fpena
    Charlotte, North Carolina
    2002 Porsche Carrera Cabrio, 2011 Porsche Cayenne Turbo
    1991 Porsche 944 S2 Cabrio
fpena's Achievements
  1. That's next on the list of things to do. I guess we assumed since they were new struts they shouldn't have any issues but it's quite possible the valve is loose or maybe the air connections aren't seated properly. I mean it doesn't seem likely since again both sides are going down at the same time but worth checking. You are correct that when things are without issues these vehicles are wonderful. But when things like this happen they can also turn around and be quite frustrating! Thanks!
  2. I have a 2011 Cayenne Turbo with 215k miles. Recently the front struts started making noise so we replaced them and filled up the accumulator with regular compressed air. The vehicle would lower and raise but overnight would end up with the new struts pretty much bottomed out. However once I would start driving it would go back up to normal level and stay that way until stopped for several hours. Now what is unusual is that the old struts would never exhibit this condition yet the whole front end is low with the new struts. So I took it to our indy mechanic and he discovered the rears are also leaking. They did fill up the accumulator with nitrogen but we decided to take the car home and install the rears ourselves. So those were replaced today and everything appeared to be fine. This was earlier today so now about 8 hours later my fronts are once again dropping. The rears are fine and again if I tell the car to raise or lower I get no errors and it works just fine. But somewhere within this system there is something letting the air escape from just the front struts. Note this is not just one side drooping, it is both front struts. So this gives me the impression that it's not a leak at the individual unit but something affecting that whole front half. Any ideas? It all works perfectly but just doesn't maintain height overnight. This is confusing considering all four corners are now brand new units. Thanks in advance!
  3. just curious, what did they charge you? and is there any public transportation in the area? as I would need it to get back to NYC (brooklyn) thanks I used to use them when I worked in NYC. The shop isn't too close to the NJ Transit train but close enough where I would take a cab in the morning to the station and then they'd pick me up at night in a tricked-out air-cooled 911.
