zft325
About zft325
  • Birthday 02/24/1978
Contact Methods
  • Website URL
    http://
  • ICQ
  • Interests
    Cars and Cars:)
    Philippines
    Other
    2001 boxster s, 98 slk230,2002 range rover 4.6hse,98 G500,99 S320 avantgarde,1998 porsche 911 carrera,2004 toyota landcruiser vx,
zft325's Achievements
  1. Problem solved. I put the wires on to the main fuse. For some reason current is alot greater there.
  2. Hi loren, ok when you say disconnect the baterry you mean disconnect the temporary wire for the power (footwell) ?
  3. Hi experts. Im about 400 miles to a nearest city here and my battery drained. When i try to put current on the car( red thing near footwell) all i get is the alarm. I cabt open the hood and the trunk. Ive been trying but still to no avail its been 2 days. Usually when i try to do that i open the electronic switch without any problem. The remote of the keys dont work so im not sure if thats related, but ever since i got the car the key remote doesnt work. Is there a fuse for the electronic switch for the hood? If anyone can get me where its location is id appreciate it. Thanks. 2001 boxster s wpocb28991u662052 thanks
  4. ill try to get the code again. thats all i can remember knock sensor bank 1/
  5. Hi guys!, I need help on my car. the problem is when idle the car is shaking. i plugged the computer on and it said knock sensor bank 1, is this a symptom on a bad knock sensor? and can anyone help me with the part number of knock sensor bank 1? my car is a 2001 boxster S. thanks in advance!
  6. hows the review of pagid? thanks
  7. Hi guys, any suggestions on what brake pads should i buy? its the first pad change and im looking at several options from ebay but would rather get suggestions from you experts out there :) thanks in advance
  8. hi therock88, sorry but i cant seem to find threads on repair of that hinge, need furthermore assistance sir if u may? thanks
  9. thanks so much therock88. it sure helped alot. ill try to search on the hinge. thanks:thankyou:
  10. Hi guys i have a 2002 -996 turbo, my problem is that the rear spoiler does not work, it seems that the hydrolic shocks of the spolier is not working and has no fluid, my questions are 1. is the shock refillable? 2. any of you guys know the part number of that hydrolic shock andm 3. anyone has a diagram of that part? thanks in advance all you porsche experts out there.
  11. ok cool!! thanks ill do that tom
  12. thanks guys!, just wana make sure this wont happen. hehe.
  13. HI guys, sorry for the description on the title but im referring to that plastic black thing that covers the valve pin when you want to bleed the air from the radiator. i just finished bleeding the system and i forgot to put that back cause i was monitoring the valve pin. now my systme is ok my question is: if i put that back do i need to bleed the system again cause im going to open the cap again? or is there another way i can open the cap that wouldnt require bleeding it again? i heard people say that during morning i can open it because no pressure yet on the system? any help would be appreciated. thanks guys
  14. solved this one, yes its the CPS. thanks guys
  15. HI to everyone, as i browse the common defects of boxster s on the net, i saw some horror stories of their car burning after seing the check engine light on and seing smoke on the air vent (right portion) . my qustion is are these stories true? are they based on reports? any reason why these may happen? hope someone can explain why and what can cause them and also to prevent them from happening. inputs pls. appreciate it
