valcax
Everything posted by valcax
  1. maybe the old owner replaced 4300 to 5200? how I can know my K bulb?
  2. 4300ºK, are you sure? I think philips d2s is available in other ºK ?
  3. Hi, I know the porsche boxster 986 litronic mounts a Philips D2S as Xenon bulb. I need to know about these bulb: - part number - color temperature (ºK)
  4. Loren, vin doesn´t support that information. help!
  5. I need to know my boxster version. it is 2.5 204cv MY99 How can I know?
  6. no reply?
  7. EXCUSe for confusing... I ask for part number a chrome Carrera logo. I know chrome Boxster logo is available.
  8. yes in boxster.... not in carrera? :o
  9. and "4" chorome logo? regards!
  10. what year is the last update cd navi for pcm2? cd part number? dvd part number?
  11. No boxster logo? :( sure?
  12. I could see on porsche 911 TSB two part number 000.044.000.83 design key as carrera GT 999.915.272.40 instant adhesive any design key with boxster logo? part number? on tsb design key is with 911 logo.
  13. in Spanish forums, many customers have installed 7mm spacer front and 15mm rear (with longer bolts), as they are sold by FVD, but this is not approved by Porsche!! They say all is ok!! CAN I INSTALL???
  14. I need to know: CD Compartment in Pcm Navi unit 8 bits is the same as 16 bits? I suppose the difference is in the mainboard, not in cd compartment.... wrong or right?
  15. No luck in ebay, any shop where to get? That´s all!!! If you can help me..... :cheers:
  16. pcm1 8 bits --> only Porsche disks. (last update 2000-2) pcm1 16 bits ---> from 02/2001 to 07/2002. There is a porsche tequipment update to 2004. If your soft version is 5.43 you can use opel disks and then you can get total update to 2006. If you are not sure you have 8 or 16 bits, you have to pull out your pcm navi computer and see part number: 996.642.122.00, 01, 02 --> 8 bits. 03 and 12 ---> 16 bits.
  17. thanks!!
  18. Now I know there are two versions of head but I need to know a part number.
  19. Part number of standard bolts 986?
  20. If you have pcm1 8 bits, only porsche supply discs (2000-2) but if you have 16 bits then you can buy opel ncdr to run your pcm nav. regards.
  21. The screws are not held on with much torque, so they must be seized. Try to use WD-40, PB Blaster, or another penetrant to loosen. --Brian 10 Nm as TSB
  22. How to unscrew? it was impossible for me!
  23. What size spacers and where did you get them? If they are the Porsche 5mm spacers, there is only one small screw to remove and then replace on the spacer. Many use 5mm, 6mm and maybe larger without the single mounting screw. Need more info to help you. Spacers are the same than coochas, Porsche kit 5mm spacer and longer bolts.
  24. Today I have been mounting spacers. Impossible for me unscrew little screws on hub. I have installed spacers with no screw, but with 130Nm on longer bolts. What tool did you use for removing screws on hub?
