BoxSinit
Everything posted by BoxSinit
  1. Ok, I am going to look into it. Thanks!
  2. I think I know what happened here! I piggybacked the original poster, Andrew Howell, and he was getting the "immobilizer not ready" warning! I think we are back on track here! As in the quote that I have attached reads, you initially suggested that I check the fuel pressure and delivery rates. It went a different direction when you thought there was something in the tachometer being off and that's where the CPS fix came into to play. I understand your mixup because your tending to a lot of different threads. Moving forward. I did purchase a fuel pressure kit. Where is the fuel pressure rail? What readings should I be getting for the fuel pressure and delivery rates? I have never performed this test before. All new stuff for me, but rewarding and going through the steps. By the way, I just donated again. I do appreciate you, JFP and this site!
  3. The car did fire up then died when I used starter fluid. Doesn't this suggest it's a fuel delivery issue?
  4. I hope it isn't that. That looks like an expensive fix. I'm not sure if I mentioned it but the car does turn over strong but won't start. Could it be the starter as well? I took a look under the seat and it's not wet at all.
  5. Will do. Is the immobilizer easily accessed for removal? I'm just curious, would this be inspected first before fuel delivery troubleshooting, based on its more susceptible to corrosion damage by sitting?
  6. Hello JFP, Well, I finally got a chance to install the CPS. It didn't start. Of course, I am disappointed, I really want to get this car going. This car always ran like a champ, but after sitting for over a year, it just won't start. What are the usual suspects in a car sitting? I'm just a bit frustrated 😤. Can I be missing a fuse or something? I did change the ignition and fuel pump relays. Is it back to a fuel delivery issue? What's my next step? I know I can get this done.
  7. Yes! Thanks for helping me out! It's nice to go through the steps of testing instead of throwing parts for a fix. I will be ordering the part. Torque setting for the CPS bolt? I just have a couple of questions to get an understanding. After I got a low-voltage drop at the fuel pump, I turned it over and the tach didn't move much, does this indicate the CPS may be faulty? Also, can CPS just go bad from sitting or could this be more of a coincidence?
  8. Good morning JFP, I did a resistance test. Firstly, I tested pins 1 and 2 on the lowest setting. The reading stayed at 1 so I went up to the next highest. I consistently got as high as 911. Next, pins 1 and 3 reading stayed at 1 from the lowest setting up to the highest setting, so really high resistance. Looks like a lot of resistance overall. Do you think the CPS sensor is bad? I attached a few pictures.
  9. Hello JFP, I finally got some time to get the car up and get to the connector to test. I attached a picture. I'm assuming pins 1-3 are from left to right based on the picture. Which pins are the ground and the live wire?
  10. As always, you are spot on with instruction. I appreciate the detailed explanation. I'm going to look into this. I'll get back to you. Thanks!
  11. Interesting. All new stuff to me. What range of number should I get with an AC voltage test? As far as the signal strength and the use of the scope to measure; what type of scope and where does it's interface?
  12. Ok. I'm new to testing electronics. Would I do a voltage test at the connector of the CPS?
  13. Ok. Initially I was going to change this but went in a different direction. I hope this is my issue! Where is the crank position sensor located? Is the part number the same for a Boxster and S version? I have a 2002 S. Thanks!
  14. The tachometer raises a 1/5 of 1000 rpms then drops down when you turn it off. No bouncing.
  15. Hey JFP, I decided to check the voltage of the power source (at the connector) to the fuel pump. I first tested the battery which was a little over 12V. I started the test on the multimeter at 20V but got nothing. I had to go to the lowest setting on the multimeter to get any reading that was no higher than 1.5V. The voltage drop shouldn't be that low, correct? I got a fuel pressure kit but I wanted to be sure if power was getting to the fuel pump. Let me know what you think. Thanks!
  16. Hey JFP, I tried to the jumper pin. It wouldn't turn over but I "think" I hear some whirring forward the cabin when I leave the ignition on. I do hear the throttle body resetting in the background. I never noticed, but what kind of sound does the fuel pump make?
  17. I'm going to try to tackle this myself. I see a post of yours on another forum. Where is the shrader value to connect the fuel pressure gauge? I see a diagram but not sure exactly where it is in the engine bay.
  18. Thanks JFP. I guess I'm in a jam. Ive done a lot work on my car but not familiar with the testing stated above. Any tips? Do you think Chevron Techron would help?
  19. I replaced my fuel pump relay and no luck. How do you jump the relay?
  20. Hello All. It's been a while. I am having a similar problem. My 2002 S has sat for 1-2 years. The car ran perfectly before sitting. JFP,Should I take the same course of action? It's been frustrating getting to the bottom of this. So far I replaced the battery, added new gas, checked fuse C4, replaced ignition and fuel pump relays . Tried starting fluid and it started for a brief moment and died. Not too familiar with a multimeter but working on seeing if there's power to the pump itself. Any help would be appreciated. Thanks!
  21. I did clear it. I'm going to hook up the Durametric to see if it came back. Thanks.
  22. Does anyone have anyone have any insight how I would get a code of 5525 when this isn't the norm for a Boxster?
