BobMarley
    Old Town Alexandria Va
    2000 VW Passat V6
    2002 Porsche Boxter
BobMarley's Achievements
  1. Hey people, I tried searching but can't find a mechanic shop in Virgina that somewhat specializes in RMS repair for the Boxster. I remember they were located somewhere in southern Va, any assistance would be appreciated. TIA
  2. Fixed! Thanks Cassie, I swapped actual bulbs and voila, I had low beams. Went out and bought some bulbs and put them in. The strange thing is that the driver's side bulb looks fine(the one I was actually/initially testing), so that threw me from the get go. I'll remember the swap method in the future! thanks for everyone's help.
  3. Okay, just swapped the fuses, same thing. I did notice that my side marker lights are not working either... maybe a clue? I'll try swapping the bulbs. Thanks!
  4. Replaced the headlight switch, still a no go. Any other ideas? thanks!
  5. Hi Loren, Thanks! I'll look up headlight switch!
  6. Hello, From what I found online, here and pbb, I replaced my ignition switch, but my headlights still don't work. Background: Started my car, switched on my headlights, came on for a brief moment, then they went off. Jiggled the ignition key, to see if they came on at all, nothing. Checked fuses, A slots 3 and 4, fuses okay, are the fuses that I'm checking even the correct ones? Checked the bulbs, they are okay. Changed the ignition switch, same issue. My high beams and fog lights work... Now I'm at a loss. Any insight? Thanks!
  7. sweet, great directions, thank you!
  8. Thanks again, did it yesterday, 3 bars instead of barely 1, strange... Had some issues with the arm and the wiper motor arms(scraping), but a little bending and it's all okay now. cheers!
  9. Then noise are the control arms, check fleabay, for some aftermarket ones.
  10. Thanks for this... Question: How did you mount the low profile antenna to the mounting arm? Did you use the tape that is on the antenna?
  11. Hey CJ, how are the arms holding up. Also, March has come and gone, and DelubozParts doesn't have them up for sale yet. Any ideas?
  12. Great write up! Question: Why didn't you go for the higher/10,000k ones? Whiter/bluer light, right?
  13. looks good to me Thanks Toolpants
  14. So sweet, hmmm, do I need a new top....? :D Any pics of it up?
