hucqym
About hucqym
Contact Methods
  • Website URL
    http://
  • ICQ
    San Francisco, CA
    Boxster 986 (2001), 5-speed manual, grey
    DIYs:
    Brakes/pads replacement
    Waterpump replacement (twice)
    Clutch replacement
    IMS replacement (LN kit)
1,105 profile views
hucqym's Achievements
Community Answers
  1. no reference, really. I wasnt able to measure a voltage using my multimeter at the battery connector tab so thought about another way to get access to the battery connection. Suspected OBD port might have it and checked the pinout here https://en.wikipedia.org/wiki/On-board_diagnostics Pin 16 is battery+ and Pin 4/5 is ground. On the durametric adapter pin 4/5 is shorted together.
  2. just wanted to update the thread with my solution: I finally tried the OBD route and that worked. opened my durametric adapter and soldered wires to battery and ground connections. Connected the jumpstarter battery to that and popped open the trunk. It seems that either my battery pullout tab in fusewell is busted or the chassis ground doesn't work well when battery is too low. Even the OBD solution didn't work when I connected to the door lock hook instead of OBD ground Hope somebody else finds this useful. Note: Needless to say but a gentle word of caution for the noob, DO NOT try to jump-start with this connection. Use it to just pop the hood.
  3. Hi Mike, . Yes that was my guess with ctek given it tries to detect reverse polarity and so i got a jumpstarter kit that i tried with the red-pullout and C3 and neither worked. I had already taken a look at your website and as outlined above I have tried it or it is not applicable to my 01 boxster. emergency release cable not accessible and i wasn't able to directly unlatch mechanically by inserting a small tool in the gap. I didn't have a multimeter handy so haven't checked voltages at cig lighter, C3 or red-pullout so that is up next. Is there anything else that might be messing with me other than a dead battery? Immobilizer or something else? thanks
  4. My 2001 boxster was parked in a garage for over 4 months while I was abroad. The alarm went off a couple times and so my brother unlocked it using the key manually and kept it that way. Apparently that helped with the alarm. But now when I returned battery appeared to be completely out so I proceeded to connect an external battery using red-pullout in fuse box to pop the hood. That didnt help. I have successfully used that approach multiple times in the past. I browsed through the forums and tried the couple other techniques as well but nothing works. To summarize: All electricals are off! 1) Pull out red-tab in the fuse box and connect to external battery. Kept it connected for about an hour as well but hood doesnt pop 2) All fuses look good. Connect external battery positive to a small piece of wire wedged into C3 fuse. No luck 3) Connect a CTEK battery charger to cigarette lighter but it doesnt seem to start the charging process as it probably doesn't detect a battery 4) Looked for the emergency release cable in the front passenger side wheelwell but can't find it. Looks like I wouldn't be able to access it without removing the headlight assembly 5) No flooding or dampness under the seat that might have possibly blown out the immobilizer either. Any clues what might be the issue? Perhaps the immobilizer has disabled the system?
  5. thought I should update this. It did turn out to be a silly 2c part that needed replacement. (Ofcourse the replacement kit costs orders of magnitude more than that, but still significantly cheaper than waht porsche wants me to replace) See this other DIY article and that was the exact part I had broken as well. http://986forum.com/forums/diy-project-guides/45967-how-fix-broken-lock-cylinder-20-dollars.html Must note, however, that the ebay part is of pretty cheap grade and I am afraid it might have a short life too. I'll try to find a genuine audi replacement part somewhere if I can.
  6. the door lock on my 2001 boxster broke and i took things apart. Seen various posts on broken doorlocks and folks have had different failure mechanisms and so I decided to just share the video of my failure mode to determine the best fix. The door lock part itself seems to be okay and the plastic connecting piece to the handle etc.. seem fine. The key mechanism seems to be the culprit. The key rotates 180degrees freely without any resistance and the metal piece does not rotate. But if I rotate the metal piece itself then I can get the key to correspondingly rotate. Please tell me I am just missing a silly <$20 part that I can easily replace. It would suck to have the whole assembly replaced.
  7. so my understanding is that the P0xxx codes are the standardized codes and mandated by law while P1xxx are the additional porsche specific codes. Does that mean that smog check will pass the OBD functional test even if P1xxx codes are present in memory (w/ or w/o CEL on)?
  8. Thanks Maurice. Sounds like going the bleeding route is the cleaner/easier route. So I'll -> attach a drain pipe on the bleeder and open the valve, -> push back the pin (hopefully now it will stick there). -> install and bolt the slave cylinder. -> Close the valve. attach the power bleeder with fresh fluid in it, pressurize and then open the bleeder valve again to get all air out, correct?
  9. Alright! so finally closing in on this task! :) Managed to get the bearing in (had to use a regular hammer instead of the deadblow mallet and it went in like butter). Engine buttoned up and timing checked by manually rotating and using cam lock to verify alignment. All looks perfectly lined up. yay! keeping fingers crossed till I can get to fire it up! Now the tranny is back in and I am struggling a bit with the slave cylinder installation. I had left it tied up still hooked to the fluid line and now it is a struggle getting it all the way in to bolt it back up. It measures about 64mm from the edge of the plastic sleeve to the tip of the pin, when idle. I can push it in smoothly by hand as shown. Is it just a matter of struggling and seating it back in or am I going to have to open bleeder valve and then do the bleeding work etc... Would much like to avoid that task now if possible since I am in a little hurry.
  10. So the LN instructions that I received along with the kit are slightly updated (Rev14 June12) than the one JFP linked to. I have attached the scanned copy here and hope LN does not have issues with that. Its talking about locking cam on bank-1 ONLY. So i guess my concern about not being able to lock both cams while pulley locked in TDC compression was unnecessary. This fine DIY article by "insite" also mentions "Engine @ TDC compression for aligning timing marks on bank-1 and TDC-exhaust for aligning timing marks on bank-2". Let me know if I am missing something here. To summarize, here's what I did: 1) Lock engine at TDC compression (notch on intake cam on bank-1 pointing roughly outwards) 2) lock cam on bank-1 (drive belt side) using the 5-chain lock (shorter one) 3) used a little shim and MODIFIED longer-cam lock from the LN kit to "kinda lock" cam-2 as well at a slight angle. (although this wasnt required as per the new instructions from LN) 4) Removed all three chain tensioners (the new instructions makes the removal of the third chain tensioner optional) 5) Removed the old bearing using the LN removal tool and it came out without too much fuss. yay! :) Now I have some trouble getting the new bearing in. Most procedures say light tapping will do it but not in my case. Did freeze the bearing with install tool overnight but it still wont go in. Is my attempt to lock the bank-2 cam as well causing some unwanted tension? should I take that out? The intermediate shaft does not appear completely centered and I wonder if thats the reason why the new bearing wont go in easily? IMS install procedure.pdf
  11. so this is before loosening the chain tensioner or removing the bearing flange. The car was running fine till i pulled it in for this job. Is it even possible that I manage to get the cams out of timing while removing transmission/flywheel etc...? Or is it possible to have the engine running ok with the timing off? Is there a tolerable margin on that? too bad i forgot to get a reading on the timing using my durametric before starting.
  12. I guess both are not "dead vertical" simultaneously. If Left is dead vertical (locking tool sitting properly), the right one is a little off. If I then rotate pulley by 360deg and then lock it - right is dead vertical and left is a little bit off. When I say it is a little off, it is only a guess - because if I look or just hold the tool by hand, it feels vertically aligned but when I try to fasten the tool it slips out at the end.
  13. so I do have this complete kit and did modify the 3-chain one a little to make it similar to the 5-chain one. I can use them interchangeably now. But i guess the modification that item#6 is mentioning is a little different. I still cant lock both pairs simultaneously. Keeping engine locked at TDC, I find I can lock the Right camshaft while the locking tool slips out of the left as soon as I tighten it. If I rotate by 360", I can get it to sit properly on left camshaft but now the right one slips out. Look at this video thats talking about an offset and modification to lock both pairs simultaneously. This video is talking about 911 but I guess I have the same issue. Jump to 1:36 on the video Would've been so much nicer if LN sold the kit with the modified 5-chain lock instead of giving me a 3-chain lock. (and a similar kit for the 3-chain model). Especially given the fact that this kit sells for a couple hundred bucks! :(
  14. Firstly, THANKS JFP for your prompt responses, as always! :) Now to lock the camshaft on my 5-chain 01' boxster, I need some tool as shown in the attached image. The LN kit that I bought has only one. Any idea where I can another similar one. I sure hope I dont have to buy the more expensive ($200+) timing tool just for locking the camshaft or another kit. Also to clarify, on my 5-chain configuration, timing slots are on the exhaust shaft only, right? Also whats with the mention about modifying cam lock to be able to lock both pairs simultaneously. It seems like if I had another tool of the same type shown here, I would be able to lock both camshaft pairs simultaneously.
  15. so without using the set screws, but keeping both camshafts locked, will the IMS mostly stay centered or would I have to deal with that aligning when I try to reinstall the new bearing?
