SithPitt
    Puerto Rico
    3000GT VR-4 [1991], Cayenne Turbo [2005] & Carrera 4s [2003]
    Boxster S 2001
1,286 profile views
SithPitt's Achievements
Community Answers
  1. I happened to my on my Carrera. In my case was not the mirror glass, but the base corner side pointing to the front that was a bit loose. I noticed when I was washing the car. Check externally your mirror unit moving it sideways and up/down near the base too see if there is base related... If not check Dr. Pepper suggestion... SithPitt
  2. Well that's something that I didn't know, but it's a good thing to know... Mine doesn't have Sirius :thumbup: And BTW thanks for the congrats :jump:
  3. The Transport System [1st pic] goes straight to the roof of the Cayenne and is not compatible with the long roof railings [2nd pic]. My cayenne didn't have any, so I figured that my best choice was the Transport... Your bicycle railing [3rd pic] is an exclusive fit for the long railing and as you can see is like the Transport system which goes side to side... SithPitt
  4. Well you have to check if your radio harness has all cables as same as a Cayenne with PCM [1st thing] CDR-23 has only one black optical cable and PCM has 2 on the rear one for the NAVI DVD and the other the radio antenna [2nd thing] You have to check under passenger seat for NAVI DVD location [3rd]...
  5. Good to know - thank you. Can you provide the part number for the antenna and the cost please Thanks, Simon Ok Simon, here all go: :jump: Pictured below is the GPS OEM antenna... Here's the Volkswagen Part Number [7L5 035 507 A] as seen on the GPS metal base sticker.... Here's the Porsche Part Number [955.647.107.01 or 955 647 107 01] as seen on the box from manufacturer.... I wrote down the numbers because Images, sometimes, are not displayed... I bought this item at www.ecstuning.com for around $79.00 [not including Shipping & Handling] Hope this helps better to everyone in the future... SithPitt
  6. This is an old post, but I recently had a similar issue. With Durametric you will go to the coding tab for the Level Function and calibrate... The sensor which does not accept your coding is the sensor which is bad....
  7. Finally SOLVED! :cheers: It was the GPS Antenna! I replaced the unit in the Rear Lid Spoiler, but nothing! So I proceed to apply the 1-4-8 code and VOILA! :jump: :thumbup: :cheers: It worked!!! So I guess that if you have NO Satellites and applied code 1-4-8 and still no Sats after check connections, then you got a bad GPS Antenna unit. Finally if you install a new GPS antenna, then apply code 1-4-8 on the PCM unit to reset and PCM to recognize new GPS Antenna. Here are today's picture with finally NAVI Unit fully working. I still got the warning triangles on the SW versions, but at least I can use the NAVI now! Thanks and hope this could help others.... SithPitt
  8. No. I did the 148 & Fuse trick. Didn't work. I bought the GPS Antenna and waiting for its arrival...I'll notify whatever results when I install the new antenna... Thanks anyways :thumbup:
  9. Yes, Loren. I checked that several times and nothing at all... Step by Step.... Yes I checked pass door and same behavior.... I guess PIWIS then is the only solution... I spent like $600.00 on eBay for the Durametric... It's beginning to be considered to be re-sell :-(
  10. Yes I switch left right middle nothing, but door lights doesn't lit either... Just work if I put the key on the ignition
  11. Everything? Well the radio and CD were working... The NAVI put me on Colombia, when I was in Puerto Rico... Beside that... Normal...
  12. Thanks for the reply, but even before the update. The Cayenne had that issue. It was on SW1 and still had the silly symbols...
  13. Hello! My 2003 Carrera 4s has something tricky. It's a 2nd hand car... When you open the door the car's dome light does not lit, nor the doors... But if I put the key on the ignition the it turns on, both: Dome and doors.... I checked all fuses and they're ok... A relay removed perhaps because of the buzzer or something? Any ideas? Thanks in advance!
