zft325
Everything posted by zft325
  1. Problem solved. I put the wires on to the main fuse. For some reason current is alot greater there.
  2. Hi loren, ok when you say disconnect the baterry you mean disconnect the temporary wire for the power (footwell) ?
  3. Hi experts. Im about 400 miles to a nearest city here and my battery drained. When i try to put current on the car( red thing near footwell) all i get is the alarm. I cabt open the hood and the trunk. Ive been trying but still to no avail its been 2 days. Usually when i try to do that i open the electronic switch without any problem. The remote of the keys dont work so im not sure if thats related, but ever since i got the car the key remote doesnt work. Is there a fuse for the electronic switch for the hood? If anyone can get me where its location is id appreciate it. Thanks. 2001 boxster s wpocb28991u662052 thanks
  4. ill try to get the code again. thats all i can remember knock sensor bank 1/
  5. Hi guys!, I need help on my car. the problem is when idle the car is shaking. i plugged the computer on and it said knock sensor bank 1, is this a symptom on a bad knock sensor? and can anyone help me with the part number of knock sensor bank 1? my car is a 2001 boxster S. thanks in advance!
  6. hows the review of pagid? thanks
  7. Hi guys, any suggestions on what brake pads should i buy? its the first pad change and im looking at several options from ebay but would rather get suggestions from you experts out there :) thanks in advance
  8. hi therock88, sorry but i cant seem to find threads on repair of that hinge, need furthermore assistance sir if u may? thanks
  9. thanks so much therock88. it sure helped alot. ill try to search on the hinge. thanks:thankyou:
  10. Hi guys i have a 2002 -996 turbo, my problem is that the rear spoiler does not work, it seems that the hydrolic shocks of the spolier is not working and has no fluid, my questions are 1. is the shock refillable? 2. any of you guys know the part number of that hydrolic shock andm 3. anyone has a diagram of that part? thanks in advance all you porsche experts out there.
  11. ok cool!! thanks ill do that tom
  12. thanks guys!, just wana make sure this wont happen. hehe.
  13. HI guys, sorry for the description on the title but im referring to that plastic black thing that covers the valve pin when you want to bleed the air from the radiator. i just finished bleeding the system and i forgot to put that back cause i was monitoring the valve pin. now my systme is ok my question is: if i put that back do i need to bleed the system again cause im going to open the cap again? or is there another way i can open the cap that wouldnt require bleeding it again? i heard people say that during morning i can open it because no pressure yet on the system? any help would be appreciated. thanks guys
  14. solved this one, yes its the CPS. thanks guys
  15. HI to everyone, as i browse the common defects of boxster s on the net, i saw some horror stories of their car burning after seing the check engine light on and seing smoke on the air vent (right portion) . my qustion is are these stories true? are they based on reports? any reason why these may happen? hope someone can explain why and what can cause them and also to prevent them from happening. inputs pls. appreciate it
  16. hi loren. nope did not bleed because i did not take out the abs pump. only the electronic part. so no problem.
  17. here are more pics of the parts
  18. hi loren, finally installed the part. 1. take out plastic cover inside the bonnet beside the abs pump unit. 2. unscrew the abs module (bosch part) from the source unit (imported part) 3. detached the broken abs module part, 4. installed new module. 5. start the car and erase fault codes. 6. test drive the car. all is back to normal.
  19. Hi loren, just got the parts from america. im gona take it to the shop tom and do the procedure. ill post results after. thanks
  20. thanks so much bud. ill proceed with the part. thanks
  21. this is the ebay link of the part. you think its compatible? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190405802644&viewitem=&sspagename=STRK%3AMEBOFFX%3AIT
  22. hi loren, this is what i saw in the hood on the options c08, 139 , 249, 288, 340,432, 476, 502, 551, 584, 604, and mu vin number is wpozzz98z1u642866, can you pls help me to determine if i have the traction control? im just confused on the abs module, i am about to order the part, the only thing i notice is that in the dash i have the button that says psm off with the light beside it. thanks bud
  23. :thankyou: thanks so much loren, i will try that as soon as i get the part that i ordered (abs pump with module) , will post results. your the best loren
