persandberg
    Porsche Boxster S 2003
persandberg's Achievements
  1. Then I know! What will the pin 25 be used for?
  2. Tanks! Are the pins sitting in order,my OBC stalk have only five pins.What to skip?
  3. Hi, I'm doing the OBC activation on my Porsche Boxster S 2003,Have anyone a wiring instruction from the 4 stalk to the connector 999.650.513.40 up to the Cluster? Regards Per
  4. My Boxster 2003 S which I changed cluster on is not possible to change anything with the OBC hack.Could this be because the WIN is not right,I also got protected on my CDR 23 radio.What need to be changed with the Porsche tool? /Per Yes, the new cluster needs to be synch'ed with your DME and other MOST devices. Thank's,I will let Porsche Center to do that.
  5. My Boxster 2003 S which I changed cluster on is not possible to change anything with the OBC hack.Could this be because the WIN is not right,I also got protected on my CDR 23 radio.What need to be changed with the Porsche tool? /Per
  6. I have the same display on my instrument cluster does that mean I have the OBC enabled,I have tried to do the retrofit with switch and it didn't work.Any tips how to get it function? /Per
  7. Hi, I tried the retrofit on my Boxster 2003 S,the display look the same as this one you show with 3 lines with temp on line 3,but it's not possible to change anything with the switch.I connected 22 and 24 to the PSM switch,any ideas how to get it work? /Per
  8. Hi, I have a 2003 S Boxster,I have connected a switch to the pin 22 and 24 in the instrument cluster,I can only read trip,odometer and temp on the third line,I can't change any thing.Do you know if anything have changed on the OBC on 2003 S? Regards Per
  9. Hi,How to control the OBC if you don't have the stalk avilable.What wiring and control can you add to Boxster S 2003. Regards Per
