rada70
Everything posted by rada70
  1. I'm curious as well. I don't think it's doable, since no one responded!
  2. wow. that's excessive! So just to fully understand, this model# is the only one that will work with my car? I found a lot of amplifiers online but with different model #'s.
  3. Loren sorry but I don't have the sticker. Is there another way to find that out? The cayenne is the S Titanium version, if that helps. Thanks
  4. Loren Hi, Can you tell me the part # for US models. I have an 06 Cayenne S. Thanks Need to know your radio/PCM option. I8DU or I8DV ? I really don't know what that means Loren. How can I find out?
  5. Loren Hi, Can you tell me the part # for US models. I have an 06 Cayenne S. Thanks
  6. Loren, I will become a contributing member as soon as possible. The body shop has the TSB from Porsche. They don't know the missing part#s, (my guess they don't know how to translate it). I also need to know how to find out whether my car is equipped or not. It's a Cayenne 2006 Titanium. Thanks for your help
  7. Thanks Loren. They are having a problem with the locking device connector. I was told today that I might need a relay, a harness, and an ECU for the carrier. Is that true?? I don't think I need all that. Is there a plug where the wire of the carrier plugs in to? Thanks
  8. Hi guys, After a long wait I finally got the spare tire carrier installed on my cs06. My buddy shop is having a hard time trying to connect the wires to the car. The project got in to a halt for that reason. Any suggestions will be appreciated.
  9. Do you guys know of a reputable performance shop in NY. I would like to do a cat bypass ECU upgrade and so forth Thanks
  10. Any reports on the performance of the turbo cluster? IS everything working as it should? Thanks
  11. Thanks guys. These instructions came in handy. I had it done this morning. It looks a lot nicer than the stock ones.
  12. I got it done. It was time consuming.
  13. Hi, This is my first post. I was attempting to install a cd changer in to my 2006 CS. I need help of getting the inside panel off. I didn't want to cause any damage to the car. Thanks in advance.
  14. I just had a Tooki Bluetooth by NAV-TV installed. It works fine. It works through your PCM unit. I like it.
