JBW
Everything posted by JBW
  1. Looking to choose R-SPEC tyres for my GT3. Only doing club level track days, not full circuit racing or Targa rallies. Will use my R-specs on a dedicated set of BBS rims, leaving road tires on my standard rims. Some say the Yokohama A050 is the ultimate and obviously its top dollar. What do people think is the best “bang for your bucks” value option? including from the following: -Yokohama AD08 or V105 -Dunlop DZ03G -Hankook z221 -Kumho V70a -Toyo R888 Appreciated and regards to all
  2. 2004 996 GT3 3.6L ENGINE - INTO A - 1998 996 C2 3.4L BODY SHELL We have been looking at the body shells & PET diagrams. - Understand the GT3 engine/box is longer & heavier (?) The 2 key parts that seem different are on: PET "REAR END" DIAGRAM - 801-35 A - TERMINAL PIECE - item 1 - this is VERY different. C2: - 996 551 973 00 GT3: - 996 551 173 90 B - REAR WALL - item 9 - large piece - but seems quite similar? C2: - 996 502 911 00 GT3: - 996 502 191 91 Would most appreciate any advice re: - Are these the relevant different body parts? - any other different parts people can think of? - Can we use the existing C2 REAR WALL to mount engine on to etc? - as guessing its a big job to swap in a GT3 REAR WALL!! nb- should have clarified: A- we are also swapping in my GT3 Cup Transaxle/Gearbox B- also fitting my GT3 engine wiring harness to manage GT3 engine. The GT3 engine wiring harness looks like it will "plug & play" into the existing C2 harness - @ just behind the seats - hopefully! ANY THOUGHTS RE: 1 - do you think this will still cause issues with the WIRING for the GT3 engine e-throttle? (As the Carrera 2 did not have e-throttle back in 1998) 2 - the GT3 box is longer I think - true? fitting issues? THANKS :)
  3. ps - re fitting "Cup Car" style carbon doors - vs OEM steel doors - the weight saving apparently is huge - 40 odd pounds per door ?!
  4. I have recently had a relatively major track "off" - so looking for many replacement body parts. - no insurance cover for the damage of course :( Bumper covers, doors, fenders,bonnet, engine lid, wing etc Am interested in lightweight fibreglass (FRP) or carbon panels as substitutes for OEM parts - my car is used on the race-track a lot. Understand Carbon is more expensive - but lighter. But FRP easier to do minor repair work on from a small bump? 1 - Thoughts on OEM vs FRP vs Carbon? OEM parts fit well, are good for re-sale etc - but ARE also expensive! 2 - Recommended non-OEM body parts suppliers? - MA Shaw in USA - xtrememotorcars in USA - Revosport in HK - others? 3 - Fitting "Cup Car" style carbon doors to a car that is still used on the road - seems hard work. - Issues with locking/security, handles, mirrors, inner parts - is it just too hard/expensive &/or not practical? many thanks JB
  5. Need a new set of FRONT BRAKE ROTORS – for my 996 Mk II 2004 GT3 (ie with the larger 6 pot calipers) Have been getting 6 moths use only from the OEM Sebro’s. Cracking from the very outside ventilation holes close to edge of rotors, plus cracks between the holes. I’m typically only doing short sprints, time trials etc – or 8 lap races (9/10 minutes) – at most - So fade, heating not a huge issue More focussed on getting some good life from the rotors – but still reasonable bite factor etc. OEM Sebros are DRILLED of course – I hear SLOTTED rotors are better as no issues with the cracks between the ventilation holes - But these heat up easier? Provide the same grip/bite factor? Appreciate thoughts..........recommended suppliers? Cheers JB
  6. I'm only going off what the Workshop says to me - we need camber to get heat & push the rears to grip better under load ....especially thru high speed corners is there a simpler way to do it then? - ie with toe? many thanks
  7. thanks Craig - I'm getting there - all clear now! cheers :)
  8. Thanks Loren so the Cup rear trailing arm includes parts 1-8-9 in the diagram? cheers
  9. anyone know how to access some replicas of the very cool looking wind deflectors - or down-force vanes (?) - on the new 997 Gen II GT3 RS 4.0l - on the sides of the front bumper cover - see pic attached thanks
  10. Thanks- bit confused - my car is '04 996 CS so do I upgrade to RS/Cup arms? think these are correct: ?? 996 331 053 90 leftwishbone assembly 996 331 054 90 Right cheers
  11. awesome advice- thanks
  12. fantastic - thanks!
  13. I am looking for some adjustable LHS rear wheel control arms for my Porsche 996 2004 GT3 CS I am starting circuit racing & we need to get morecamber into the slick tyres to make them work - ie get hot! Apparently - the standard arms on a road 996 GT3 just won't give enough camber adjustment. will 996 GT3 Cup (or RS?) arms do the job? Appreciate any insights/parts available thanks :)
  14. wow! - awesome advice :) thanks
  15. many thanks Craig very interested you are positive re wet use - my workshop is so wary of them - I've found the same - but admittedly mine were old & worn when I bought the GT3 cheers Justin
  16. Hi from OZ fellow GT3 lovers - really like some un-biased advice re BEST R-SPEC TYRES FOR A GT3 IE - FAST ON A TRACK - BUT STILL USEABLE ON THE ROAD - LEGALLY! Guessing Treadwear/softness 80 or lower Michelin Pilot Sports often seen (think they were original fitment on my 2004 car) - but I hear they are super dangerous in the wet on the road - just no grip. There seem to be a number of non "big-name" supplier now offering R-specs that are very good value - price relative to life - eg Hancock Obviously - 18 inch - 235/295 - perhaps you can run up to 305 on the rear? thanks Justin
  17. Hi from OZ fellow GT3 lovers - really like some un-biased advice re BEST R-SPEC TYRES FOR A GT3 IE - FAST ON A TRACK - BUT STILL USEABLE ON THE ROAD - LEGALLY! Guessing Treadwear/softness 80 or lower Michelin Pilot Sports often seen (think they were original fitment on my 2004 car) - but I hear they are super dangerous in the wet on the road - just no grip. There seem to be a number of non "big-name" supplier now offering R-specs that are very good value - price relative to life - eg Hancock Obviously - 18 inch - 235/295 - perhaps you can run up to 305 on the rear? thanks Justin
  18. Yes - speakers in rear not connected! - crazy the grills are still there - I had to remove CS seats to run the spkr cables All of the CS's I know DO have side air bags - one of mine went off on track recently - perhaps an Australian requirement etc cheers
  19. Hi there I have an identical 04 GT3 CS - in black - in Perth This is the car just sold by QSM yes? FYI - the slots in the top of the bumper are the same as for a GT3 RS - ie the Cup Car bumper - the car also has some S/S gear rings if I remember? Other mods worth considering: - shocks - Bilstein PSS9's - Star racing exhaust - keep your existing one for road use! - single mass flywheel - RS carbon wing Lots of fast GT3s here in Perth - 996 & 997 The Porsche Club in Oz have booked BATHURST over Easter! - join us! cheers Justin
  20. Well you're going to have a couple of other challenges where wiring is concerned. #1, you're going to have replace the OBC, which i'm assuming you got with the new engine yes? I'm not 100% positive on this or not, but the instrument gauge cluster you have in your car, and that of the cluster found in a boxster S are 2 different versions... I believe it's similar to people who have wanted to swap in the 996 cluster in their boxsters, but I'm not 100% positive. That may be something you need to research more. The new 3.2 L OBC will be configured to a 3.2L's specs. However, because you have bored the engine, you will likely need to find an indy shop capable of "tuning" the engine. The MAF may need to be re-mapped among other things to fully take advantage of the performance specs. The A/C controls (HVAC) control unit should be plug and play, I don't see there being anything different between these modules. If the car has not been equpped with the "third radiator" already... you'll definately also want to make sure that gets installed as well. The 3.2S comes stock with 3 radiators, with the third in the middle. Has the car already been fitted with a Boxster S front bumper? Not sure if it's 100% necessary to put the S bumper on, however, that particular bumper has an air opening for cooling of the third radiator. Obviously the lines also have to be run to this radiator. While we're at it, we might as well discuss the brakes and suspension. The S uses bigger rotors (cross-drilled) on both the fronts and rears, as well as larger calipers and pads among other things. It "may" be easier to purchase the "BREMBO" big brake kit, rather than trying to find Boxster S parts for all of it. You'll get the same if not better performance out of them, and it may cost less in the long run than having to hunt down all the parts. Just my thoughts there. The suspension... the rear and front sway bars are more robust than a standard boxster, along with the linkage. These can be swapped out, and should help with overall stability. Since neither the S or the standard boxster were really designed for a larger engine like the 3.4 (at least on your year and model you're working on), and considering you're specing the car out for race... I would also suggest a more heavy duty engine mount. There are articles on how to swap in the 996 engine mount, which i believe would suit your purpose. There are some aftermarket ones that are out there, however, I have heard bad reviews on them and them causing more problems rather than fixing them. As for the ABS, I'm not entirely sure as to the differences, someone else would need to chime in to give you some sound advice there. One other thing you really should consider... again, with the intent of "racing" in mind. Replace the factory 3.2S AOS (Air Oil Separator) that's on the engine with larger more robust MotorSports AOS. It's a 2 compartmental true AOS as opossed to the factory ones that come on both the non-S and S engines, and it's meant for higher G-Forces (especially on cornering). Last time I checked, Sunset Imports can get the MotorSports AOS (which is a special Porsche order item) for $150, which isn't too bad all things considered. Hope this helps. cheers many thanks again :) apologies for delayed reponse Really feel we have bitten off more than we can chew here - really should have started with a mna S & upgraded form there - not a 97 Tip - bad advice from Dealer thks again J
  21. many thanks - but we are ok there cheers Justin
  22. WOW - that is worth far more than 2cents - thanks a "million" :) Dealer was ok that the 5spd box that I have - ex 1999 2.5l Boxster would be ok with the 3.2 - both re fitment & ability to handle torque - so will raise your point with them re 6 spd box - very curious indeed. Has me even more worried now!! - over & above the whole tip to man conversion. Yes - re the e-gas & throttle issue. We knew this had to be re-worked & has been done successfully already, back to suit the non e-gas version Have started work on single mass flywheel & race clutch - both to suit the 5 spd box thou..... Finally - what is your view on the whole tip to manual conversion - the killer seems to be the wiring system - never being able to get all the components thereof to talk together......engine mngmt, ABS, lights, A/C etc many thanks Justin
  23. Many thanks :) Yes - it is just a question of dollars. But the issue is being advised using a TIP to start with was ok, was a fatal error re $$ - yes or no? - will take forever to rtn to manual trim - ie replace entire wiring harness I am told, etc etc Yes - I plan to use the Boxster 5 spd box I have cheers
  24. Hey Sam - I'm in Perth. Yes - issue getting the back - sticky - side of the velcro to stick to carpet. In the end - we glued the velcro strip to carpet - I am loathe to drill holes - real issue on re-sale - residual glue on carpet post any future removal of velcro strip can be cleaned up with turps/trim of carpet etc! good luck - Justin - ps Boxster for sale - send me email if interested - it a Motorsport RS car!
