these headlights fit/work in my 2000 boxster?
  22. I'm purchasing a Valentine One V1 radar detector and was looking for instructions on how to hard wire the unit and have it shut when the car is not running and turn on when I start the car. Does anyone have the DYI on this?
  23. the cheapiest I've every seen them @ Suncoast for 1395.
  24. Jophn- That seems pretty straight forward. I was told that panel needs to come off.
  25. dj- the cap that you replaced was it an original porsche part?
