sandoval
Members-
23 -
Last visited
From
Laguna Beach, CA USA
Porsche Club
Present cars
01 C2 Aero
Future cars
GT3
Former cars
Supercharged 968
sandoval's Achievements
So I installed the rear set of PSS9's today they are a bit tricky to get in but with the help of a Jack and thick flat head I was ablt to seat the bottom. Again I am hoping I used the right parts since the Bilstein manual SUCKS. I ended up with the shock, spring and rubber/plastic perch on top of the spring. When I went to fasten the top (inside the car) I found that the OEM nut has wider threads so I was not about to muscle it on. Did anyone else have this problem in the guide it says that the nut is reused (Origal equipment) but I just don't feel right about the size of the threads. Can someone post am interior shot for me? I have the thin nut that keeps the adjustin nut in place. So I guess I will go down to HD and find a similar threaded nut. It took me a few hours to do the rear and sways I think this is definatley a 5-6 Hour job for the first timer. I had fun doing it and saved some money to justify other mods!!!
PSS9 Install...
sandoval replied to sandoval's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Well I guess not many people have done this install themselves. I did find it quite easy once I figured out the process. The first strut took me 2 almost 3 hours... The second strut about 20 minutes. I do use air tools so that helps. I did find using a Jack and a pair of spring clamps were very helpful. What took so long? Figuring out how to get the old stut out from under the wheel well. I ended up removing the triangle peice. Also it helps to remove the 10mm bolt that holds the brake wear sensor. It would have been nice to have anther set of hands but it is very doable by yourself. Question I reused a few parts. the Triangle strut top mount, the ball bearing assemply, the coved washer (Said to reuse that part in the Blilstein doc. I have) and the top and bottom brass color disks (one goes under the large top strut nut. Theother goes over the coved washer.) Did I reuse the right parts? I had the strut, spring and bump stop left. I highly recommend this as a DIY project. I can't see paying $600-1100 for this job it is not that hard. I still have the rear and sway bars tomorrow. I will give some feedback on the rear tomorrow. -
I have a few questions before I swap out the suspension. Do I need to depress the coils on the original springs with a spring clamp type tool? I have the car in the air on Jack stands wheels and calipers off so I thought this would be a great time to do the install. Also one of my front struts is missing a Boot (I bought the PSS9's off a member on 6 speed his shop misplaced the boot) Bilstein is on B/O until the end of Feb. Do I need the boots looking at PET it looks like the GT3 does not have boots as part of the front strut assembly can I get away without the boots for a while? Do I need them at all? The install looks straight forward just by looking at the exposed parts. Is there a good DIY guide? Any words of Wisdom? Short Cuts etc. before I do the work this weekend? Thanks in advance.
Torque Specs for Header bolts
Exactly what I was looking fo... Thanks Loren! -
996 505 986 92 add 01C at the end Sunset could not find just... 996 505 986 92
Option Codes (help...)
I answered my own question through a google search... Post 1970 Option List 911/924/928/930/944/964/965/986/993/996 models 001 Carrera Cup Version 002 Touring Version 003 Group N GT1 009 3 speed sportomatic transmission 018 Sport steering wheel with elevated hub 020 Speedometer with 2 scales KPH/MPH 024 Version for Greece 026 Activated charcoal canister 027 Version for California 030 Sports Suspension/Group 031 Sport shock absorbers 034 Version for Italy 036 Bumpers with impact absorbers 042 Martini Racing stripes 058 Bumpers with impact absorbers 061 Version for Great Britain 062 Mud flap, rear (series equipment for Sweden) 062 Version for Sweden 068 Bumpers w/impact absorbers 070 Tonneau cover - Cabriolet 092 911 (993) Turbo S 096 964 Anniversary Version 30 Years 911C4 (ROW) 097 Anniversary Model 25yrs 911 (Germany) 098 Anniversary Model 25yrs 911 (USA) 098 Standard Porsche Leather in deviating colors (Coupe/Targa/Cabriolet and Turbo) 099 Anniversary Model 25yrs 911 (ROW) 103 Adjustment of shock absorber strut 111 Version for Austria 113 Version for Canada 119 Version for Spain 124 Version for France 124 Yellow light (series equipment for France) 126 Digital radio 1982 (911 only) 126 Stickers in French 127 Stickers in Swedish 130 Labeling in English 139 Seat Heating - Left 148 Modified Engine 930/66/S/SL 150 Emissions Systems removed for countries without unleaded fuel 152 Engine noise reduction 153 Engine parts belonging to a stipulated assembly for type 951 154 Control unit for improved emissions 155 Motronic for cars with kats 156 reduced sound muffler 157 Oxygen sensor and catalyst 158 Radio \"Monterey\" - 86 \"Reno\" - 87 159 Motor Sound Package 160 Radio \"Charleston\" 164 Tires 215/60 VR15 167 Bridgestone Tires 176 Oil cooler with fan 182 Safety devices in passenger compartment (944) 185 Automatic 2 point rear seat belts 186 Manual 2 point rear seat belts 187 Asymmetric head lights 190 Increased side door strength 193 Version for Japan 195 Prepared for cellular telephone 197 88Ah battery 198 Stronger starter for Canada (1.7kw) (944) 208 Trailer Coupling 215 Version for Saudi Arabia 218 License brackets front and rear 219 Differential 220 Locking differential (40%) 221 Porsche-locking differential 224 ABD (Active Brake Differential) 225 Version for Belgium 240 Version for countries with inferior fuel 241 Shorter shifting travel 243 Shorter gearshift lever 249 Automatic transmission 251 Automatic Transmission Shorter Gear Ratio, (33/13) for Countries CH, S, Au 255 Fuel consumption indicator 258 Heating for outside mirror 261 Passenger side mirror electric plain 262 Outside mirror for passenger side, plain, manual 269 Additional Headlight 277 Version for Switzerland 286 High intensity windscreen washer 288 Headlight washer 298 Prepared for unleaded fuel, manual transmission 299 Prepared for unleaded fuel, automatic transmission 302 Type designated on rear end 308 Pneumatic spring for engine hood 319 Additional Engine Cooling for hot climate countries 323 Sticker, without ESE-Regulations 325 Version for South Africa 326 Radio Berlin 327 Radio Köln 328 Radio Bremen or Symphony 329/330 Radio Blaupunkt Toronto SQR 46, All models, not for USA 331 AM/FM Cassette w/2 door speakers 335 Automatic 3 point rear seat belts M339 911 (993) Twin Turbo 340 Seat heating Right 341 Central locking system 346 Standard color rims (silver) 347 Platinum anodized wheels 348 Forged wheels Grand Prix White 351 Porsche-car radio, CR stereo, type DE, etc 360 Splash guard corner pieces 373 Left Sport Seat w/ Power Height Adjuster 374 Right Sport Seat w/ Power Height Adjuster 375 Clutch lining without asbestos 377 Combination seat, left, adjustable 378 Combination seat, right, adjustable 379 Series seat, left electrical vertical adjustment 380 Series seat, right electrical vertical adjustment 381 Series seat, left 382 Series seat, right 383 Sport seat - left 387 Sport seat - right 389 Porsche-car radio, CR stereo, type US 391 Stone guard decal rear fenders, added separately 392 Scottish Tweed interior trim 393 Forged wheel 8J/9Jx16 393 Rear fender decals for Turbo model 393 17 Inch wheels (Targa) 393 18 Inch Targa Look Wheels (Coupe/Cabriolet/C4S) 394 Disk wheel, telephone styling 8J/9Jx16 Cast - Magnesium 394 Rear fender decals for Turbo model 395 Light metal wheels forged 395 Pirelli P7 205/50/VR15 front and 225/50/VR15 rear tires 396 Disk wheel, telephone styling 8Jx15 rear 398 Left outside mirror - electric - plain 398 17 Inch Cup design wheels 398 P31 Sports Chassis (968) 399 A/C without front condenser 400 Pressure cast wheels 401 Light metal wheels 402 50 year anniversary car 1982 403 Pressure cast 17\" wheels 403 Aluminum trim strip lower sill 404 Stabilizer bars 405 Level control system 406 50 year anniversary car 1982 406 Front wheel housing protection 1983-1986 407 18-inch polished wheels 408 18 Inch Turbo Look Wheels (C4S) 409 Sport seats left and right leather 410 Sport seats left and right leatherette/cloth 411 License bracket, front 412 External oil cooler 413 18 Inch Turbo Look Alloy Wheels 414 Combined oil pressure and temperature gauge 414 Transmission oil cooler 415 Wider rear track with 21mm spacers 416 Leather steering wheel and shift boot 418 Protective side moldings 418 Aluminum trim strip on wheel arches 418 Protective strip moldings set for 944 418 Protective strip moldings (968) 419 Rear luggage compartment instead of rear seats 422 Blaupunkt Bamberg Radio 423 Cassette container and coin box 424 Automatic heating control 425 Rear wiper 426 Special model 924 World Champion 1976 1978 (Martini) 427 Special model 924 for France only (100 manufactured) 429 Fog headlamp, white 429 Special model 924 \"Sebring\" USA only 430 Rectangular fog light yellow lens 431 Leather steering wheel 363mm 432 Sports steering wheel, leather 363mm (4 spokes) 432 Protective lacquer finish black 434 Work Instructions for cars overseas (924 and 944) 436 Three spoke leather steering wheel with airbag 436 Folding top Targa 437 Comfort seat left 437 Full power seat left 438 Comfort seat right 438 Porsche script on doors gold 438 Full power seat right 439 Electric Cabriolet top 439 Special model \"Weissach\" 1980 439 Porsche script on doors black 439 Folding Top 911 (993) Targa 440 Manual antenna, 4 speakers 441 Fader, antenna booster, 4 speakers 441 Radio speakers and antenna amplifier 442 Prepared for radio without antenna 443 Tinted front and side glass, heated windshield 444 Steel Wheels 444 Cabriolet 446 Parts for type \"Targa\" belonging to stipulated assembly 446 Wheel Caps with colored Porsche crest 18 inch wheels only 446 Chrome Trim Carrera 447 Emergency wheel - with collapsible tire 449 Emergency Wheel Forged 449 Blaupunkt Lubeck radio 450 Alloy wheels, black Carrera only 6JX15 front 7JX15 rear 451 Prepared for sport group 451 same as 450 comet diamant metallic 452 Blaupunkt Frankfurt radio 454 Blaupunkt Coburg radio 454 Cruise control 455 Wheel locks 456 Sport shock absorbers and stabilizers 458 16\" alloy wheels 6JX15 silver green diamant metallic 459 same as 458 comet diamant metallic 456 Special model 924 Weissach 460 same as 458 gray blue metallic 461 Electric antenna, 4 speakers 462 Sekuriflex windshield 462 Special model \"Weissach\" 1982 462 Carrera script on doors, black 463 Clear windshield 463 Lateral glasses tinted, (Series Equipment for Australia) 464 Without compressor and tire pressure gauge 465 Fastening parts for transportation (Series Equipment overseas) 467 Drivers side mirror, convex 468 Graduated tint windshield, green side glass 468 Air compressor 469 Black headliner 470 Without spoilers, in conjunction with turbo look 471 Integrated rear spoiler 471 Sport group 1 471 Carrera RS Sports 472 Additional rear apron 472 Carrera RS Touring 472 Turbo with standard chassis 1980 472 944 Turbo (951) 473 With spoilers 474 Sport shock absorbers Bilstein 475 Brake pads without asbestos 475 License plate fastening (Series equipment Austria, Finland, Australia) 476 Brake pad with abrasive pad 477 Alloy wheels 6JX15 included with 911S 477 Alloy wheels Carrera only 6JX15 front and 7JX15 rear 479 Version for Australia 481 5 speed manual transmission 482 Engine compartment light 483 Right hand drive 484 Symbols for controls 484 Version for USA 1989 and on 485 Forged wheels gold metallic 5.5JX15 487 Connection for fog headlamp with parking light 488 Stickers in German 489 Symbols and insignia in German 490 Hi-Fi sound system 491 Turbo look 492 H4 headlights for left hand traffic 492 2.8 Liter Carrera RSR 494 2 speakers on back shelf 494 Amplifier system 496 Black trim painted headlight rims 497 Self Starter 498 Without rear model designation 499 Version for West Germany 501 Turbo Insignia 503 Cabrio variant (Speedster) 504 RSA Version 505 Slant nose for USA 506 Slant Nose for ROW 513 Lumbar support - right seat 520 Infrared Security system 525 Alarm with continuous sound 526 Cloth door panels 528 Passenger side mirror convex 529 Outside mirror passenger side, convex, manual 530 316KW-330KW Retrofit kits for 993 M64.60/60S/60SN 533 Alarm system 537 Left seat with positrol and lumbar 538 Right seat with positrol and lumbar 545 92 Liter Fuel Tank 548 Fuel filler neck, unleaded fuel with flap 549 Roof Rack 551 Wind deflector Cab 553 Version for USA 555 944S Cabriolet 556 944S Cabriolet 557 944S Cabriolet 559 Air conditioner 560 Detachable roof 562 Airbag driver\'s side 563 Airbag passenger\'s side 563 Automatic air conditioner 564 Without airbag 565 Safety steering wheel 380mm leather 566 Rectangular front fog lights 567 Windshield green graduated tint 568 Tinted windshield and side glass 569 Package M429 Fog Light and M571 rear fog light 570 High output air conditioner 571 Carbon air filter interior 571 Rear fog light 572 Heating 573 Air conditioner 573 210KW Retrofit kit for 993 M64.05/06 576 Without rear fog light 577 Heated and Tinted Windshield 579 Version for Hong Kong 580 Non Smoker Package 586 Lumbar support left seat 590 Comfort Kit 14 inch Fuchs Alloy Wheels 185HR14 tires plus other items 591 Bosch-Teves ABS 592 Brake fluid warning system 593 Bosch ABS 594 Wabco ABS 595 Rear spoiler painted to match body 596 Spoiler painted matte black 597 Heavy-duty battery and starter 598 Insignia \"16 ventiler\" 601 Litronic Headlights (non turbo) 602 Third brake light \"High mount\" 605 Vertical headlight adjustment 607 More numerous cables for dashboard 612 Prepared for Philips C Netz 613 Porsche Telephone Motorola D Netz, Germany only 621 Differing parts for engine 924S 622 Differing parts for cars with 2 V-Engine 630 Police equipment 635 Park Assist system 637 Club Sport Model 638 Turbo Cup (944) 639 928 GT 642 Additive for cooling water 650 Sunroof 650 911 (993) Targa Sliding Roof 651 Electric windows 652 Intermittent Wipers 652 Delete Sunroof 655 Electric Folding roof control (944) 656 Manual Steering 657 Power steering 659 Front Fog Lights (1979) 659 Onboard computer Carrera 2 662 PCM Navigation System 666 Without lacquer and chrome preservation 673 Prepared for lead sealed odometer 675 Instrument cluster technical lighting 680 Digital Sound Package (Turbo) 684 1 piece rear seat 685 Divided rear seat 685 944 luggage boot cover 686 Radio \"Ludwigsburg\" SQM with arimat 688 Blaupunkt Boston Radio 690 CD Player CD-10 with radio 691 CD-Player \"CD-1\" with Radio 692 Remote CD changer (6-disc) 693 Blaupunkt London Radio 696 AM/FM Radio with CD 701 Car-version Slant Nose 702 930/66 Engine 715 Control PV-U production pilot run (944) 718 R program VIN Change for May 1993 Models for USA/Canada Only 718 S program VIN Change 719 Special reconstruction (944) 734 PV-O Series engine (non series) (944) 735 PV-O Series transmission (non series) (944) 754 Turbo Cup (944) 755 Special model 924S for ROW 1988 Le Mans 756 Special model 924S USA 1988 Le mans 757 Special model 944 1988 758 Special model 944 Turbo 1988-Turbo S 780 Remove safety certificate 900 Tourist delivery 912 Vehicle without identification plate 925 Version for high altitude areas in the US 930 Seat cover rear LLL 931 Seat cover rear KKK 932 Seat cover rear SKK 933 Seat cover rear SLL 934 Seat cover rear SSK 935 Seat cover rear RLL 945 Seat cover front SKK 946 Leather/leatherette seats 947 Seat cover front: cloth/leather/leatherette Seat cover rear: cloth/leather/leatherette 948 Seat cover front SLL 974 Luggage boot cover 975 Velour carpet in luggage compartment 980 Seat cover Ruffled leather 981 All leather lining 982 Soft leather Look Seats 983 Leather seats front and rear 985 Parts silver colored 986 Partial leather lining 989 Left and right sport seats cloth 990 Seats all cloth C00 Eurospec emissions C02 Equipped with catalytic converter C03 California type car C10 Swiss 911 Version post 1986 with Kat C16 UK Version C36 Canadian Version C72 Swiss 944 Version pre 1986 without Kat E0 Wood dash and door panels E03 Leather dash vents E04 Leather instrument knob and switches E07 Leather shifter and handbrake E11 Leather console and tunnel E12 Carbon fiber console E13 Leather power seat switches and frame E15 leather seat belt locks and housing E21 Aero Kit (non turbo models) E22 Aero Kit (turbo models) E70 Leather package E71 Maple Burr Package light E72 Maple Burr Package dark E73 Carbon Package FLY Air Transport from factory L1 Leather interior (Non-turbo coupe) L1 Leather interior (Cabriolet) P02/MP04 Stereo w/CD Player (Coupe/Targa) P08 Active Limited Slip Differential P12 Options 418 +494 + 650 P14 Heated Seats P15 Full power seats left and right P31 Sports Suspension with two 17 inch wheels P32 Sports chassis with 18 inch wheels coupe P36 Special chassis 17 inch wheels Targa P39 Digital Sound Package (Non Turbo) Includes M490 P49 Digital Sound Package (inc M490) P65 With sunroof P77 Leather sports seats P86 Velour Mats R01 Touring Package (not Available w/Airbags) R74 Touring Package M4P3 911 Turbo Sport Feb 1993 M4P3 911 Turbo Sport 1994 3.6 Turbo M6A Black floor mat \"Porsche\" M6B Floor mat \"Porsche\" M6E Space gray mat M6F Metropol blue mat M6J Nephrite green mat M6M Boxster red mat M6P Graphite gray mat M6S Savanna beige mat SAC AC Rapid charger SBE Battery Eliminator SL Special Leather interior (Coupe/Targa/Cabriolet) SLB Standard Battery SUL Ultra-light battery SVD Voice activated dialer kit S6 Cellular phone with console TS2 911 Turbo S2 for USA only conversion kit VA3 Tourist delivery prep PORSCHE EXCLUSIVE OPTIONS X-CODES and DESCRIPTION X Wood steering wheel XAA Aerokit XAD Rear GT Fins XC3 Hardtop (Cabriolet) XD3 Rain sensing windshield XD4 Crested Rim Caps XD9 Painted wheels body color XE2 4 exhaust outlet Muffler system XE3 Dimming rear view mirror XEH Self dimming side mirrors and rear view mirror XF2 Leather Instrument Housing XF7 Leather covered tray XH6 Leather Horn Button XJB Rear center console painted silver XJ2 Leather Impact Post XJ3 Leather Locking Knobs and Plates XJ6 Leather steering wheel column XJ8 Leather Shift Cover (Automatic Trans.) XKX Lower part of instrument panel painted silver XK7 Leather Shift Cover (Manual Trans) XL4 Rootwood Center Console, Door Panel and Trim Inlays w/Analog Clock XL5 Rootwood Center Console, Door Panel and Trim Inlays w/Analog Clock XMA Roof liner, A&B Pillars in leather XMB Leather sun visor with reading light XME Rear center console painted body color XMJ Rear center console carbon XML Rear center console light wood XMP Leather sun visors lighted mirror XMZ Rear center console leather XM6 Leather Door Openers and Handle Recess Plates XNB Rear center Console Dark wood XND Lower instrument panel painted body color XNS Steering column in leather XN2 Leather inside door handle XN7 Leather Parking Brake XN8 Leather sunvisors XN9 Leather sunvisors with mirror XPA 3 spoke steering wheel leather XPB 3 spoke steering wheel leather and light wood XPC 3 spoke steering wheel leather and dark wood XPD 3 spoke steering wheel leather and carbon XP3 leather boot cover (cabriolet) XP6 Leather Seat Belt Hinges XP7 Leather Seat belt Lock and Housing XP9 Leather radio speaker trim rings XRB 18 inch sport/classic wheels/tires XRL 18 inch sport design wheels XR3 Leather Front Seat Hinges XR5 Leather Backrest Lock Controls XR7 Rear window washer XSA Sports seat rear side of backrest painted body color XSB Sports seat rear side of backrest covered in leather XSD Seat adjust knobs in leather XTA Carbon Fiber Inside Door Latch XTG Inner rocker covers covered in leather XTJ Door grip light wood and leather XTK Door grip dark wood and leather XTL Door grip leather and carbon XTN Mirror adjust in leather XV3 Leather air conditioning adjusters XX1 Front floor mats embroidered Porsche XX2 Footwell lighting XX3 Lighted door storage compartments XX6 Leather shift pattern insert XY5 Leather Tiptronic shift plate XZD Dome lamp cover leather X09 Leather extended center console X18 Burl Wood Fittings to the instrument panel X19 Leather instrument housing X26 Steering Wheel all leather X28 Light Maple Burr wood steering wheel X30 Dark Maple Burr wood steering wheel X34 Painted instrument panel X40 Leather sun visors with ride side illumination X45 Instrument dials matching interior color X52 Console Mounted Leather CD Player X54 Stainless steel exhaust pipes X69 Door sills in Carbon embossed with model insignia X70 Door sills in steel with model insignia X71 Aluminum Painted Instrument dials X77 Airbag Steering wheel combination of carbon and interior color leather X85 Slant Nose 3.6 Turbo S X88 Increased HP, 3.6 Turbo S X89 Wheel Caps with Porsche crest painted on wheels X92 Front Spoiler 3.6 Turbo S Slant Nose Only X93 Rear Spoiler 3.6 Turbo S Normal and Slant Nose X99 Fender Vents 3.6 Turbo S Normal and Slant Nose Y Wood package Y6 Wood Tiptronic selectro knob and brake Y0 Wood brake and shifter levers Y01 Aero Kit 1 includes front and rear spoilers Y02 Aero Kit 2 includes front and rear spoilers and rockers Y04 Carbon fiber package Y05 Carbon/Aluminum shift knob and brake handle Y06 Leather/Aluminum shift knob and brake handle Y07 Light maple/Aluminum shift knob and brake handle Y08 Dark maple/Aluminum shift knob and brake handle Y17 Leather console options package Y23 Aluminum and chrome Tiptronic shifter Y24 Carbon Fiber Tiptronic Selectro and Brake Y29 Aluminum and chrome package X54, X70 and X71 Y61 Carbon Fiber Tiptronic Shift Knob and Brake Y65 Leather dash package Y75 Aero Kit (C4S) Z-Codes & Descriptions Z02 Roofliner in Leather Z05 Leather headliner, pillars and sunvisors in unique color Z06 Leather Welting in Color Z08 Trunk Carpeting to match interior Z09 Carpet welting 98/99 Z10 Leatherette Welting in current colors Z11 Carpet Welting in current Porsche colors Z12 Leatherette Piping in current Porsche colors Z18 Sunvisor in Leather Z21 Stitching in deviating colors Z23 Door stitching in deviating colors Z24 Dashboard stitching in deviating colors Z25 Center console stitching in deviating colors Z27 Leather headliner, pillars and sunvisors Z28 Leatherette headliner, pillars and sunvisors Z30 Leather Piping in current Porsche Colors Z31 Seat Stitching in current Porsche Colors Z32 Leather Piping Z34 Non standard Carpet colors Z36 Leather Luggage Compartment Cover Z41 Pearl White metallic paint Z42 Leather door trim in deviating colors Z43 Leather Door trim and arm rests in deviating colors Z45 Leather seat inlays in deviating colors Z46 Leather front seat inlays in deviating colors Z48 Front hood without Porsche Crest Z49 Front seat belts in deviating colors Z50 Seatbelts front and rear in Guards red, Speed yellow or Riviera blue Z51 Leather seats Z53 Head restraints with Porsche crest Z69 Unique Carpet Color Z77 Non standard color steering wheel Z79 Leather pillars in deviating colors Z80 Leather A pillar and window frame Z81 Leather A/B pillar Z84 Non standard color stitching front and rear seats Z86 Dashboard in deviating colors, requires leather interior Z88 Non standard color stitching excluding seats Z95 Painted brake calipers Z96 Non standard leatherette colored roofliner Z108 Upper dash in non-standard color Z109 Lower dash in non-standard color Z110 Instrument hump in non-standard color Z111 Seat insert in non-standard color -
sandoval posted a topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
I am trying to figure out these option codes I can't find a master list anywhere... can someone point me to a Code=X list? I used Krindel site but it just gives me the numeric options. Thanks, Eric C02 XAA XPA XRL XSA XSY 236 288 375 376 424 476 490 601 659 696 983 Thanks! Eric -
Pictures posted here: http://www.6speedonline.com/forums/showthr...&threadid=15008 Ask for Jeff at Sunset Imports it was $208 shipped. FYI I just placed my order with Sunset Imports 955 505 900 00 96.81 955 505 901 00 61.96 955 505 902 00 11.63 955 505 903 00 11.63 955 044 800 59 6.20 $188.23 Installing does require you to remove the front bumper. You Need Drill & bits Torx set 2 bits T25,T26&T27 2 of the three can't remember without looking. I recommend using the socket Torx in fact I don't think you can get a full size Torx screwdriver in front of the wheel. Ratchet and extension Needle nose pliars if you have pop up headlight washers Phillips screwdriver -There are 5 or 6 torx screws in each wheel well that needs to be removed. -There are 2 torx screws near the bumper turn signals one up one forward on each side. -on the rear of the existing plastic skid plate there are 4 ot 5 Torx bolts that need to be removed. at each end there is a Phillips headed screw. -Under the Hood there are 4 torx screws and 2 plugs that need to be removed. -Once you remove all of these screws and bolts (This is where a helping hand comes in handy. You need to reach in on the side and pull up on a lever that is a latch each side has one. You can feel it. Towards the top on the side of the bumper cover about a 12-18" in. Once you release these the bumper will slide out. -If you have the Pop up headlight washers you need to unhook the hose and clamp it. I used a set of needle nose vice grips to pinch off the hose. -There is also a wiring harness that needs to be removed both the hose and wiring harness are on the passenger side near the fender. Now that you have the bumper off. -Remove the Eye hook covers completely. - You need to drill holes into the existing plastic skid plate. There are little raised circles to direct you where to drill. there is about 10-12 holes that need to be drills. Use a drill bit that is the size of the circle. -Now that the holes are drilled flip the bumper cover over (So that it is sitting nose up to the ceiling) and put your Skid plate in place. I left the plastic protective film on until the job was done. I recommend not removing the film. -Before the next step make sure you have the plastic skid plate extension piece placed between the existing skid plate and the new SS skid plate. It is like a puzzle when you are looking at it you will know where it goes. Now Holding it in place start putting on the clips the large clips go around the outside the small clips go on up towards the nose where there is a small clearance. After you have a couple on Flip the bumper cover over so that the skid plate is on the floor. (I used towels for cushion) use a set of needle nose pliers to push the clamps down on the posts. You will understand when you are doing this it can be done with your fingers but you will have torn up hands by the end. Make sure you did not miss any of the posts. -I installed my Silver Hood crest at this point. -Now start putting everything back together. Just follow the directions I gave you to remove the bumper to put it back on. In reverse of course! - Peel the film from the Skid plate. -Install the two rubber Eye hook covers Woo hoo your done now sit back and appreciate your success!
02 seat belts on an 01
Coupe thank in Advance. -
Do you have the Part Numbers for Red Seat Belts on an 01 FRONT only
