BobbyBBB
About BobbyBBB
    Spain
    996C4 99'
BobbyBBB's Achievements
  1. I have a 99 C4, and the factory design says: 7,5Jx18 ET50 with 225/40 ZR 18 10Jx18 ET65 with 265/35 ZR 18 and your car must have the same. I have this wheels and the driving is much more better than with the 17" ones. Some wheels dimensions was changed on 2002 for the 18" wheels. 7,5J has become to 8J, and 265 rear is now 285, also the offset has changed.
  2. What do you mean whit "they use S/Steel hose clamps on all the places where the vacuum lines connect or you'll be back many times until they do put them on"? What will happens when he doesn't use s/steel hose clamps? Can you show me a photo about this? Thanks Wardhog.
  3. I had a similar noise last summer, it seems to come from the interior back part of the car. In my case I have a 99C4 Coupe, and the cause was the rubber pieces at the rear sway-bar. After the years they have became too dry, a little grease and noise goes away.
  4. I have the car with 744 color, and buy a retouch pencil to retouch some minor stone damages, but the color provided by the Porsche dealer seams not to be correct :eek: . Could someone tell me the code number of the correct retouch pencil?
  5. You must check the offset number, it's important, not only the width of the whells. Remember that Porsche does many tests to calibrate the dinamic of the car with several whells. To use an non approved dimension could end in a non favorable car dinamic in hard turns.
  6. What do you think about car cover Weathershield from AutoAnything? It's the right for indoor and sometimes outdoor?
  7. I'm also interested in change my steering wheel with Carnewal's one 3 spoke and triptronic. My car is 99' C4 Triptronic. The DIY instructions are the same?
  8. I will tell it to my shop that they activate it.
  9. I have a 99' C4, and in the car's book I have read that it could be programmed that the doors close at a certain conditions, but my porsche dealer says me that in my car it is not possible. Can someone help me?
  10. Hello Loren, Probably you have sent the TSB, but I didn't received it. You know, sometimes the e-mail goes wrong. One friend has brought his car today to the workshop due the RMS and the copy of the TSB could be helpfull maybe. His car and mine are 99'C4. When this problem doesn't go fixed, the 996 could be an expensive car. Thanks in advance.
  11. Hello, Lore, that means that Porsche assume the cost of the replaced engine when that problem appers independent of the gone warranty time, or the cost of the RMS replacement? At the back of the engine of my car you can see it's dirty with oil. Could be I have the problem? Is possible to have pictures and a copy of the TSB? I have buyed the cas as second hand by the Porsche dealer. It could be that the motor is not the original and has been replaced before due to the RMS problem. Iwill check the number number. How can I know the year model of the motor? Thanks in advance.
  12. I have an 99' C4 with Sportclassic II 18" What spacers can I use? 5 mm in all the wheels or only 17 mm at the rear ones? Does it increase performance driving curves, or only better image? Thanks in advance.
  13. Many thanks Loren. You are the Porsche's Bible.
