elsenorfon
About elsenorfon
  • Birthday 04/04/1980
Contact Methods
  • Website URL
    http://
  • ICQ
  • Interests
    Soccer
    Natick, MA
    2002 Boxster S
    NHP Muffler
    Turbowerx headers
    Toyota Celica GTS
698 profile views
elsenorfon's Achievements
  1. This thread has been incredibly informative, a big thank you for everyone involved. Cheers
  2. I also have the B&M and am glad I got it. VERY tight shifting, which is how I like it.
  3. yeah it looks slightly off. how do you go about reseating this? ive pulled and pushed and cant figure it out :(
  4. Just a couple days ago i got an error message saying "failure spoiler control." when i got out i noticed half my spoiler was still up. I can manually lower the whole spoiler, but i can only raise the left side. The right side refuses to move it seems. I checked fuse D7 and it's good. I've pulled the fuse at this point becuase it's embarrassing going down the highway in my beautiful car with half a spoiler lol. But now of course the rear trunk wont open without that fuse. Any ideas as to what's causing this and if it's fixable? I'm bummed :( I'm on the highway every day going over 75.. Many thanks for any help
  5. The problem didn't START with the flash, it STOPPED with the softronic tuned flash. I was worried that it was only masking the problem though. Great idea with the butane! thank you very much for the help
  6. P1115 : "Oxygen Sensor Heating 1 Ahead of Catalytic Converter - Below Lower Limit" and P0134 - 02 Sensor Circuit No Activity Detected (Bank I Sensor 1 The trick is I'm getting no CEL anymore since flashing my ECU with Softronic update. I'm guessing the tuned version doesn't check o2 sensors or something because this was impossible to get rid of before. So I'm worried I still have an air leak in there that I need to find :(
  7. I have been throwing o2 sensor codes and even after changing the o2 sensor twice (passenger side pre cat FYI) I was still getting the error codes. From the research I've tried to do this could be indicative of an air leak in the intake lines. I have no idea how to check for leaks. It makes a kind of "woosh" sound when I rev the engine and the engine bay is open, but that's all I know. Any advice on this? I have changed the throttle body (techno torque) so maybe the seal isn't as good now? Thank you in advance, Kyle
  8. Fuse E6 took care of it, you guys are gods among men :) thank you
  9. according to my fuse diagram E6 is telephone..but there's no fuse in that slot. am I reading this wrong somehow, or is E6 really telephone? that seems unhelpful lol
  10. I just took my 2002 Boxster S out for the summer after putting it up since September. It worked fine when I put it up..but now when I try to fill my gas tank it gets about .4 gallons and then spits out. And I mean literally spits. It bubbles and spits, like there's some kind of pressure pushing it back out. Air pressure it seems. According to my ticker I can drive 0 miles before I run out of gas so I need to figure this out NOW! :( this is very frustrating, please please please help if you have any idea. I saw on the FAQ about the filler flap problem, but this seems different since I get more than .1 gallons in and because of the air pressure pushing it back out, but maybe I'm wrong. Many thanks in advance
  11. Hi, so this headers are without cats correct? Did you installed both 02 sensors? Did you get a CEL? The front cats are taken out. I moved both o2 sensors downstream after the 2nd cats. CEL is all set once you move them.
  12. $799 for the headers, they're not on eBay, I ordered directly through turbowerx
  13. FIXED! Fuse C3 was the culprit. Agh that was so easy I'm pissed :) Thank you everybody for the help though!
  14. Anybody live in the Framingham/Boston area?? I really need help with this badly and obviously would drive to you. Please?
  15. The only reason I don't think fuse is because the windows still *work* when opening the doors, but i'll check them in case. What kind of diagnostic tool do I need and where would I get it? I'm very new to Porsche. Thank you!
