JonPaul
Everything posted by JonPaul
  1. That worked! Thx Loren.
  2. Hi Loren, So, I got my removal keys today and swapped in the cdr220 but the code 4241 didn't work. So after some thought, I went back and read your 'Read This First' post and went through the Becker 1 serial number retrieval procedure and discovered that the last 3 numbers I gave you were incorrect. The correct info for the radio is: Model BE4462 Serial no. X5030954 Hopefully that will generate a code that will work Thanks, JP
  3. Thanks Loren. That was fast!
  4. Hi Loren, Just bought a CDR220 and the seller said he had the code but turns out, he only had the serial number id card. Model number: BE4462 Serial number: X5030594 Thanks in advance, JP
