Laz
Everything posted by Laz
  1. Thanks a bunch! I'll give it a shot later today.
  2. All these years, finally lost my radio card and a radio key set! The Becker 1 is Type 4462, Ser. No. 15063894, 24/99. Where might I get a new key set, too?
  3. Thanks, Loren. I have too many numbers dancing in my head! I looked at my invoice and it has the correct number for the base, but they had pulled the S kit, marked properly, which I returned.
  4. I want to replace the retaining clips and pins on my 2001's front rotors. The rotors and pads were recently changed out, but the retainer kit I got from Sunset (very nice to deal with) had "996-352-959-01" on the invoice and package. (The clips are too big.) Pelican and AutoAtlanta have this number only. Thanks. I'm in the US, btw.
  5. ... I noticed when switching from low to high beam and back neither Litronic relevels as it should. I bounced the front end up and down thinking I might cause the leveling to act, but nothing happened. Earlier in the evening, I got flashed by an SUV of all things, so that was a clue. I pushed and wiggled the front and rear suspensions' electrical connectors and mechanical linkages, and they seem OK. They DO move with "ignition on" leveling test. (I hear the motors operating in any case.)
  6. I've gathered opinions (all reasonable) that the noise could be the sway bar drop links (retorque or replace -- they were replaced and torqued properly,) upper strut bushings/bearings/plates, lower control arms (whole assembly only, no replaceable bushings,) radiators (the noise is heat-dependent; only occurs after car is fully warmed.) Checked/damped/removed as many trunk panels as possible, checked and shimmed underbody/wheelwell panels, checked under dashboard/removed one passenger side cover panel, removed headlamp units. Damped the trunk lid and latch mechanism. Went to a good local shop today, which fortunately has a street nearby that allows the noise to occur, and had them use their "electronic ear" to check the upper strut by attaching the sensors to the mounting bolts inside the trunk, and also to a lower control arm near the hub carrier (on the side that seems to be making the most noise.) No conclusive results. Two Porsche dealers haven't been able to find the cause, and a couple years ago when the rear had the same noise, a third dealer changed out a lot of the rear suspension which solved the problem, but they couldn't say what the actual cause was either. When I got home, I placed one end of a short strip of oak against various suspension pieces and rapped the other end sharply with the palm of my hand. When I rapped it against the front springs, I got a noise that sounded a lot like the plonk. I compared the noise against the rears', and those seemed well "seated" as the sound was a solid thunk with some slight ringing. I found that I could even just pluck and poke the fronts with stiffened fingers and get a hollow rattling, which began to diminish as the car cooled down. Near as I could tell, the rattle seemed to be coming from the bottom of the springs where they seat against the struts. I think I'm finally on to something, and tomorrow will go back to the shop to demonstrate my method. QUESTION: are there replacable shims or somesuch between the spring bottoms and the struts? (I'm aware of the bushings and plastic(?) plates at the tops.) Thanks for your patience and consideration: I know this has been a long post.
  7. Tomorrow I'll be having the anti-sway bar bolts retorqued. What I've noticed is the noise seems to occur when the car (2001 base Boxster, no mods) is fully warmed up. Ambient temperature doesn't seem to be a factor. Example: Took a 50 mile drive and parked on a grassy field. Lots of plonking from up front. Left a few hours later, air temperature still about the same, but the front end was quiet. Based on this, are there any other possibilities? (I also suspect the larger, central underbody panel, as I've damped/removed most everything else to no avail: Hood, panels inside trunk, battery and side panels, panel under passsenger dashboard.) Someone at PPBB suggested checking the radiators, too. Thanks.
  8. Thanks again, Graeme.
  9. How does one access the swaybar bolts? I just lifted my Boxster and did not readily see them. Are they behind the plastic shielding? I did not remove the wheels. <{POST_SNAPBACK}> Thank you, Lemmy. How're things in Alphaville?
  10. Thank you, Graeme.
  11. 2001 base Boxster. I imagine there are up to 8: 2 pairs for the chassis brackets, 2 pairs for the links. Thanks.
  12. At approximately 10mph, over small, sharp irregularities, such as rough asphalt, or concrete slab gaps there's a noise like a Frisbee being knuckle rapped. Seems to happen after car is warmed up. Have already tapped/damped various plastic underbody panels, trunk lid, trunk panels and a cover panel under the passenger side dash to no avail. Had a very similar noise from the rear years ago. A dealer changed many suspension components (under warranty), which fixed the problem, but couldn't say what the actual cause was. I'm hoping it had to do more with tightening something, even some panel, especially now being out of warranty. One suggestion over at PPBB is to check the sway bar bolt torques. Haven't gotten to that yet, but if anybody has a definitive answer, let me know. Thanks 2001 base Boxster, no mods.
  13. Thanks for the conjectures. I found in the back recess. Threads are on the outside. It's a very light gray, and it's not one of the flip-up fasteners on the carpeted engine panel. Sorry about no picture, but I'm still using a beautiful Canon F1 from way back.
  14. I heard a light rattle coming from the rear of the car. In the top's latch recess I found this: a light gray cap(?) about a total 1 1/2 inches long, having a hollow, very course thread shaft about 1/2 inch wide. The other end terminates as a flat disc about an inch in diameter, with a curved "basket handle." There are no markings such as a part number, etc. It shows no sign of wear, or having had any fluid on it. My only conjecture at this point is that having the engine replaced recently, it might be something that temporarily sealed an orifice or hose on the new motor. 2001 2.7 Manual
  15. Thank you to one and all.
  16. Tool Pants, if you would: here's the part #: "986-100-922-FX" The invoice also says "2.7L 2001 BOXSTER MA" I would've thought the serial number's "AT" meant Automatic Transmission. Also I wonder if I do or don't have a 217 hp engine or a later version and what the "MA" might signify. Thanks again for your help and I think this'll be the end of my questions concerning this topic.
  17. Thanks. I re-read the invoice, and yes, there's the part number with an FX. For a couple days I thought I had a new one. Interestingly, the replacement seems to pull better than the old one, though it's a bit "whinier". The old motor got more throaty at around 40 thousand miles.
  18. Correction: Thank you "Tool Pants".
  19. Thank you, Toolpants. The number is M96122AT65165022
  20. Due to a chronic Rear Main Seal problem (replaced four times), my 2001 2.7 got a replacement engine under warranty. The repair invoice has the old and new serial numbers, and the new one contains the letters "AT". I understand that an "X" somewhere indicates the engine is a rebuild, but I don't know what the "AT" signifies.
  21. Thank you, Loren.
  22. Will there be a new TSB posted? I'm curious as I've had my share of RMS problems. The latest dealer's service invoice (1/20/05) mentions "replace bolts as per bulletin". One of the threads on this board mentions new blue bolts and I'd like to know when these began to be used, along with anything else that may give me reason to believe the leak problem might be resolved. 2001 2.7 Boxster
