flybye_
Everything posted by flybye_
  1. I'm in VA Where do you live?
  2. Can anyone suggest a shopr or dealer to do the install of the Cruise contol, I have the obc just need to add the 4th stalk and wire up. This is an 04 S. I just dont have the proper place to perform this mod. Thanks Fly. :D
  3. Hi Im looking for a shop or dealer to retro install cruise control in my 04 boxster S I have 3 stalks with obc. I dont have the tools or place to do it my self. Email me flybye_@yahoo.com thanks mark
  4. Any update I'm ready to order :) email me pls
  5. From what I've read about the Bose woofer its a very low ohm speaker, what radio are you using? if it's an after mkt. check the ohm load on the speakers
  6. I think you can buy the part that sticks in the hole where the top latch goes, if you install the tonell cover I think you can use it?
  7. bummer I would burn you a copy of the traffic pro cds
  8. Does the motion alarm work when the top is down? If not is there a way to turn that function on? I saw something about a part to fit where the conv latch sits to turn it on? I'm confused :unsure:
  9. Yes I installed a traffic pro unit, new door speakers and amp. Let me know what you want to do and I'll give you some Ideas. my 04 had the MOSt audio system, major pain. email me off list and we can chat
  10. Are you talking about the Harmon becker traffic pro unit with the gps? or the Porsche unit with the large screen? You can order the entire set from Navtech for $150...or find a friend with the disk that you need and a good cd burner . <{POST_SNAPBACK}>
  11. I just fitted 5 1/4 boston pros 50 If I remember correctly the max was 4" inorder to fit the bostons I had to inlarge the hole size. I used a dremel and sandpaper. It worked great. Let me know if you have other questions I just re did the whoel system in my 2004 with MOST new radio, speakers amps mark 2004 550 boxster
  12. Does anybody know if there is a aftermarket plug for the radio harness? I'm looking to try and plug a male end into the factory female end harness to connect my radio, I dont want to cut the factory harness so I would like a plug that is the same type and end like on the radio. I remember something about a vw part? thanks mark 04 boxster flybye_@yahoo.com
  13. can someone tell me what wire is the CAN bus communication with the dash. Or a wire diagram would be great I'm going for a most system to non most traffic pro. I'm running a new amp, but I would like to use the factory plug in harness for power ground and constant power thanks 04 Boxster s
  14. I'm looking to upgrade the factory speakers I have the Hi-fi option what is the current speaker size can I drop in a 6.5 ? I'd like to knwo the speaker size before I rip the panel off 04 bxster s 550
  15. I'm looking for the Part number for the front dash speaker grills Not the speakers themselves just the grills. I believe they are the same for Carrera Models Also I'm looking for the part number of the ash tray delete in artic sivler trim. Is it a whole new part or do I just take off the ashtray hinged flap? Also the part number for the cigar lighter with the No smoke logo thanks Car is a 04 Boxster s 550 with black interior and artic sivler trim thanks, mark NJ :D
  16. can you look into somwhom activation the ccd changer my larnd rover had the same prob.I installed the changer then spliced into the wires and reana relay swicth it works great great sounds. I just dont wan to spend $900 on a cd changer
  17. I'm in the same boat like you, I;'ve searched all over no luck yet finding a way to just plug into the unit. I think I can go into the changer wires, but I don't have a cd changer unit to tap into. I did a custom install on my Landrover for my xm. I went in the changer wires and installed a relay switch. It's not to hard to make, but again, I'm missing the 6 disc changer. & $800 is a lot for the changer. Email me if you find out any other info and I'll do the same Mark Flybye_@yahoo.com
  18. Hi I'm the new owener of a 04 boxster 550, I would like to add cruise control. I have the OBC can this be done? if so will this void my warrenty if the dealer can't install it? Please advise
