bud22405
About bud22405
Contact Methods
  • Website URL
    http://
  • ICQ
  • Yahoo
    bud22405
    Fredericksburg, Va.
    95 LS400 (225K miles)
    01 996 Cabriolet
    01 Toyota Highlander
    07 Toyota Tacoma
    98 Honda Accord (for daughter use)
  • Future cars
    LS 460
    Electric? high milage
    maybe a (911 Turbo if I can stop the tickets
    BMW 325
    Datsun 2000 Roadster (my all time favorite)
bud22405's Achievements
  1. In replacing the corroded battery cable on my 2001 Carrera cab, my mechanic noted that the starter bolt in the 1 o'clock position continues to turn on itself and will not remain fixed for tightening (see circle in photo). Any idea on the cause? The car just went over 100K so while everything is exposed I'm thinking of replacing it, the AOS, plugs and coils along with leaking cam cover seals. The water pump and belt are new...anything else to look at or replace on a 100K engine? It has original IMS and RMS with no sign of leakage.
  2. got my first one at 58. In response to her joking that it was 'another" mid-life crisis, I said "Well it's better than a blonde" and without missing a beat she responded: "...and it's cheaper, too!"
  3. The front fender is from ?? and you paid ???
  4. i had this samr floaty unstable experience at speeds over 80. I had khumo tires. when i switched tp Michelin ps2s and put 14mm speaces in front and 7mm in rear feeling went away. don't know which was the factor, probably mostly the tires
  5. nope, no wing. i'll take it in for an alignment
  6. I'm sure the tire pressures are ok, the tire brand i'm not sure of. i thought maybe an air dam or lowering the car was the common solution but i'm beginning to think it's just the difference i feel between a heavy car and the porsche. i will check the front end next time it's on the rack. thanks!
  7. 01 Tiptronic C2 Cab- 62K Kuhmo Ecsta SPT XL tires 6k miles Newbee here to both Porsche and this site. When either accelerating rapidly to say 90 or so and even when staying around that speed for some time, my 01 996 Cab seems very light in the front end. The steering gets very loose and somewhat scary. :o The car just doesn't feel "planted" or stable My other car is a big heavy LS430 and it is very solid to 100+. The cab is entirely stock US. Is this to be expected in a 911, does it require a "dealer" visit, or what is the best inexpensive fix (besides slowing down) that might correct this "problem, if it is indeed a problem? The car is otherwise fine.
  8. i've run my 95 LS400 on 87 octane for 10 years with zero problems other than reduced power.
  9. which mod did you get the I or II...i'm really interested in the louder modII. also how's the interior cabin noise with yop up?
