odix
Contributing Members-
285 -
Last visited
Days Won
1
Classifieds
Everything posted by odix
Temporary spare wheel/tire part numbers and installation directions Part numbers, step-by-step instructions and photos with details in the attached .jpeg. This is a basic task -- with the only catch being the spare wheel and tire are surprisingly heavy. Keep that in mind as you will need to lift and move the wheel/tire around. And you'll also need an air-compressor to use the spare. It's default storage state (to save space) is deflated. Turbo/Turbo S models (and folks with the air suspension option) have a built-in air-compressor -- the manual has details. If Author odix Category Cayenne (9PA, 9PA1) - Accessories Submitted 12/13/2012 01:06 PM Updated 03/18/2013 09:35 AM
No hold-down for spare
odix replied to Natty's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
And for other folks looking for details on the temporary spare I added a tutorial in the, Cayenne (9PA, 9PA1) - Accessories section. Tutorial has part numbers and step-by-step instructions. http://www.renntech.org/forums/tutorials/article/296-temporary-spare-wheeltire-part-numbers-and-installation-directions/ -
Part numbers, step-by-step instructions and photos with details in the attached .jpeg. This is a basic task -- with the only catch being the spare wheel and tire are surprisingly heavy. Keep that in mind as you will need to lift and move the wheel/tire around. And you'll also need an air-compressor to use the spare. It's default storage state (to save space) is deflated. Turbo/Turbo S models (and folks with the air suspension option) have a built-in air-compressor -- the manual has details. If no built-in air-compressor in your vehicle spec (like me, I have spring-suspension), you'll need to travel with an electric air-compressor. I have a small one and it's fine. Cayenne Spare Tire Kit Installation Guide.pdf
It's surprisingly simple. You can see where the collapsable spare (rim) mounts to the vehicle in your manual. I bought the rim and tire on Craigslist and then ordered the mounting parts. Less then $20 for the parts. View this Renntech thread for more info: -
Hi Steve -- what you describe is normal. I see it on my Cayenne ('04 S) and in a relative's ('04 Turbo). The most recent temp when you kill the ignition is stored and also the vehicle is well insulated and has a lot of heat storage -- be it the vast oil amount or metal in the engine compartment. I noticed in cold (sub-zero) weather, parked outside, the issue is not present for long -- the temp display reflects reality quickly.
Hi -- Make sure your headlights are fully seated. You press the light housing in with considerable force and tighten the locking bolt until you hear a "clunk" which sounds somewhat disconcerting -- almost like a cracking plastic noise. You can search this forum for more detail on headlight seating/mounting and un-mounting.
Another door lock problem
odix replied to the head's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
When you use your key (physical key in the door lock) does the same issue occur? Which rear door? Behind driver or passenger (US or UK vehicle?) The 8mph locking issue may be tied to your settings -- you can disable the auto-lock-at-speed feature. Be sure it's disabled and see if the issue resurfaces. (It's triggered at 4mph, not 8mph, but it always seems to take place when going faster then 4mph to me.) See attached page from the '04 Manual, p. 109.) -
Part arrived today -- using my thumbnail I gave the button a serious tug and out it came. Comparing the old button to new I could see what had worn out/broken off. New button lined up and slipped in with moderate finger pressure. All well. Button works fine now, odometer resets each time the button is pressed. The team at Sunset Imports are really, really good. Great prices, fast shipping, good overall communications.
I have the same issue, odometer reset button does nothing. I ordered a new one. (Sunset Porsche has it: the trip reset button is $25.98 part 955-641-070-00.) I've been pulling on the old part using my fingers only and it does not seem to budge -- I have not put a huge amount of pull/pressure but it makes me nervous. For you guys that have done this: how much pulling does it require to pull the button free? Did you use your hands-only or pliers? Please let me know, any info would be much appreciated. Thanks.
A Durametric may be a good purchase for you to pull the codes. Will save you the drive to a dealer. http://www.durametric.com/default.aspx
Plug-in a CTEK when you park overnight -- see if it makes a difference. Do it for a week or so. The point deilenberger makes about about your short trips is a good one. Over time, you simply may not be giving the battery enough run-time charge. CTEK is an OEM for Porsche. I use the model 3300 in my '04 Cayenne S, single battery. (I bought the cigarette lighter plug attachment so I don't need to pop the hood to charge.) http://smartercharger.com/battery-chargers/#CTEK%20Multi%20US%203300
New screen -- great find Scarpoolla. Please update us once you have it installed. (I'm wary of the dash disassembly task to get to the console but if patient and careful it looks doable.) I was fantasizing that a good electrical engineer could map data signal output to a similar-sized color TFT/LCD. Everything is possible but the complexity would be significant -- in fact I'm sure the signal could be routed to an iPod...but I know who wants an iPod shoved in their console. So much for my "all stock" sentiment. I'll just have to deal with my hot-day fade display until a solution surfaces. PS -- I'll split the cost of the shipping your old screen to Canada with you. No problem. Just PM me the amount and I'll send it to you via PayPal. You're a huge help to the community. And a crazy idea: do the 9PA/9PA1 Cayenne Turbo console LCDs use the same cables? If so, that LCD might be cleanly mountable in our Cayenne/S consoles... The Turbo LCD's are available for sale for cheap. The console frame could be adjusted. Turn signal indicators may be blocked... Here are the consoles: 1. Cayenne/S, 2. Turbo/S, 3. an overlay of the two -- you can see what they look like on top of one another. It looks like the Turbo's screen would fit inside the turn signal indicator span in the non-Turbo console. If it's the same cable and the screen can be properly paced in there then wow, I'm on board. We'd still have our turn indicators visible and we would not loose the amperage gauge for a non-functional turbo boost gauge.
Update: I heard back from the Italian company. No luck. From: Lisa Zotti <lisa@minitools.it> Date: April 10, 2012 11:49:48 PM To: odix Subject: R: 2004 Cayenne S multifunction display, (possible part number: 5621-40 207) Dear Sir, we don’t have the article required. Thank you Cordiali Saluti/Best Regards Lisa Zotti SAVI ELETTRONICA S.r.l. Società unipersonale C/da Popoleto, 14/B 70011 - ALBEROBELLO (BA) Italy C.F./P. IVA/N.I. Reg. Imp. Bari: 05948750723 Cap. Soc. € 20.000,00 i.v. vendite@savielettronica.it Tel. +39 080 4324023 Fax. +39 080 4327154 Questo messaggio è da intendersi esclusivamente ad uso del destinatario e può contenere informazioni che sono di natura privilegiata, confidenziale o non divulgabile secondo le leggi vigenti. Se il lettore del presente messaggio non è il destinatario designato, o il dipendente/agente responsabile per la consegna del messaggio al destinatario designato, si informa che ogni disseminazione, distribuzione o copiatura di questa comunicazione è strettamente proibita anche ai sensi del decreto legislativo 196/03. Se avete ricevuto questo messaggio per errore, vi preghiamo di notificarcelo immediatamente a mezzo e-mail di risposta e successivamente di procedere alla cancellazione di questa e-mail e relativi allegati dal vostro sistema. ___________________________________________________________________________________________ This message is intended only for the use of the addressee and may contain information that is privileged, confidential and exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this e-mail in error, please notify us immediately by return e-mail and delete this e-mail and all attachments from your system. > Da: odix Inviato: martedì 10 aprile 2012 17:58 A: Lisa Zotti Oggetto: 2004 Cayenne S multifunction display, (possible part number: 5621-40 207) Hello. Do you have LCD replacement screens for the 2004 Porsche Cayenne S multifunction display? It's an orange monochrome display, not color LCD. It is located in the center console between the speedometer and tachometer. Here are some pictures of the part: http://www.renntech....play-fades-out/ There are many people interested in purchasing this part. Please let me know. Thank you.
I did not see 955's on the Palo Alto Speedo's supported vehicle list but I just called them and spoke to a guy -- he said it's a $1,200+ job for a 2004 Cayenne S. Basically a console swap. He said he's heard, many times, about people trying to repair the screen by itself but did not know the answer or if it worked or not. He was a nice guy but skeptical about a screen fix without replacing the entire console. From what I understood they have never done this repair -- most people simply pay the big money and replace the console and then have it recoded. And for the Italian supplier, I just emailed them (if they respond I'll will update this post): From: odix Date: April 10, 2012 8:58:22 AM To: info@mte.net Subject: 2004 Cayenne S multifunction display, (possible part number: 5621-40 207) Hello. Do you have LCD replacement screens for the 2004 Porsche Cayenne S multifunction display? It's an orange monochrome display, not color LCD. It is located in the center console between the speedometer and tachometer. Here are some pictures of the part: http://www.renntech....play-fades-out/ There are many people interested in purchasing this part. Please let me know. Thank you.
Scarpoolla -- you are awesome -- excellent write-up, photos and research. Thank you for your efforts and contribution. I agree with you -- if we all pool our info and resources we may be able to find a solution. Even though our vehicles are getting old there must be, to your point, a screen supplier somewhere and/or a repair facility. Replacing the entire console seems ridiculous and a lot of hassle. LEDs usually last -- I have no science behind this statement, just overall experience with LEDs in general. When I look at my screen the backlight seems uniform which leads me to believe it's the screen only, not the LEDs/backlighting. Are you are planning on replacing your original console screen with the one you purchased -- install it in your existing console? But as you say, if you go to the effort to remove your entire console why not place a Turbo console in there? (But I happen to like to keep things stock and having a non-functional boost gauge would be a bit odd to me.) Plus, if we can determine a screen source then it should be a lot cheaper to replace the screen-only. I found a Canadian guy (small company) who fixes/replaces similar screens in VW Touaregs but he is not set up (yet) for Cayennes. The good news is these people exist and are thinking about Cayenne screen repairs. The company is: www.pixelfix.info My correspondence with Pixelfix: From: Pixelfix Contact Us <contactus@pixelfix.info> Date: April 07, 2012 7:48:37 PM To: odix Subject: RE: Message from Pixelfix.info Hi, At the moment we are not ready yet to process these clusters , due to lack of equipment and software for live testing on the bench. Apologize for any inconvenience. Paul Wojcik -----Original Message----- From: odix Sent: April-07-12 8:38 PM To: contactus@pixelfix.info Subject: Message from Pixelfix.info Hi -- I have a 2004 Cayenne S (Porsche but very similar to VW Touareg). My multifunction display is fading. I can pull the cluster and ship to you. Do your do this repair? Please let me know. Thanks.
My 2004 Cayenne S multifunction display is now starting to fade a bit -- today was a hot day and it was obvious the display is fading. Gear selection is dim as in the miles-per-hour readout, bottom rows of pixels. Classic symptoms of the display fade. Thanks to cwingert's above post I located the replacement lighting transformer part for $42. http://www.keyecu.co...ods.php?id=1717 The site sates: "Mainly to repair this dashboard you need replace defective lighting transformer to a new one." Makes sense to me -- I would rather spend $42 then do a lot more. If it works, excellent, if not it's only $42. (And the hassle of tearing the dashboard apart...) Pulling the console may not be as brutally complex as I thought but...has anyone replaced the lighting transformer on a failing multifunction display? Also, I found this -- same part, different seller: http://www.codecard....r/prod_332.html
And it was more human error then Porsche engineering: "...it determined some units were not being properly locked into place either at the assembly plant or by dealers." The headlight housing hardware and locking mechanism work -- it's just that headlight housings need to be installed correctly in the vehicles. I suppose the design and instructions could have had less margin for error (forcing an person to confirm the light housings are properly seated; a safety tether, etc). Generation 1 and 2 Cayennes (9PA and 9PA1) have a similar mounting and install process -- and we all can read here on this forum that those light housings have to be pressed in and the mount bolt turned until "clunk" is heard. That said, it's probably somewhat disconcerting to have a headlight fall out while driving.
navigation issue
odix replied to colinmartin's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
Is the address you are entering in a different location (map range) from the CD you have loaded in PCM? Here in the US, for long road trips, I need to change CDs on ocassion as I travel out of the CD-map region. I have an '04 Cayenne S, CD-based PCM, and I can't load all the map CDs in the system at once -- you need to keep the CD map of the current region always in the PCM CD-player -- for the region you're in. Then you change CDs as needed. So if you're in Bucharest and enter a Paris address the CD would need to be changed. Hope this makes sense. -
Sunset Porsche sent the parts (really fast service by the way) -- Sunset is awesome. 15 minutes after opening the box, all fixed. Thanks again to all in the thread for overall info and to RFM for the specifics. Update: for those of you with the same issue, I posted a DIY with pictures and basic description of the steps. In the Cayenne (9PA, 9PA1) - Common Fixes and Repairs DIY section. http://www.renntech.org/forums/tutorials/article/269-2004-cayenne-s-center-ceiling-panel-melted-housing-repair/
The amount of melted plastic housing around my switch apparently made it too difficult for me to epoxy and properly line-up the tabs so I PM'd RFM and he gave me some tips on what to order. The folks at Sunset Porsche are shipping me a repair kit (Renntech.org discount). > Thank you for your inquiry with Sunset Porsche Parts. There is a kit for this repair. It may come with a couple extra pieces but the only way to get the parts you need is to order the kit. With your discount pricing, the kit is currently $83.24 (plus shipping to get to you). Once you are ready to place this order, we could get it from the warehouse, which usually takes 3-5 business days, and then we can ship it to you. Since we are a Porsche dealership, these are genuine factory Porsche parts. > Once I have the parts and have it repaired I'll post an update. And if anyone wants pictures let me know and I'll put together a DIY document. Thanks again all.
